04-30-2016, 14:01 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Spice mi 362 hangs on logo :- 1ST READ INFO Code: Operation : Check/Read Info [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : c936w_emcp_xll_spice Model Brand : Spice Model Device: c936w_emcp_xilaile AndrVersion : 4.4.2 BaseBand CPU: C936W_EMCP_XILAILE CompileDate : 01-Dec-14 8:25:33 AM Project Ver : Spice_Mi-362_IND_Ver1.3 Model Ext : Mi-362 ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:18 Reconnect Power/Cable! Code: Operation : Format File System / Reset Settings [ v1.16 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000031FFB000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:19 THE PHONE WAS STILL ON LOGO. THEN I FLASHED IT WITH 7715_4.4.2_C936W_XLL_Spice_Mi-362_EMCP2x2_V09_20140925 THEN THE PHONE GOES TO WHITE SCREEN 2ND READ INFO Code: Operation : Check/Read Info [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : c936w_emcp_xll_spice Model Brand : Spice Model Device: c936w_emcp_xilaile AndrVersion : 4.4.2 BaseBand CPU: C936W_EMCP_XILAILE CompileDate : 25-Sep-14 12:35:54 PM Project Ver : Spice_Mi-362_IND_Ver0.9 Model Ext : Mi-362 ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:16 NOW I AGAIN FLASHED WITH THE FIRST ORIGINAL VERSION BUT STILL HANGS ON LOGO READ INFO Code: Operation : Check/Read Info [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : c936w_emcp_xll_spice Model Brand : Spice Model Device: c936w_emcp_xilaile AndrVersion : 4.4.2 BaseBand CPU: C936W_EMCP_XILAILE CompileDate : 27-Nov-14 8:27:51 AM Project Ver : Spice_Mi-362_IND_Ver1.3 Model Ext : Mi-362 ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:40 Reconnect Power/Cable! Code: Operation : Format File System / Reset Settings [ v1.16 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : Size : 0x000000002FAF0000 State : 0x0001 Mount : Size : 0x0000000008F0D000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:20 I USED UPGRADE DOWNLOAD TOOL 2.9.9015 ANY WAY TO SOLVE THIS? WBR sahil2000ind |
04-30-2016, 14:14 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Is it written V2-New PA at back sticker? This phone has two hardware revisions, try to flash with 7715_4.4.2_C936W_XLL_Spice_Mi-362_EMCP2x2_HTX_V19 Br. Infinity Box Support Team. |
04-30-2016, 14:22 | #3 (permalink) | |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Quote:
WBR sahil2000ind | |
04-30-2016, 14:29 | #4 (permalink) |
Insane Poster Join Date: Jul 2011 Location: Sirsa Age: 32
Member: 1611651 Status: Offline Sonork: aruninsan Thanks Meter: 24 | 1. NV read 2. bro only use ................ by flash with select option Format all android data than flashing. 3. NV write 4. Done Last edited by YellowBoss; 05-06-2016 at 12:38. |
05-06-2016, 12:39 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @Arun Insan Please next time use brain and think well before make posts. Here is Infinity-Box support forum but not other products advertizing section ! Thank you ! |
