01-19-2020, 10:29 | #1 (permalink) |
No Life Poster Join Date: Mar 2016 Location: MWA
Member: 2541648 Status: Offline Thanks Meter: 166 | SPD/UNI SOC Interface Crushes I have also noted that in my previous reading firmwares for mobicel, tecno, I was able to view boot_logo.bmp but in this model the all .bmp images not possible to view but read firmware completed succesfully Operation : Identify [ v2.04 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : Hisense_U605_00_S03_20190701 Ver. Incmt : Hisense_U605_00_S03 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-05-05 Build Time : 1561954216 Product Model : Hisense U605 Product Brand : Hisense Product Name : U605 Product Device : HS7731ESP Product Board : Hisense_U605 Product Manfct : Hisense Product Info : sp7731e_fs280 Product Board : sp7731e_fs280 Board Platform : sp7731e Platform Version: MOCORTM_17C_W18.23.4_P20_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.23.4_P20 HW Version: sc7731e_modem CMP_Time : 02-25-2019 18:03:32 MODEM TAG : MOCORTM_17C_W18.23.4_P20_Debug_FM_BASE_17C_W18.23. 4_P20_sc7731e_modem_pike2_pub UserData : STATE : PLAIN Done! Elapsed: 00:01:57 Operation : Read FW [ v2.04 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : Hisense_U605_00_S03_20190701 Ver. Incmt : Hisense_U605_00_S03 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-05-05 Build Time : 1561954216 Product Model : Hisense U605 Product Brand : Hisense Product Name : U605 Product Device : HS7731ESP Product Board : Hisense_U605 Product Manfct : Hisense Product Info : sp7731e_fs280 Product Board : sp7731e_fs280 Board Platform : sp7731e AndroidVer : 8 VlnrLevel : 0x00 SP7731E__Hisense__Hisense_U605__8.1.0__Hisense_U60 5_00_S03_20190701__OPM2.171019.012__sp7731e_fs280 Read : prodnv.img ExtSparse : Compression ratio : 42% Read : phase.cfg Read : recovery.img Read : tos.bin Read : sml.bin Read : u-boot.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Read : nvitem_w.bin Make : persist.img Read : gnssmodem.bin Read : gnssbdmodem.bin Read : modem_wcn.img Read : modem_w.bin Read : deltanv_w.bin Read : gdsp_w.bin Read : pm_sys.bin Read : boot.img Read : system.img ExtSparse : Compression ratio : 88% Make : cache.img Read : vendor.img ExtSparse : Compression ratio : 71% Read : vbmeta.img Read : fbootlogo3.bin Read : fbootlogo4.bin Read : fbootlogo5.bin Read : customerdata.bin ExtSparse : Compression ratio : 2% Read : udc_config.bin Make : userdata.img Read : u-boot-spl.bin Firmware size : 0x63034C60 ( 1.55 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:36:18 So though i can view the .bmp files is this file still safe for flashing or not? |
01-19-2020, 15:15 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello, can you send me whole FW folder, which on SW crash? That will help find problem. |
01-22-2020, 14:12 | #5 (permalink) | |
Member: 2541648 Status: Offline Thanks Meter: 166 | Quote:
I Misunderstood your Comment the FW folder I sent has FW folder whic dumped after opening interface and .bmp files still not open, The first dump folder was deleted. But because I have faced this two times I will upload again the folder when I have the phone with same issue | |
01-23-2020, 19:06 | #6 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Quote: non-veiwed fblogo not mean anything infact, inside black screen as default. If you get crash at same device, probably, it may be some port conflict, or AV issue, when SW process file. Anyway, need check exactly fault case. | ||
