Old 10-20-2017, 10:08   #1 (permalink)
brokendreem's Avatar
Member: 1150957
Thanks Meter: 60
Nokia 6 TA-1000 Dead
Just Try To Update Version 7.1.1
Flash With CM2 Tool, Now Phone Dead And Ask Hs-Usb Diagnostic Port,
Can Not Connect To Flash Mode All Time Show Hs-Usb Diagnostic Port,
I Think Its Boot Damage, Can Possible Boot Repair?
The Following User Says Thank You to brokendreem For This Useful Post:
Old 10-20-2017, 11:19   #2 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Post software logs here
Did you used firmware read by CM2
The Following 2 Users Say Thank You to Kirumira For This Useful Post:
Old 10-20-2017, 11:42   #3 (permalink)
Member: 1150957
Thanks Meter: 60
yes try to flash with one working phone read file
The Following 2 Users Say Thank You to brokendreem For This Useful Post:
Old 10-20-2017, 11:49   #4 (permalink)
Member: 1150957
Thanks Meter: 60
Card found : A8A8234A , v0136
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15
Loading firmware ...
Created by Infinity-Box (c) Chinese Miracle II (c) 2017
Device Brand : Nokia
Device Manufact.: FIH
Device Model : D1C
Device CPU : MSM8937
Device IntName : TA-1000_00CN
Device Version : 7.1.1
CU_SWVer : FIH
Device Compile : 8/17/2017 9:35:47 AM
Device ExtInfo : TA-1000
Load Ok!
Operation : Flash [ v1.15 ]
ForceFlashing : Disabled
Verify FW package ...
Verification passed!
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 430 [MSM8937]
ID_BLOCK_S : D9C09DEE
ID_BLOCK_I : 0004F0E1
ID_BLOCK_L : C2C82D1D0F85C14E6F843D57D9985DB7
ID_BLOCK_L : C0F097191FF03C7BB128E215B044AD9A
Pickup loader from firmware package
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RC14MB
Boot Ok!
Flash Chain : 65
Flashing now
Flashing : gpt_main0.bin
Flashing : NON-HLOS.bin
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : devcfg.mbn
Flashing : adspso.bin
Flashing : sec.dat
Flashing : splash.img
Flashing : emmc_appsboot.mbn
Flashing : boot.img
Flashing : recovery.img
Flashing : hwconf.cfg
Flashing : sysinfo.cfg
Flashing : splashm.img
Flashing : hidden.img
Flashing : cda.img
Flashing : persist.img
Flashing : misc.img
Flashing : mdtp.img
Flashing : cmnlib.mbn
Flashing : cmnlib64.mbn
Flashing : keymaster.mbn
Flashing : system.img
Flashing : cache.img
Flashing : userdata.img
Flashing : gpt_backup0.bin
Wipe data ...
BootConfig set to 0x00
Flashing done!
Done!
Elapsed: 00:09:46
Reconnect Power/Cable!
Old 10-20-2017, 13:28   #5 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Hello,
Read firmware from working phone,WRITE TO FAULTY PHONE with this http://forum.gsmhosting.com/vbb/12715360-post1.html
Post Results after.
Old 10-20-2017, 16:32   #6 (permalink)
Member: 1150957
Thanks Meter: 60
Originally Posted by Kirumira View Post
Hello,
Post Results after.
Phone Can Not Connect To Pc With Correct Driver,
All Time Ask Hs-Usb Diagnostic Port
How Can I Flash This Phone With Infinity-Box BEST NK2 v1.01
Old 10-20-2017, 19:58   #7 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Force phone to EDL mode , install emergency driver and flash it with correct TA-xxxx version.
The Following User Says Thank You to JayDi For This Useful Post:
Old 10-21-2017, 08:10   #8 (permalink)
Member: 1150957
Thanks Meter: 60
thanks for reply
first remove qualcomm driver then install
emergency driver
EmergencyDownloadDriver.msi
WinUsbCoInstallers.msi
WinUsbCompatIdInstaller.msi
WinUsbDriversExt.msi
how can i put phone to force edl mode?
1st time when flash phone with correct TA-1000, flash done then phone enter
qualcomm hs-usb diagonostics 900E port
and can not connect to edl mode so how can i flash it
Old 10-21-2017, 09:13   #9 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Now,use Keys combinations - Both Vol keys, or Edl-cable.
Old 10-21-2017, 10:07   #10 (permalink)
Member: 1150957
Thanks Meter: 60
bro try with this Keys combinations but can not connect edl mode
Old 10-21-2017, 12:02   #11 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
I think this one will not be diffucult for you
check here http://forum.gsmhosting.com/vbb/12603024-post1.html
Spoonfeeding is allowed here !!
Old 11-01-2017, 06:20   #12 (permalink)
Member: 1150957
Thanks Meter: 60
brother
try with foil, edl cable, use Keys combinations all r same
only qualcomm hs-usb diagonostics 900E port
i think its brick, any unbrick solution
Old 11-02-2017, 13:14   #13 (permalink)
Member: 1150957
Thanks Meter: 60
waiting any solution for long time............
Old 11-02-2017, 13:30   #14 (permalink)
JayDi's Avatar
Member: 462970
Disassemble device. Short TP. Reflash.
900E - edl stuck, happen after wrong hw version flashing.
Old 11-06-2017, 11:08   #15 (permalink)
Member: 1150957
Thanks Meter: 60
can you sent me Short TP picture
Page generated in 0.22924 seconds with 8 queries
