01-15-2016, 06:45 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: perlis
Member: 351660 Status: Offline Thanks Meter: 5 | spd reading firmware always fail,help? 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 112 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Failed! Error_Info : Connect Failed , USB Debug NOT enabled, or driver NOT installed! Reconnect Power/Cable! |
01-15-2016, 06:55 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Code: [FW_READER] : Step #2 Failed! Error_Info : Connect Failed , USB Debug NOT enabled, or driver NOT installed! All explained on Reading FW manual. All on support - drivers and manuals. |
01-15-2016, 06:57 | #4 (permalink) | |
Member: 351660 Status: Offline Thanks Meter: 5 | Quote:
01-15-2016, 06:59 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Use Latest CM2SPD module. By default - software check if adb.exe running and ask to close it. Or check manually if it running and close in task manager. |
