12-30-2008, 23:54 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 45
Member: 60701 Status: Offline Sonork: 100.1623285 Thanks Meter: 121 | Sfr 341 zte cable without open phone tested by me THANKS TO INFINTY FOR PINOUT AND SOFTWARE VERY GOOD CABLE |
The Following User Says Thank You to ali42 For This Useful Post: |
12-31-2008, 00:06 | #4 (permalink) |
Member: 60701 Status: Offline Sonork: 100.1623285 Thanks Meter: 121 | Sfr 341 zte cable without open phone tested by me Pinout to unlock sfr341 without open phone thanks to infinty for pinout and software very good cable[/quote] |
01-28-2009, 17:48 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
01-28-2009, 19:47 | #7 (permalink) |
No Life Poster Join Date: Mar 2002 Age: 46
Member: 10483 Status: Offline Thanks Meter: 23 | Thks for your hep, but I see the picture. We see the rx and tx but not gnd ???????? There is no pinout with simple cable with mini usb connector ???????? Is it the same pinout as aiko 78g ? Last edited by gsmnice; 01-28-2009 at 19:56. |
01-28-2009, 20:03 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, What is the reason to check picture but completely ignore text at left side of "Shell" ? keyboard top connector 2x5 1 2 3 4 5 6 7 8 9 10 4: Box Tx/Phone Rx (RJ45 pin-2) 5: Box Rx/Phone Tx (RJ45 pin-3) 6: Gnd |
02-04-2009, 14:46 | #10 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | Quote:
You are in GSM business but don't know how to find the Ground Pin. Its very strange...... Ground pin on connector can be found very easily by simply using a multimeter. Check the continuity of Negative terminal of battery connector with the all the pins of data connector(Connector where you connect cable with box) of phone one by one. The pins which shows full continuity with Negative terminal of battery is simply is a Ground pin. BEST OF LUCK! yawarniazi Last edited by yawarniazi; 02-04-2009 at 14:56. | |
The Following 2 Users Say Thank You to yawarniazi For This Useful Post: |
02-04-2009, 20:57 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | read this again: http://forum.gsmhosting.com/vbb/show...49&postcount=8 Your are wrong, information is very good. You must say now BIG SORRY ! Your are wrong, connector is 2x5 pins. You must double check phone connector again and say now BIG SORRY ! |
02-05-2009, 21:38 | #12 (permalink) |
Member: 10483 Status: Offline Thanks Meter: 23 | I ll check, but I repeat explication is not very good for the pinout of this phone. Infinity box, very good team, and maybe the best team and best support, but for this phone, I think you can do better. Where can I buy connector 2x5 ????? I unlock the phone because I opened it, but it s not pratical. BIG SORRY INFINITY TEAM Thks |
02-05-2009, 22:07 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | What is the problem with given pinout exactly ? You must explain. You can get it everywhere, f.e. from this phone charger, or f.e. here: http://www.infinity-box.biz/index.ph...infinder&lg=en Just use cable and in this case you do not need to open phone. |
zte f 285 unlocking 100% tested by me | AjayBansal | ZTE CDMA | 93 | 06-24-2013 09:38 |
zte c321,c370 og unlock file & flasher tested by me | rehan41u | ZTE CDMA | 1 | 06-05-2013 08:30 |
SFR-341 ZTE unlocked | godwin | Infinity-Box | 7 | 01-15-2010 15:35 |
zte mts c339 unloking tested by me | rehan41u | Various CDMA/TDMA Cell Phones | 1 | 11-27-2009 17:20 |
