05-10-2008, 20:19 | #1 (permalink) |
No Life Poster Join Date: Apr 2006
Member: 260998 Status: Offline Sonork: 100.1581802 Thanks Meter: 181 | ....::::Successfully Unlock ZTE 227 by Infinity::::.... to select model 225 ZTE 227 Vodafone pinout Keyboard Up 1.........8 1 - phone Tx 2 - phone Rx 3 - Gnd [IMG]http://www.*********.com/upload/1210446694.jpg[/IMG] tested 100% enter code 12345678 after unlock |
06-26-2008, 15:28 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Please, see here RJ45 pin description: http:///vbb/showthread.php?t=342807 |
09-20-2011, 09:53 | #14 (permalink) |
No Life Poster Join Date: Apr 2006 Location: SFAX/TUNISIA Age: 48
Member: 266765 Status: Offline Sonork: +21624131501 Thanks Meter: 336 | COM2 [VCP0] selected module v1.73 Device: SFR-227 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00EC:22A0 Connecting Done Check hardware ... sw version: -FR-P108B1V1.0.0B03 Feb 27 2008 11 46 47 VDF-P108B1B02-FrEsPtIt- Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\SFR-227_eeprom-static_20110920-095418.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg error: can't load database v.11 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\SFR-227_eeprom-security_20110920-095419.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\SFR-227_eeprom-complete_20110920-095421.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\SFR-227_lock-area_20110920-095425.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 28 sec Remove/Install battery now ! |
09-20-2011, 11:42 | #15 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
i can't unlock ZTE A61 by infinity box | shetos17 | Infinity-Box | 7 | 05-27-2010 10:17 |
can i unlock ZTE A316+ by DD ? | TheFoXMK | SAGEM JTAG UNLOCKER | 1 | 02-05-2010 17:53 |
i can't unlock ZTE A61 by infinity box | shetos17 | Infinity-Box | 1 | 09-28-2009 17:24 |
Successfully Unlock ZTE 227 With infinity | FayGsmDz | Infinity-Box | 3 | 11-08-2008 08:44 |
20 May 2008: ZTE-227, Vodafone-227, Philips-192, J-Max-JM5700, G-Tide-W110, user code | InfinitySupport | Infinity-Box | 27 | 05-23-2008 22:02 |
