10-04-2008, 16:32 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, We will give you exact answer after you will read and folow this advice: http:///vbb/showthread.php?t=546293 So for now everything is in your own hands ! Please do not make any delay with information ! |
12-15-2008, 14:26 | #9 (permalink) | |
No Life Poster Join Date: Nov 2006 Age: 44
Member: 388207 Status: Offline Thanks Meter: 221 | Quote:
Price :- 2500.00(In indian currency approx) CPU CHIP :- Infineon inbuilt memory card slot with simple camera motorola L6 charger supported to charge this phone connector pic attached waiting eagerly for the support of this model as well as all other spice hadsets in infinity | |
12-15-2008, 18:17 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. How many pins in connector ? 2. try to use PinFinder and detect pinout 3. try to read flash from this phone like ZTE-225 model, let's see results. |
04-07-2009, 04:58 | #12 (permalink) |
Member: 388207 Status: Offline Thanks Meter: 221 | cable l10c rx3 tx5 cpu infenion not connecting in pana1 i tried almost all model with same log here i attach please advice what i should i do phone is in running condition with the problem that call not connecting and no incomming COM2 [VCP0] selected module v1.65 Device: ZTE-125 Checking data, wait... Action: read eeprom Boot ... Press and HOLD Power button now ! e-gold: A0 loading... error: can't run preloader: Release Power button now Boot Failed Finished, time used: 5 sec Remove/Install battery now ! COM2 [VCP0] selected module v1.65 Device: LG-KG276 Checking data, wait... Action: read eeprom Boot ... Press and HOLD Power button now ! e-gold: A0 loading... error: can't run preloader: boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Failed Finished, time used: 7 sec Remove/Install battery now ! |
The Following User Says Thank You to Deepakranasaria For This Useful Post: |
04-07-2009, 04:59 | #13 (permalink) |
Member: 388207 Status: Offline Thanks Meter: 221 | COM2 [VCP0] selected module v1.65 Device: LG-KG276 Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! e-gold: A0 loading... error: can't run preloader: boot answer: 01 Release Power button now Boot Done Set Baud ... slowest Set Baud Done Connecting ... Connecting Failed Finished, time used: 11 sec Remove/Install battery now ! |
04-08-2009, 09:39 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If this phone can not be booted well like other models this means that we can not make solution remotely. if you can sell to us this phone for tests pls contact to [email protected] Thank you ! |
25/04/08 : ET-BoX v1.63 Released - Spice Again on TOP ;) Added Spice S900 & S909 | nonu_don | ET-BoX | 17 | 03-18-2010 08:52 |
14 May 2008: "Hero of India" in action: Spice-S808, Spice-S415, Lenovo-i706... | InfinitySupport | Infinity-Box | 33 | 05-17-2008 17:15 |
06 Nov 2007: "Hero of India": Spice-S535, Spice-S545, LG-KG195 models supported | InfinitySupport | Infinity-Box | 26 | 01-11-2008 10:17 |
pls HELP INFINITY, spice s404 formated fs in spice s410 by mistake. now s404 is dead | shahi | Infinity-Box | 2 | 11-02-2007 15:15 |
19-03-2007 New Spice tool released! Now we support ALL Spice phones! | GSMtricks | Multi-Box | 36 | 04-02-2007 07:40 |
