02-05-2008, 08:13 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Dubai, UAE Age: 38
Member: 547967 Status: Offline Thanks Meter: 653 | Successfully unlocked another KG130 Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 35531******x current otp imei: 355311***xx file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_3553110***xx_L G KG130_20080205-230911.B1E.bin . . . . . . . version: 234-30V10a44KG130P40FL Check flash Done Check space... current eeprom imei: 355311******x . . . . . . . . . . . finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 106 sec Remove/Install battery now ! |
The Following User Says Thank You to mujahid_ali For This Useful Post: |
E75 Success Unlock!!! | jr astigin | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-29-2010 11:19 |
>>> another i607 successfully unlocked <<< | keaelite | UST Pro II | 3 | 04-25-2009 13:51 |
Another 6120c successfully unlocked with UB | sairat | Universalbox | 4 | 03-29-2009 06:51 |
Another 6120c successfully unlocked with UB | sairat | Universalbox | 0 | 03-17-2009 07:19 |
>>> another W380i successfully unlocked <<< | keaelite | SETool2 | 1 | 08-11-2008 14:37 |
