05-01-2009, 06:55 | #1 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 200548 Status: Offline Thanks Meter: 104 | spice s535 unlock sucessfull module v2.72 Device: Spice-S535 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... ........... detect device identification#1 finished identification#1 protocol ver: 02 ver. sw 1: GW23_PCB01_GSM_MT6205B_DN.2_07.BIN ver. sw 2: 2.07, 00000000 ffs offset/size: 00300000/000E0000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: Spice-S535_GW23_PCB01_GSM_MT6205B_DN.2_07__ffs... file saved: C:\Program Files\InfinityBox\MModule\Spice-S535_GW23_PCB01_GSM_MT6205B_DN.2_07__ffs_20090501-111652.B0E.bin flash: EC22A000000000:18E59F00000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... detecting additional parameters... ...... flash: EC22A000000000:18E59F00000000 flash: EC22A000000000:18E59F00000000 Write: area 0/1 .......... additional parameters detected Ok Special operation Done Write ... flash: EC22A000000000:18E59F00000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 415 sec Remove/Install battery now ! thanx infinity team |
The Following User Says Thank You to bittubansal For This Useful Post: |
05-01-2009, 08:05 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
Spice S535 ""ntwk Not Supported""-tried Unlock-no Scope | zone2 | Infinity-Box | 9 | 11-21-2008 22:15 |
Spice S535 Successfully Unlocked With Infinity | amit_varietymob | Infinity-Box | 8 | 06-24-2008 19:23 |
Spice S535 Set Wrong Unlock | debmobile | Infinity-Box | 10 | 05-23-2008 13:46 |
Spice S535, S545 Need Update | ramesh_931 | Infinity-Box | 15 | 01-12-2008 19:28 |
06 Nov 2007: "Hero of India": Spice-S535, Spice-S545, LG-KG195 models supported | InfinitySupport | Infinity-Box | 26 | 01-11-2008 10:17 |
