06-05-2020, 08:05 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Pakistan Age: 44
Member: 240756 Status: Offline Thanks Meter: 90 | Stylo S55 Nova MT6580 I Accidently flashed Stylo S55 Nova with wrong File Stylo VS571 and Now Mobile is Dead But Detect and Connecting with.is There any solution to unbrick and Revive... Please any Moderator Help me.i try to flash with its original File but flashing failed. Card found : D0FD8DDE , v0140 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.09 Load IDBase v518137 Ok! Update configuration ... Update Ok! Load IDBase v518137 Ok! Operation : Write Flash [ v2.09 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :18 [FL] : Set : preloader.bin [FL] : Set : pgpt.bin [FL] : Set : proinfo.bin [FL] : Set : nvram.bin [FL] : Set : lk.bin [FL] : Set : lk2.bin [FL] : Set : boot.bin [FL] : Set : recovery.bin [FL] : Set : para.bin [FL] : Set : logo.bin [FL] : Set : odmdtbo.bin [FL] : Set : expdb.bin [FL] : Set : vendor.bin [FL] : Set : frp.bin [FL] : Set : tee1.bin [FL] : Set : tee2.bin [FL] : Set : secro.bin [FL] : Set : system.bin [FL] : Total size : 0x6BDADC5C [ 1.69 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM18) MODE : BOOTROM PORT : 18 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1952 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4500017045453848CE06013879B524F6 DAInf: 4 : 2 : 156 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 7001004548384545380106CEF624B579 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : MT6752 EMI : SRC : preloader_k80_bsp.bin EMI : CNT : 0009 EMI : [00] : ID : 150100464E58324D42 : VEN : SAMSUNG | DEV : FNX2MB : RAM : [ 1.00 GB ] EMI : [01] : ID : 150100463732324D42 : VEN : SAMSUNG | DEV : F722MB : RAM : [ 1.00 GB ] EMI : [02] : ID : 700100454838454538 : VEN : KINGSTON | DEV : EH8EE8 : RAM : [ 1.00 GB ] EMI : [03] : ID : 13014E51324A393551 : VEN : MICRON | DEV : Q2J95Q : RAM : [ 1.00 GB ] EMI : [04] : ID : 700100454838434438 : VEN : KINGSTON | DEV : EH8CD8 : RAM : [ 1.00 GB ] EMI : [05] : ID : FE014E50314A39354B : VEN : MICRON | DEV : P1J95K : RAM : [ 1.00 GB ] EMI : [06] : ID : 90014A483847346132 : VEN : HYNIX | DEV : H8G4a2 : RAM : [ 1.00 GB ] EMI : [07] : ID : 150100464E36324D42 : VEN : SAMSUNG | DEV : FN62MB : RAM : [ 1.00 GB ] EMI : [08] : ID : 13014E51324A393554 : VEN : MICRON | DEV : Q2J95T : RAM : [ 1.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DA : Failed to configure DA! ERROR : 00000BC4 : DEVICE NOT FOUND Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
06-05-2020, 09:52 | #2 (permalink) |
Member: 240756 Status: Offline Thanks Meter: 90 | No one is here to Answer of my post.what i made Mistake.plz infinity Team help me out of this problem.is that Driver issue or something els.please Reply.... Thanx |
06-05-2020, 23:03 | #3 (permalink) |
Member: 240756 Status: Offline Thanks Meter: 90 | im wonder and shocked that no one is replying of my post and no respons even.but anyway finnaly i revive My Device Stylo Nova S55.if i made something wrong so someone correct me that that is your doing wrong and is your mistak.But its fine and thanx to all Here is Log and Device is power on... Card found : D0FD8DDE , v0140 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.09 Load IDBase v518137 Ok! Update configuration ... Update Ok! Load IDBase v518137 Ok! Operation : Write Flash [ v2.09 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :18 [FL] : Set : preloader.bin [FL] : Set : pgpt.bin [FL] : Set : proinfo.bin [FL] : Set : nvram.bin [FL] : Set : lk.bin [FL] : Set : lk2.bin [FL] : Set : boot.bin [FL] : Set : recovery.bin [FL] : Set : para.bin [FL] : Set : logo.bin [FL] : Set : odmdtbo.bin [FL] : Set : expdb.bin [FL] : Set : vendor.bin [FL] : Set : frp.bin [FL] : Set : tee1.bin [FL] : Set : tee2.bin [FL] : Set : secro.bin [FL] : Set : system.bin [FL] : Total size : 0x6BDADC5C [ 1.69 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM68) MODE : PRELOADER PORT PORT : 68 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Write Flash [ v2.09 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :18 [FL] : Set : preloader.bin [FL] : Set : pgpt.bin [FL] : Set : proinfo.bin [FL] : Set : nvram.bin [FL] : Set : lk.bin [FL] : Set : lk2.bin [FL] : Set : boot.bin [FL] : Set : recovery.bin [FL] : Set : para.bin [FL] : Set : logo.bin [FL] : Set : odmdtbo.bin [FL] : Set : expdb.bin [FL] : Set : vendor.bin [FL] : Set : frp.bin [FL] : Set : tee1.bin [FL] : Set : tee2.bin [FL] : Set : secro.bin [FL] : Set : system.bin [FL] : Total size : 0x6BDADC5C [ 1.69 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM68) MODE : PRELOADER PORT PORT : 68 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1952 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4500017045453848CE06013879B524F6 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 7001004548384545380106CEF624B579 EMMC: VEN : KINGSTON | OEM : 01 | DEV : EH8EE8 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1C8000000 [ 7.13 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 5D06A323817DE500BB5D695B6E69337A STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (CUST) SEC_DL : SECURE USB DL DISABLED SEC_ID : 0x35464646304237304435444533464335 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000400000 Erase : 0x0000000000000000 : 0x0000000000880000 Erase : 0x0000000001C80000 : 0x00000001C5300000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader code ... Update bootloader Ok! Write : PGPT Write : PROINFO Write : NVRAM Write : LK Write : LK2 Write : BOOT Write : RECOVERY Write : PARA Write : LOGO Write : ODMDTBO Write : EXPDB Write : VENDOR Write : FRP Write : TEE1 Write : TEE2 Write : SECRO Write : SYSTEM [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:02:24 Reconnect Power/Cable! |
The Following User Says Thank You to Aazib jhon For This Useful Post: |
