06-22-2022, 12:20 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Spreadtrum SPD6531 Recover PhoneBook.. is this software bug otr unsupported device or what..? Code: Set mode to : SPD6531 Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 59 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Elapsed: 00:00:06 Reconnect Power/Cable! |
06-22-2022, 13:23 | #3 (permalink) |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | if u mean "Read Firmware" it is done.. and i repated the operation (read phonebook) many times and same error.. Code: Operation : Read FullFlash [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 59 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Set FileInfo : Model Vendor : Nokia Model Name : Asha500 ExtInfo Data : EN Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32_EN__Nokia-Asha500.bin Done! |
06-22-2022, 15:26 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | It may be some kind of damaged or unknow ffs (where notebook is stored) structure. Probably Data Explorer can do the job but Im not sure. Yoo can upload backup file somewhere, I can try to test. |
06-23-2022, 13:14 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, Infinity Data Explorer can do the job. You can order Data Explorer licence via Infinity Online Service, it's almost instant (10-15 min) Code: DE Card found : S/N: ... Firmware Version: 0101 Operation : Extract Data SPD [v1.08] Source: Dump SPD653x Loading file : SC6531BA_SR1131BA_00400000_GD25LQ32_EN__copy_Nokia-Asha-500.bin ... OK Searching FileSystem ... OK *** FileSystem found at: [003C8000] size: [00038000] *** Memory Info : [00008000][00000007] Extracting FileSystem ... *** Stage #1 Searching required data ... *** Contacts Found *** Messages Found Extracting contacts... *** Extracted 288 contact(s) TXT saved to - C:\InfinityBox\DataExplorer_v1.08\ReadOut\SC6531BA_SR1131BA_00400000_GD25LQ32_EN__copy_Nokia-Asha-500_23_06_2022_14_09\ VCF saved to - C:\InfinityBox\DataExplorer_v1.08\ReadOut\SC6531BA_SR1131BA_00400000_GD25LQ32_EN__copy_Nokia-Asha-500_23_06_2022_14_09\ Extracting messages... *** Extracted 18 message(s) TXT saved to - C:\InfinityBox\DataExplorer_v1.08\ReadOut\SC6531BA_SR1131BA_00400000_GD25LQ32_EN__copy_Nokia-Asha-500_23_06_2022_14_09\ Finish. |
