03-12-2009, 09:28 | #1 (permalink) |
Junior Member Join Date: Dec 2005
Member: 214987 Status: Offline Thanks Meter: 3 | Still On pana01 Update Pls infinity team I observed a little problem about ZTE A66 I successfully flashed and unlock about 3 with pana01 v1.64 the log for one is below: COM113 [VCP0] selected module v1.64 Device: ZTE-A66 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: AIN-P108A17V1.0.0B01 15 48 16 ZAIN-P108A17B01-EnFr-NG01 g3dBV2.0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A66_eeprom-static_20090311-151935.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A66_eeprom-security_20090311-151936.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A66_eeprom-complete_20090311-151942.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Write Done Finished, time used: 248 sec Remove/Install battery now ! but there is one I tried unlocking but it gives the following log COM113 [VCP0] selected module v1.64 Device: ZTE-A66 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820013 loading... next part... boot answer: 00 error: unknown bootcode answer: Release Power button now Boot Failed Finished, time used: 6 sec Remove/Install battery now ! I think there is still the need for Another update which will support e-gold:820013 and other higher bootcode if there is. since all the successful ones are egold:820000 while this is egold:820013 thanks. |
08-08-2009, 14:35 | #4 (permalink) |
Major Poster Join Date: Feb 2004 Location: MAROUA CAMEROUN Age: 59
Member: 52636 Status: Offline Thanks Meter: 5 | COM23 [VCP0] selected module v1.69 Device: Sagem-my150x For ZTE A66 Egold-820013 OK Sucsseful unluck By using sagem my150 Model its ok ok Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820013 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-static_20090808-141008.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-security_20090808-141009.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-complete_20090808-141011.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_lock-area_20090808-141017.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 35 sec Remove/Install battery now ! |
08-08-2009, 20:18 | #5 (permalink) |
Freak Poster Join Date: May 2005 Age: 54
Member: 145807 Status: Offline Thanks Meter: 4 | Zte A66 820013 ok COM11 [VCP0] selected module v1.69 Device: Sagem-my150x Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820013 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-static_20090808-201344.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-security_20090808-201345.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-complete_20090808-201352.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_lock-area_20090808-201411.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 68 sec Remove/Install battery now ! |
The Following User Says Thank You to SAM5 For This Useful Post: |
08-20-2009, 22:01 | #6 (permalink) |
Major Poster Join Date: Mar 2007
Member: 475196 Status: Offline Thanks Meter: 1 | COM1 [VCP0] selected module v1.68 Device: Sagem-my150x Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820013 loading... error: can't run preloader: 01 middle part... error: can't run middle loader: 0802 Finished, time used: 12 sec Remove/Install battery now ! pls i need a help |
update firmware still on 1.03 | jackyivan | Cyclonebox | 3 | 05-02-2009 21:46 |
Still on Pana01 V1.64 update | mohammed ako | Infinity-Box | 1 | 03-22-2009 18:22 |
padfinder sleeping in update still now no update | fixed | PadFinder box | 6 | 11-08-2008 23:14 |
Sugestion For Next Pana01 Update | torpedo_seluler | Infinity-Box | 3 | 06-30-2008 08:35 |
Still No New Update On Server | pig | Cruiser Suite | 8 | 05-27-2004 01:44 |
