02-23-2017, 09:40 | #1 (permalink) |
Freak Poster Join Date: Jan 2015 Location: manshera,Pakistan
Member: 2330556 Status: Offline Thanks Meter: 79 | Cm2 Flashing Problem phone was working before flashing..some apps were crashed..i flash the phone with research downloader but problem was same.then i erase phone with cm2. Now i am trying to flash the phone with cm2 it gives error.. NOW WHEN I TRY TO FLASH WITH REASERCH DOWNLOADER I GIVES REPARTETION ERROR I TRIED THIS TRICK BUT SAME ERROR ON FDL2 Last edited by arsikhanarsi; 02-23-2017 at 09:47. |
02-23-2017, 14:18 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Seems FlashIC problem, did you made FlashIC Test? Also can try with other firmware rev. Br. Infinity Box Team. |
02-25-2017, 07:53 | #3 (permalink) | |
Member: 2330556 Status: Offline Thanks Meter: 79 | Quote:
but the problem was same.Then i decide to erase and now my phone is dead. Flash ic test info is here ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:19 Reconnect Power/Cable! | |
02-25-2017, 08:09 | #4 (permalink) | ||
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | PMT update fails shows usually if eMMC damaged .... and your eMMC test log shows all........ Quote:
The Following 2 Users Say Thank You to .::EXTREME::. For This Useful Post: |
02-25-2017, 12:43 | #5 (permalink) | |
Insane Poster Join Date: May 2016
Member: 2573221 Status: Offline Thanks Meter: 11 | Quote:
The Computer Still Detect The phone After He dies ? | |
09-17-2020, 06:35 | #8 (permalink) |
Insane Poster Join Date: Apr 2020 Location: Mananjary
Member: 2955238 Status: Offline Thanks Meter: 6 | same problem for me! ================== Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:25 ======================================== Any one have this firm please::: Device info : Patch Level : MRA58K Display ID : J022-CRO1-J5--V01-20191115 Ver. Incmt : root-103233 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-07-01 Build Time : 15.11.2019 Product Brand : Qnet Product Name : sp7731g_1h10_hd_oversea Product Device : sp7731g_1h10 Product Board : sp7731gea_hdr Product Manfct : Beldar Board Platform : sc8830 Product Info : sp7731g_1h10 Product Model : CRO1 Thank in advance |
