Faisal_Computer | 06-05-2010 13:05 | Sigmatel not celebrated >> Hi ,
got mobile of sigmatel problem is when ever we try to power on its say not celebrated on LCD ,
i had tried all things which i can , but still same problem , here i am giving you link for that flash file , please check it thanks PHP Code: http://rapidshare.com/files/395533346/T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL__fullflash_20100605-151603.B0M.bin
==== [6/5/2010 2:56:34 PM] ====
COM3 [VCP0] selected
module v3.14
Action: touchscreen calibration
mode: 2
Calibration order: reverse
Model: Autodetect 6205-6239 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:1003:0002
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: T600_V04_EnFrArRuSpPeVi_SIGMATEL
Version: T600_V04_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 35798632542412
connection Ok
detecting structure #5 (mode-2)...
18 17 done
210 byte(s) read
reading data #2...
512 byte(s) read
calibration value: 0
writing data...
verification...
verification Ok
Power-On and test phone now
If calibration is not completed yet:
1. make "Reverse calibration order" UN-checked and try again
2. try another calibration mode
Finished, time used: 41 sec
Remove/Install battery now !
==== [6/5/2010 2:57:34 PM] ====
module v3.14
mode: 3
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
connection Ok
detecting structure #5 (mode-3)...
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error:
detection failed (20 tries)
What to do:
Try another calibration method, if still no luck:
1. make full flash backup for emergency case
2. make "format ffs"
3. Power-On phone
4. Power-Off phone by "Power" button (do NOT remove battery)
5. Repeat "Calibration" operation again
6. if still no luck read full flash and send to support with subject: touchscreen calibration failed
error: can't detect ffs/eeprom structure id
error: operation failed !
Finished, time used: 14 sec
==== [6/5/2010 2:57:58 PM] ====
module v3.14
mode: 4
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
connection Ok
detecting structure #5 (mode-4)...
What to do:
3. Power-On phone
Finished, time used: 12 sec
==== [6/5/2010 2:58:22 PM] ====
module v3.14
mode: 1
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
connection Ok
detecting structure #5 (mode-1)...
1 4 5 6 done
211 byte(s) read
reading data #2...
512 byte(s) read
writing data...
verification...
verification Ok
1. make "Reverse calibration order" Checked and try again
==== [6/5/2010 2:58:53 PM] ====
module v3.14
mode: 1
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
connection Ok
19 18 done
147 byte(s) read
reading data #2...
reading data #3...
can't read required data
Finished, time used: 25 sec
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
==== [6/5/2010 2:59:37 PM] ====
module v3.14
Device: Autodetect 6205-6239 NOR
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
460800
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info ver: 04
sw version: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL.BIN
project-id: T600_V04_EnFrArRuSpPeVi_SIGMATEL, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 48 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
==== [6/5/2010 3:01:10 PM] ====
module v3.14
mode: 3
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0error:
What to do:
3. Power-On phone
Finished, time used: 54 sec
==== [6/5/2010 3:02:23 PM] ====
module v3.14
mode: 2
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
connection Ok
18warning: wrong packet cs
17 done
210 byte(s) read
reading data #2...
512 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 15 sec
==== [6/5/2010 3:02:55 PM] ====
module v3.14
mode: 1
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
connection Ok
19 18 done
147 byte(s) read
reading data #2...
reading data #3...
Finished, time used: 22 sec
==== [6/5/2010 3:03:26 PM] ====
module v3.14
mode: 1
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
connection Ok
1 4 5 6 done
211 byte(s) read
reading data #2...
512 byte(s) read
writing data...
verification...
verification Ok
==== [6/5/2010 3:03:57 PM] ====
module v3.14
mode: 4
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
connection Ok
What to do:
3. Power-On phone
Finished, time used: 11 sec
==== [6/5/2010 3:04:18 PM] ====
module v3.14
mode: 4
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
connection Ok
What to do:
3. Power-On phone
==== [6/5/2010 3:04:40 PM] ====
module v3.14
How to calibrate touchscreen:
- for this operation you need to have full flash backup from phone
- if you have full flash backup already press "Yes", select full flash file and follow instructions given by software
- if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure
Do you have full flash backup ?
aborted by user
Finished, time used: 7 sec
==== [6/5/2010 3:04:54 PM] ====
module v3.14
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
reading: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL__fullflash...
file saved: C:\Documents and Settings\Faisal Hussain\My Documents\T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL__fullflash_20100605-151603.B0M.bin
Finished, time used: 11 min 15 sec
==== [6/5/2010 3:16:17 PM] ====
module v3.14
Loading file v.02...
T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL__fullflash_20100605-151603.B0M.bin loaded
ffs/eeprom record offset detected
ffs/eeprom record size detected
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
67 byte(s) read
connection Ok
512 byte(s) read
211 byte(s) read
1748 byte(s) read
writing data...
verification...
error: verification failed
what to do:
1. be sure that you have full flash backup for emergency case
2. make "format ffs" in "complete" mode
3. power-on phone
4. power-off phone by "Power" button (DO NOT remove battery)
5. repeat current operation
==== [6/5/2010 3:17:00 PM] ====
module v3.14
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
67 byte(s) read
connection Ok
512 byte(s) read
211 byte(s) read
512 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 17 sec
==== [6/5/2010 3:17:51 PM] ====
module v3.14
mode: 1
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
67 byte(s) read
connection Ok
19 done
211 byte(s) read
512 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 10 sec
==== [6/5/2010 3:18:13 PM] ====
module v3.14
mode: 2
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
67 byte(s) read
connection Ok
18 17 done
210 byte(s) read
512 byte(s) read
writing data...
verification...
verification Ok
==== [6/5/2010 3:18:35 PM] ====
module v3.14
mode: 3
19200 autodetect
Initializing [6225:8A05]...
CPU: MT6225
high speed boot On
chip: 0000:0000:0000
status: 18
error: initialize step #1 failed
Can not initialize test mode, possible reasons:
1. communication fault, repeat required operation
2. ffs/eeprom is seriously damaged, use repair ffs/eeprom files or use another unlock/format method
==== [6/5/2010 3:18:54 PM] ====
module v3.14
mode: 3
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
67 byte(s) read
connection Ok
What to do:
3. Power-On phone
==== [6/5/2010 3:19:21 PM] ====
module v3.14
mode: 4
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
67 byte(s) read
connection Ok
What to do:
3. Power-On phone
==== [6/5/2010 3:19:51 PM] ====
module v3.14
Action: repair security area
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
detecting startup code area #2...
startup code area #2 is absent
sec info (fast) detection...
error: incorrect ffs address range
Finished, time used: 1 min 23 sec
==== [6/5/2010 3:21:25 PM] ====
module v3.14
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
67 byte(s) read
connection Ok
building list...
done
items to clear: 135
items cleared: 135 of 135
building list...
done
items remains: 0
Remove/Install battery now ! Br
Faisal_Computer |
