Start If we received a chineese phone from customer with no power condition and no hardware problem , how we make that phone alive from infinity box? What are the steps? Will we need to flash the phone or some says format ffs is enough . Please help us |
In many cases "Format FFS Complete" is enough to alive a dead chinese phone. But if phone not get alive at this stage then go ahead to flash the phone, still no luck then check phone's hardware. BEST OF LUCK! yawarniazi |
thank you sir. if we received a phone with hang problem if we give ffs complete is there any posibility of dead phone.? what is mean by ffs safe and ffs complete?if we do ffs complete ,infinity box take some backup. what is that backups? how can this backup helpful ? how to restore backup? |
pls help . because this is important beginners like me |
hello! at the time when you are beginner always do backups. for this you must perform "read full flash" operation. use maximum available speed, this will save your time. after that it is safe to do whatever you want. start from Format FFS safe check phone condition. if this does not help- continue with Format FFS complete. if phone died- you simply load your saved backup as "firmware" and write to phone. use option"smart write", in this case you will restore your phone in a minute. |
sir when we format ffs infinity also take some backups . what is for? when we need to restore backup? sir if flash chineese phone like alfatel how many files we needed? or single file is contain all (mainfile,flex,lp)? from your help i am so much ok in infinity. you are great . you admire beginner like me . thanks |
hello! our program automatilcy saves only EEPROM area backup. this is helpful when phone dies after format. in this case you just load this backup as"eeprom" and write back to phone. FULL backup is 100% guarantie against any operations. even if you flashed phone by wrong flash file- you can restore it back. Single full backup file contains main flash area + EEPROM |
thankyou sir you are great |
