06-23-2009, 08:51 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: BULGARIA Age: 53
Member: 14868 Status: Offline Thanks Meter: 44 | Sciphone i68+ problem unlocking SIM1 Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: PHONE25_GEMINI_07B_HW Software version: MAUI.07B.W08.16.MP.V Software date: 2006.06.14 Barcode: AT+EGMR=0,5àà imei: 354236021002813 imei: 356893066002815 Finished, time used: 12 sec Power off phone now ! after unlock standart metod: all operations done , but same state on the phone on SIM 1 - > X , on SIM2 full bar. tried unlock Read codes, but cannot connect phone(phone full powered , but cannot connect) - no success tried format ffs(safe) - no luck here is detailed info too: COM1 [Serial0] selected module v2.83 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot Off chip: 0001:4003:000A status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 208818FFFFFFFF:20881800000000 flash: ST ST [def 0080x040000] 32Mb detecting chip #01 in region #00... flash: 208818FFFFFFFF:20881800000000 flash: ST ST [def 0080x040000] 32Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 208818FFFFFFFF:20881800000000 flash: ST ST [def 0080x040000] 32Mb detecting chip #01 in region #00... flash: 208818FFFFFFFF:20881800000000 flash: ST ST [def 0080x040000] 32Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 02000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: L01_GEMINI_07B_PCB01_GPRS_MT6225_S00.MAUI_07B_W08_ 16_MP_V4_F1.BIN ver. sw 2: MAUI.07B.W08.16.MP.V4.F1, 00000000 ffs offset/size: 01C00000/00400000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01C00000 flash: 208818FFFFFFFF:20881800000000 checking area [00000000]: 00000000-01FFFFFF... ffs/eeprom found near: 01C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01C00000-01FFFFFF detecting ffs/eeprom structure pass 1... ........................... detect standard fat location pass #1... .................................................. ............................. detect standard fat offset pass #1... detect standard fat data... detected record size adjusted fat layout detection complete ffs/eeprom detected ok: element #1 detecting ffs/eeprom structure pass 2... ........................... detect standard fat location pass #1... ......................... detect standard fat offset pass #1... detect standard fat location pass #2... .................................................. ... detect standard fat offset pass #2... detect standard fat data... fat layout detection complete ffs/eeprom detected ok element #2 Check firmware integrity Done Check firmware content ... detecting firmware build... .................................................. ............................. firmware build: 200905131615 detecting product-id... .................................................. .................................................. ............................ done detecting languages... .................................................. ............. language parameters detected detected languages: En Ru Gr Fr Es It De Id Th Vn Cn Tr Farsi Pt Cn Ar Check firmware content Done Backup required data ... Finished, time used: 126 sec Remove/Install battery now ! any help is welcome !!!!! |
06-23-2009, 09:47 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, Try to make unlock with "smart fast" method and post here operation log. Are you sure that phone is locked to network operator ? What text you see at phone LCD when you power-on it with sim card ? |
06-26-2009, 16:03 | #4 (permalink) |
Member: 14868 Status: Offline Thanks Meter: 44 | well, phone flashed with fullflash , working in the same condition. after that made ffs complete format after that repaired both IMEI after that repaired security area. working well without sim card, but .... with SIM just power off itself, just after entering PIN code. |
SCIPHONE I68/I68+ CECT p168/P168+ & I9 Codes | dredyns | Chinese Models & Cloned Phones | 53 | 03-24-2011 12:36 |
China Sciphone i68 | Zelda42 | Chinese Models & Cloned Phones | 2 | 05-13-2010 21:13 |
Problem with sciphone i68+... | Defcon01 | Chinese Models & Cloned Phones | 9 | 08-29-2009 06:38 |
Sciphone i68 / i68+ video player question ! | baxyus | Chinese Models & Cloned Phones | 1 | 01-15-2009 03:37 |
