12-03-2018, 11:07 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Europe, Lemberstadt Age: 53
Member: 9889 Status: Offline Thanks Meter: 50 | SC6531 extracting phonebook I try to read phonebook with CM2SPD: Code: ==== Wait for phone... Phone found! [ 48 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Check data ... Reading UDA ... Process can take some time, please, wait "Access violation at address 004E9A92 in module CM2SPD.exe. Read of address 00000000" after this program freeze Reading flash w/o problem: Code: Card found: S/N : 03DB4A81 , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SPD6531 Operation : Read FullFlash [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 48 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32.bin Done! Elapsed: 00:00:53 Reconnect Power/Cable! |
12-04-2018, 10:20 | #3 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | Here fullflash: MEGA ????????????? |
12-07-2018, 11:39 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Making. Since every vendor/vault modify structure and algo of record it took some time. To try universalize it. Next time other box dumps will be ignored at all. I not want rebuild and correct other faults. |
12-08-2018, 01:50 | #6 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | I understand you I mistakely give you full readed by other box Sorry Here is sane fullflash readed by Infinity MEGA ????????????? Thanx |
