Old 10-06-2015, 16:44   #1 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 239
STOP button and ASUS T001 UNLOCK
1. Hello dear team how I anderstand it's princip yes that You dont want add stop funktion fore CM
Its note comfortable use
2. Need ASUS T001 MTK UNLOCK solution.
Operation : Check / Read Info [ v1.32 ]
Wait for phone...
Phone found! [ 36 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 1501004E35585A4D4201B917D0B93165
DA Stat : v4.2 on BBID : 0x87
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : BMZX5
[eMMC] : FLASH_CID : 1501004E35585A4D4201B917D0B93165
[eMMC] : FLASH_EXT : 00400000/00080000
[eMMC] : FLASH_LEN : 0x00000000E9000000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Done!
Elapsed: 00:00:12
Reconnect Power/Cable!
Old 10-06-2015, 16:57   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello.
1. Yes.
2. http://forum.gsmhosting.com/vbb/11283777-post21.html
Old 10-06-2015, 17:06   #3 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 239
Originally Posted by JayDi View Post
1.Wery fine princip (If fore You it comfort no need other be confort )
2.Dear Dzirt I know way how activete spunlock buton but I need solution fore this phone unlock
Operation : SP Unlock [ v1.32 ]
Mode : Direct Unlock
Wait for phone...
Phone found! [ 36 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Bad data #1 , somethig went wrong!
Operation Failed
Elapsed: 00:00:17
Wait for phone...
Phone found! [ 36 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:16
Wait for phone...
Phone found! [ 36 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:15
Old 10-06-2015, 17:55   #4 (permalink)
JayDi's Avatar
Member: 462970
Make debug log read left upper corner
Other -> SP : Make Debug log.
Send it me with NVRAM backup.
Old 10-06-2015, 19:11   #5 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 239
dear Dzirt its files You want yes?
Old 10-06-2015, 21:20   #6 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 239
I think send files note true and only this files true
Old 10-06-2015, 21:23   #7 (permalink)
JayDi's Avatar
Member: 462970
Got files. Will check them and let you know result.
Old 10-06-2015, 21:25   #8 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 239
Ok thanks but only tell me please you will chek now or tomorow becouse in the morning phone will geve client.
Old 10-07-2015, 10:37   #9 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 239
Hello dear is therre any news?
Page generated in 0.18708 seconds with 9 queries
