08-27-2020, 07:30 | #346 (permalink) |
Junior Member Join Date: Oct 2016 Location: Dagestan Age: 38
Member: 2634033 Status: Offline Sonork: уке
Thanks Meter: 0 | Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to |
08-27-2020, 10:50 | #347 (permalink) | |
What is the dongle HWID ? | |
09-21-2020, 17:10 | #348 (permalink) |
Junior Member Join Date: Sep 2008
Member: 872306 Status: Offline Thanks Meter: 0 | == DongleManager [Infinity] v1.80 [21/09/2020 17:08:49] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 01099169147D1292 === Process started: 21/09/2020 17:08:49 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to https://www.infinity-box.com/support/?r=2 |
09-21-2020, 18:42 | #349 (permalink) | |
1. Install REQUIRED Card-Reader Drivers - https://www.infinity-box.com/support/?r=6 File with Drivers: CardReader_Fetian_FT2K.7z File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 2. Run DongleManager 3. Update Dongle firmware ONCE OR 1. Insert Smart-Card into another Card-Reader. Good result for today gives Alcor Card-Reader. 2. Run DongleManager - https://www.infinity-box.com/support/?r=5 3. Update Dongle firmware ONCE In case of problem DO NOT update card again but contact to support ! | |
11-13-2020, 21:41 | #350 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2095674 Status: Offline Thanks Meter: 1 | pls help my cm2 give error below === DongleManager [Infinity] v1.80 [11/13/2020 20:43:56] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000102F1CC74082 === Process started: 11/13/2020 20:43:56 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 |
11-13-2020, 22:45 | #351 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
11-15-2020, 20:30 | #354 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1218506 Status: Offline Thanks Meter: 0 | may card sim is dead in first activation for cm2 now i lost may mony or how to tr may card sim is dead in first activation for cm2 now i lost may mony or how to translat may activation to a new dongle pleas help me i lostmay mony Infinity-Box CardID v1.09 Error when listing readers SmartCard API error #2148532270 Cannot find a smart card reader. Error when listing readers SmartCard API error #2148532270 Cannot find a smart card reader. Error when listing readers SmartCard API error #2148532270 Cannot find a smart card reader. |
11-15-2020, 20:38 | #355 (permalink) | |
This text means Dongle is not connected to PC Do you have it connected to PC usb port ? | |
11-15-2020, 20:54 | #356 (permalink) | |
Member: 1218506 Status: Offline Thanks Meter: 0 | Quote:
yes i hav remov the card and put it in anather dongle workin fine sam problem may problrm is i want to update the dongle andstoped in the methle not finished and get errin 13-11-2020 i paid may first activation 58.00 euro | |
11-15-2020, 20:57 | #357 (permalink) | |
Insert smart-card into another card-reader and read info now ! Result ? | |
11-15-2020, 22:36 | #359 (permalink) | |
Insert smart-card to card-reader and make this: - Connect dongle/box to PC - Run CardID.exe - https://www.infinity-box.com/support/?r=7 - Select Card-Reader - Click to "Read" button DO NOT send screenshot/video but copy/paste text from software window ! also you must try with anothe USB port, with another PC Last edited by YellowBoss; 11-15-2020 at 22:44. | |
