12-20-2015, 07:08 | #29551 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile S2 Gmail Acount Reset Done Qmobile S2 Gmail Acount Reset Done Only 1 click Code: Operation : Format FileSystem [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6580 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6580_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4838473165050718A1C5199223 DA Stat : v4.2 on BBID : 0x94 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A4838473165050718A1C5199223 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear Google Reset Protection Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to azhergoga007 For This Useful Post: |
12-20-2015, 07:08 | #29552 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 371 | Spice MI-348E Pattern Unlock Done Code: Operation : Format File System Settings : SmartFormat is On Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! Processing UBOT init ... UBOOT FCS Init Ok! Processing FL init ... Handshake with FL Ok! Factory Defaults : Will reset UserData and Settings! Format USERDATA partition ... Format USER Ok Reboot Phone Elapsed: 00:01:01 Reconnect Power/Cable! |
12-20-2015, 07:24 | #29553 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 301 Flashing Done Code: Core : v2.14 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm839__09.04.mcusw PPM : rm839__09.04.ppm_m2 CNT : rm839__09.04.image_m2_059Q9B5 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> Check SW version... FlashFile version : 09.04 Phone version : 02.33 17-05-13 RM-839 (c) Nokia -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... Batery voltage : 3399 mV -> Batery voltage less, than 3,7V (3399mV). Continue at user risk SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok CMLA Key read ... Ok Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 618 [XMM6180 QUARK] IF uCHIPID : 50A90012000CF583 IF Resp Data : 50A9070100030101 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : QUARK_1337.500_M1S1 QUARK EEP config Ok FLASHID : EC004000 , [ MuxOneNAND ] Boot conf set, Target Ready Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 359212051598165 IMEI 2 : 359212051598173 Phone Product Code : 059Q9B5 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359212051598165_XG618.rpl ===Flashing [MCU]=== Processing file : rm839__09.04.mcusw Region count : 8 00 : [ PSI ] : psi_flash_unsigned.fls 01 : [ BCore ] : slb_signed.fls 02 : [ Code ] : main_toc_signed.fls 03 : [ Code ] : rm839__09.04.mcusw_signed_mcusw.fls 04 : [ Code ] : swap_signed.fls 05 : [ Cust ] : dynsw.fls 06 : [ Code ] : aeneas_signed.fls 07 : [ Code ] : fota_signed.fls Parse done , flashing now Flash : 00 : psi_flash_unsigned.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x00090000 , Len : 0x00020000 Erase now... Erase done Region Start : 0x00090000 , Data Len : 0x00010FB0 Region Load done Write done psi_flash_unsigned.fls image flash done Flash : 01 : slb_signed.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60000000 , Len : 0x00040000 Erase now... Erase done Region Start : 0x60000000 , Data Len : 0x00040000 Region Load done Write done slb_signed.fls image flash done Flash : 02 : main_toc_signed.fls Sending Sec-Pack SecInfo Area : 0x0002 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60040000 , Len : 0x00000400 Erase now... Erase done Region Start : 0x60040000 , Data Len : 0x00000400 Region Load done Write done main_toc_signed.fls image flash done Flash : 03 : rm839__09.04.mcusw_signed_mcusw.fls Sending Sec-Pack SecInfo Area : 0x0003 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62E00000 , Len : 0x01100000 Erase now... Erase done Erase area 0x01 , Start 0xFFF00000 , Len : 0x00080000 Erase now... Erase done Region Start : 0x62E00000 , Data Len : 0x00F0D4CC Region Load done Write done rm839__09.04.mcusw_signed_mcusw.fls image flash done Flash : 04 : swap_signed.fls Sending Sec-Pack SecInfo Area : 0x0004 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80000000 , Len : 0x00F00000 Erase now... Erase done Region Start : 0x80000000 , Data Len : 0x00C2BCD0 Region Load done Write done swap_signed.fls image flash done Flash : 05 : dynsw.fls Sending Sec-Pack SecInfo Area : 0x0005 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62080000 , Len : 0x00100000 Erase now... Erase done Region Start : 0x62080000 , Data Len : 0x00044000 Region Load done Write done dynsw.fls image flash done Flash : 06 : aeneas_signed.fls Sending Sec-Pack SecInfo Area : 0x0006 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x63F79C00 , Len : 0x00080000 Erase now... Erase done Region Start : 0x63F79C00 , Data Len : 0x00046870 Region Load done Write done aeneas_signed.fls image flash done Flash : 07 : fota_signed.fls Sending Sec-Pack SecInfo Area : 0x0007 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x61F00004 , Len : 0x0017FFFC Erase now... Erase done Region Start : 0x61F00004 , Data Len : 0x00149890 Region Load done Write done fota_signed.fls image flash done ===Flashing [PPM]=== Processing file : rm839__09.04.ppm_m2 Region count : 1 00 : [ Cust ] : package_m2.ppm_ebl_psi.fls Parse done , flashing now Flash : 00 : package_m2.ppm_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80F00000 , Len : 0x00B00000 Erase now... Erase done Region Start : 0x80F00000 , Data Len : 0x0052A288 Region Load done Write done package_m2.ppm_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : rm839__09.04.image_m2_059Q9B5 Region count : 1 00 : [ Cust ] : package_m2_059Q9B5.image.fls Parse done , flashing now Flash : 00 : package_m2_059Q9B5.image.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0xA1000000 , Len : 0x0C580000 Erase now... Erase done Erase area 0x01 , Start 0xAE000000 , Len : 0x00300000 Erase now... Erase done Region Start : 0xA1000000 , Data Len : 0x01C35200 Region Load done Write done package_m2_059Q9B5.image.fls image flash done Flashing done! Total flash time : 00:00:14 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 301 Dual SIM Software Info: V 09.04 03-12-13 RM-839 (c) Nokia IMEI: 359212051598165 PPM version : V 09.04 03-12-13 RM-839 (c) Nokia M2 Product code: 059Q9B5 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... ===== WARNING ===== Battery voltage is NOT enough for start ===== WARNING ===== AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:00:57 |
12-20-2015, 08:03 | #29554 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | MMX D321 stuck at logo repaired by flashing and read NVRAM done- Flashing- Code: Scatter Load Ok , BaseBand : MT6572 , Project : s5201ap , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.39 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A483447326111018B7886696227 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111018B7886696227 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s5201ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3909 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x000000009DE40000 Flash Pre-Erase Done, time used : 00:00:08 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s5201ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:44 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:03 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:10 Reconnect Power/Cable! Code: Operation : Read NVRAM [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A483447326111018B7886696227 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111018B7886696227 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V36_1_wg_n Read Ok, MMX-D321-MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V36_1_wg_n_eMMC.spnv saved Done! Elapsed: 00:00:23 Reconnect Power/Cable! Infinity Box Support Team. |
12-20-2015, 11:17 | #29558 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | micromaxx d321 flash done Code: Scatter Load Ok , BaseBand : MT6572 , Project : s5201ap , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.39 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040505A24190C181 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040505A24190C181 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s5201ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3688 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x000000009DE40000 Flash Pre-Erase Done, time used : 00:00:10 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s5201ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:03 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:30 Reconnect Power/Cable! |
12-20-2015, 12:21 | #29561 (permalink) |
No Life Poster Join Date: Nov 2015
Member: 2488031 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,947 | i.onik Global Tab i725 MTK6572 Factory File Read Done Card found : S/N : 53421B11 , v0129 Chinese Miracle II [MTK module] v 1.39 Operation : Read Flash [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3038470F323732348179 DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! Operation : Flash [ v1.39 ] ======= Flash Nothing to flash! Select file first! Operation : Read Flash [ v1.39 ] Operation : Read Flash [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3038470F323732348179 DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3038470F323732348179 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G80ME [eMMC] : FLASH_CID : 45010053454D3038470F323732348179 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : i.onik ProdName : Global Tab i725 ProdModel : i725 Device : i725 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1.44 [Read Ok] : preloader_along12c_tb_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6572 / V1.1.1 / along12c_tb_kk / EMMC FW Size : 673 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__i.onik__i725__ i725__4.4.2__ALPS.KK1.MP7.V1.44\ All done! Done! Elapsed: 00:03:51 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to Suny125 For This Useful Post: |
12-20-2015, 12:22 | #29562 (permalink) |
No Life Poster Join Date: Apr 2014 Location: B A N G L A D E S H
Member: 2171294 Status: Offline Sonork: 100.1659207(No More Use) Thanks Meter: 706 | Maximus ICube Pattern Lock Read Done Code: Start at : [12/1/2015 / 2:07:45 AM] Operation : Read PatternLock [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 110100303034474530016A8BB053329D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 110100303034474530016A8BB053329D [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 2668 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 7548 Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
12-20-2015, 12:24 | #29563 (permalink) |
Member: 2171294 Status: Offline Sonork: 100.1659207(No More Use) Thanks Meter: 706 | Walton Primo F4 Virus Remove Done Code: Operation : Remove Viruses [SmartAV] [ v1.38 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D4201BAFDC2A361BF DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201BAFDC2A361BF [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 88 Removing infected files and scripts ... SmartAV Report : Removed 88 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:01:09 Reconnect Power/Cable! |
12-20-2015, 12:25 | #29564 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | voice v174 read flash and format done Code: Operation : Format File System [ v1.08 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 199 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0060 0017 0000 [0] Flash VEN : Winbond , W25Q64 [0] Flash CAP : 00800000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Read FullFlash [ v1.08 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 199 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0060 0017 0000 [0] Flash VEN : Winbond , W25Q64 [0] Flash CAP : 00800000 Read Flash Content Read Ok , collect info Platform : MOCOR_12C.W13.04.05_Release Project : SC6531_OPENPHONE HWInfo : SC6531_OPENPHONE Compile : 10-28-2014 18:15:35 Set FileInfo : Model Vendor : voice Model Name : v174 Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_MOCOR_12C.W13.04.05_Release_10282014181535__voice-v174.bin Done! Elapsed: 00:01:11 Reconnect Power/Cable! |
12-20-2015, 12:35 | #29565 (permalink) |
Banned Join Date: Jul 2011 Age: 32
Member: 1609044 Status: Offline Thanks Meter: 892 | Qphone Q101 readfw+Remove Viruses done via cm2 Qphone Q101 readfw+Remove Viruses done via cm2 Read fw log Code: Card found : S/N : ............ Chinese Miracle II [MTK module] v 1.39 Operation : Read Flash [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001005631303030380653B16A18A147 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 80001 [eMMC] : FLASH_CID : 7001005631303030380653B16A18A147 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C3000000 [eMMC] : FLASH_UCP : 7216 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Qphone ProdName : Q101 ProdModel : Q101 Device : Q101 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 [Read Ok] : preloader_vanzo82_cwet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6582 / V1.1.1 / vanzo82_cwet_kk / EMMC FW Size : 940 MiB Scatter saved to : C:\Users\gsmmithun\Desktop\MT6582__Qphone__Q101__Q101__4.4.2__ALPS.KK1.MP1.V2.10\ All done! Done! Elapsed: 00:04:17 Reconnect Power/Cable! smart av log Code: Operation : Remove Viruses [SmartAV] [ v1.39 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001005631303030380653B16A18A147 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 80001 [eMMC] : FLASH_CID : 7001005631303030380653B16A18A147 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C3000000 [eMMC] : FLASH_UCP : 7216 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 36 Removing infected files and scripts ... SmartAV Report : Removed 36 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #3 : PostFix Ok! Done! Done! Elapsed: 00:01:08 Reconnect Power/Cable! formate reset file log Code: Operation : Format FileSystem [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001005631303030380653B16A18A147 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 80001 [eMMC] : FLASH_CID : 7001005631303030380653B16A18A147 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C3000000 [eMMC] : FLASH_UCP : 7216 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following User Says Thank You to gsm_mithun For This Useful Post: |
