05-07-2018, 19:42 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Online Sonork: 100.1674604 Thanks Meter: 1,421 | SCR MODULE Select correct file! Need help I flashed with different model now phone DEAD,I want to write its dump back i get this Error : Load file error! Neither PAC or BINARY file! SCR module support BIN and PAC files as FlashFile! Select correct file! 16MB DUMPS HERE https://www.4shared.com/rar/s5WCVfpA...__MBW_L18.html Code: SPRD mode : SC6531 : REV : C000 : NOR Operation : Identify [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [FIDELIX] : FM25Q128 : 0x01000000 [ 16MiB ] Done! Elapsed: 00:01:10 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [FIDELIX] : FM25Q128 : 0x01000000 [ 16MiB ] Read Ok! Saved to : C:\Users\Plus\Desktop\FLASH_DUMP FEDELIX MBW L18.bin Done! Elapsed: 00:04:20 Reconnect Power/Cable! |
06-11-2018, 15:31 | #6 (permalink) |
Member: 96478 Status: Online Sonork: 100.1674604 Thanks Meter: 1,421 | Am Back Load firmware ok but cant write it Code: Card found : xxxxxxx , v0137 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.03 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR SPRD mode : SC6531 : REV : C000 : NOR Operation : Identify [ v1.03 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [MACRONIX] : MX25U128 : 0x01000000 [ 16MiB ] Done! Elapsed: 00:00:21 Reconnect Power/Cable! Code: BINARY : FLASH_DUMP FEDELIX MBW L18.bin FLSIZE : 0x01000000 Load Ok! Operation : Write Flash [ v1.03 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! BIN : Format UserData BIN : Format UserData Ok! Error : Flashing failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
The Following User Says Thank You to Kirumira For This Useful Post: |
06-11-2018, 18:06 | #8 (permalink) |
Member: 96478 Status: Online Sonork: 100.1674604 Thanks Meter: 1,421 | SAME ERROR CANT WRITE FLASH Logs Code: SPRD mode : SC6531 : REV : C000 : NOR BINARY : FLASH_DUMP BMW L14.bin FLSIZE : 0x01000000 Load Ok! Operation : Write Flash [ v1.03 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! BIN : Format UserData BIN : Format UserData Ok! Error : Flashing failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! BINARY : FLASH_DUMP kimfly F200 FIDELIX FM25Q128.bin FLSIZE : 0x01000000 Load Ok! Operation : Write Flash [ v1.03 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! BIN : Format UserData BIN : Format UserData Ok! Error : Flashing failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! BINARY : FLASH_DUMP MHORSE ONE ME.bin FLSIZE : 0x01000000 Load Ok! Operation : Write Flash [ v1.03 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! BIN : Format UserData BIN : Format UserData Ok! Error : Flashing failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! BINARY : FLASH_DUMP kimfly F23 FEDELIX.bin FLSIZE : 0x00800000 Load Ok! Operation : Write Flash [ v1.03 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! BIN : Format UserData BIN : Format UserData Ok! Error : Flashing failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
06-11-2018, 18:28 | #12 (permalink) |
Member: 96478 Status: Online Sonork: 100.1674604 Thanks Meter: 1,421 | NO sir. Logs Code: SPRD mode : SC6531 : REV : A000 : NOR Operation : Identify [ v1.03 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL NOT started! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! SPRD mode : SC6531 : REV : E000 : NOR Operation : Identify [ v1.03 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL NOT started! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! |
