06-27-2020, 17:22 | #46 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
What was the reason to use flexihub/eltima with Infinity software ? | |
06-27-2020, 18:15 | #48 (permalink) |
Freak Poster Join Date: Feb 2019 Location: Haripur Thakurgaon Bangladesh
Member: 2894519 Status: Offline Sonork: 100.1673673 Thanks Meter: 34 | === DongleManager [Infinity] v1.80 [6/27/2020 22:57:29] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0001242A1F394082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 0B6D242A Firmware version: 0144.02 === Process started: 6/27/2020 22:57:30 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 Warning Dongle misconfigaration plz fix it infinity best team |
06-27-2020, 18:20 | #49 (permalink) | |
As soon as you will confirm that it was read I will tell you what to do to fix an issue. | |
06-27-2020, 18:20 | #50 (permalink) | |
Attach fault.bin file from Infinity software folder. | |
06-27-2020, 20:45 | #53 (permalink) | |
Junior Member Join Date: Dec 2005 Location: UKRAINE LVIV
Member: 207766 Status: Offline Sonork: 100:1579346 Thanks Meter: 0 | Quote:
Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Applet upgrade ok Checking Dongle Identification... Identification Ok. Finalizing... Finalizing ok Process completed | |
06-28-2020, 15:27 | #54 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1260678 Status: Offline Thanks Meter: 2 | === DongleManager [Infinity] v1.80 [28/06/2020 17:25:21] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0105AF6F20281292 === Process started: 28/06/2020 17:25:21 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 help me |
06-28-2020, 20:34 | #55 (permalink) | |
Result ? | |
06-28-2020, 21:14 | #56 (permalink) |
Junior Member Join Date: Jun 2020 Location: Pakistan Age: 33
Member: 2960812 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.80 [6/23/2020 6:16:16] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00013CE7212B4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 238C3CE7 Firmware version: 0144.02 === Process started: 6/23/2020 6:16:18 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. bought new dongle... getting this problem. dont know what happened ... kindly help me |
06-29-2020, 10:03 | #57 (permalink) | |
There is a software conflict with the next application(s): \program files (x86)\intel\bluetooth\devmonsrv.exe \program files (x86)\intel\intel(r) usb 3.0 extensible host controller driver\application\iusb3mon.exe \program files\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.exe \program files (x86)\nec electronics\usb 3.0 host controller driver\application\nusb3mon.exe \program files\via xhci uasp utility\usb3monitor.exe What to do: 1. Delete or rename files (see above) 2. Reboot PC 3. Delete fault.bn file 4. Update dongle firmware with DongleManager now 5. Run Infinity software. | |
06-29-2020, 10:53 | #58 (permalink) | |
Member: 1260678 Status: Offline Thanks Meter: 2 | Quote:
thanks for your helping all services of the dongel now working with Alcor Micro USB Smart Card Reader but when i connect the main dongel i have this message ( Card with specified AID is not found ) whats the problem ?? thanks | |
06-29-2020, 12:24 | #59 (permalink) |
Freak Poster Join Date: Apr 2003 Location: Poland Age: 46
Member: 26055 Status: Offline Thanks Meter: 71 | need help === DongleManager [Infinity] v1.80 [29.06.2020 13:09:15] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0000DE0AFF001982 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 0A70DE0A Firmware version: 0134.02 "UK Edition" status: On Last launched Application: 0000 v.0000 => Activations: - 00: Infinity-Box/Dongle v0134 => Options: - Infinity-Box/Dongle cant update to for higher version |
