06-01-2008, 12:53 | #1 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Spice 404n Can't be unlock. I try to unlock this phone but it is show this error on the read code unlock method. Here is the log. Code: COM11 [VCP0] selected Action: read codes unlock method: read codes Model: Spice S404N Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6205:8B00]... CPU: MT6205 Connecting, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 33 sec Remove/Install battery now ! Code: COM11 [VCP0] selected Action: read codes unlock method: read codes Model: Spice S404N Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6205:8B00]... CPU: MT6205 Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 6 sec Remove/Install battery now ! Code: COM11 [VCP0] selected Action: read codes unlock method: read codes Model: Spice S404N Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6205:8B00]... CPU: MT6205 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 98 sec Remove/Install battery now ! What to do . . . . . |
06-01-2008, 15:45 | #3 (permalink) | |
Member: 343326 Status: Offline Thanks Meter: 1,463 | Yes i also I use "Standard" unlock method. But can't be work. After complete operation when i insert Idea sim card or other card..... It say network not support. Here is the using "Standard" method log. Quote:
How to solve this problem. | |
06-01-2008, 18:21 | #5 (permalink) |
Freak Poster Join Date: Jun 2004 Location: jb cell world Age: 47
Member: 70916 Status: Offline Thanks Meter: 56 | amol_sm first of all download the flash file from support area nd flash the phone then unlock it every thing will be fine no need to rebuild imei or format ffs this solution is tested by me do it and post reply |
06-02-2008, 10:43 | #6 (permalink) | ||
Member: 343326 Status: Offline Thanks Meter: 1,463 | Thankx for the help me friend's. I solve my problem after flash & unlock "Standard method". Here is the flashing log. Quote:
& here is the unlocking log. Quote:
Phone is OK but in my view don't need to flash the phone for just unlocking. Infinity Team also i post here previous unlocking log. But before flash the phone i try to unlock but phone can't take another card . . . . Why . . . .? It is bug or something else . . . .But after flash & unlock flash phone is working fine. | ||
07-25-2008, 09:29 | #7 (permalink) |
Freak Poster Join Date: Apr 2007 Location: punjab
Member: 483406 Status: Offline Thanks Meter: 180 | Device: Spice-S404 COM4 [VCP0] selected Device: Spice-S404 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup disabled Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... ......... detect device identification#1 finished identification#1 protocol ver: 02 ver. sw1: GW15IMSIROAM_PCB01_GSM_MT6205B_DN.1_19.BIN ver. sw2: 1.19, 00000000 ffs offset/size: 00300000/000E0000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC22A000000000:18E59F00000000 Backup required data Done Patch required data... ........ lock area found Patch required data Done Special operation... detecting additional parameters... ................ error: additional parameters detection failed detecting additional parameters... ................ error: additional parameters detection failed detecting additional parameters... ................ error: additional parameters detection failed detecting additional parameters... ..... flash: EC22A000000000:18E59F00000000 flash: EC22A000000000:18E59F00000000 Write: area 3/1 error: error# 000000FF error: flash write error: 00170000:00002000 2E3B3B3BFC2E3B3B3BFC2E3B3B3B8C2E3B3B3BDF2E3B3B3BC5 2E3B3B3B7A2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BBC 2E3B3B3BD62E3B3B3BC52E3B3B3B7A2E3B3B3B9C2E3B3B3BFC 2E3B3B3BFC2E3B3B3B3C2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BF22E3B3B3BFC2E3B3B3BFC2E3B3B3B49 2E3B3B3BFC2E3B3B3BFC2E3B3B3B123A1A2E3B3B3BFC2E3B3B 3BF12E3B3B3B882E3B3B3BE02E3B3B3BFC1A1A error: can't write required area error: additional parameters detection failed Special operation Done Write... error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer error: no any expected answer: wrong answer after chip id request error: can't detect chip at required chip base Write Fail Finished, time used: 64 sec Remove/Install battery now ! |
Nokia 6630 can't be unlocked by JAF No Tp unlocker, help! Logs. | kevinyin | JAF No Tp Unlocker by Cinek | 4 | 02-07-2009 14:18 |
Spice 404n not netork unlock,chek this log infinity team. | maheshsaiganesh | Infinity-Box | 1 | 10-16-2007 13:54 |
spice 404n not netork unlock. | maheshsaiganesh | Infinity-Box | 1 | 10-16-2007 13:53 |
What phones soft versions can't be unlocked by free JIC unlocker???? | Tygiel | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 12-20-2002 19:07 |
Sagem MW932 FF3,1N - can't be unlocked? | kreitzz | Infineon C16X M51 & ARM7 M52 BASED | 7 | 04-28-2002 04:43 |
