03-25-2019, 23:13 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 449 | Samsung GT-E1270 unlock Chinese Miracle II [SPD module] v 1.27 ========================= Start ========================= 25-03-2019 / 22:04:24 ================================================== ======= Set mode to : SPD6530_SAMSUNG Start at : [25-03-2019 / 22:05:12] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 41 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : SEND_ERROR_RSP(0x97) func:_FDL_HWInit, line:453 8è~~ &d |
03-28-2019, 20:57 | #3 (permalink) |
Member: 85718 Status: Offline Thanks Meter: 449 | Did you tryed ? With my phone have no success , tryed one by one. Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL NOT started! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! SPRD mode : SC6531 : REV : 0000 : NOR : [ 4MB ] SPRD mode : SC6531 : REV : 0000 : NOR : [ 4MB ] Operation : Identify [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL Start Failed! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! SPRD mode : SC6531 : REV : 0000 : NOR : [ 8MB-16MB] Operation : Identify [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL NOT started! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! SPRD mode : SC6531 : REV : A000 : NOR : [ 4MB ] Operation : Identify [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL NOT started! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! SPRD mode : SC6531 : REV : C000 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 ERROR : BOOT ACK not received! Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ] Operation : Identify [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL NOT started! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL NOT started! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! Operation : Identify [ v1.04 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! SPRD mode : SC6531 : REV : 0000 : NOR : [ 4MB ] Operation : Identify [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL NOT started! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! |
