12-21-2016, 15:10 | #38596 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Anywhere
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 531 | Nokia 203 unlock done Code: Card found: S/N : 334FA6A3 , v0134 Registered to: said4 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - 203 Software ver : V 20.52 27-09-12 RM-832 (c) Nokia IMEI : 354605059023216 XappVer : 000008CA PPM : V 20.52 27-09-12 RM-832 (c) Nokia C CNT : Content: c_059N1V1 V 20.52 27-09-12 RM-832 (c) Nokia Product SN : 41F9B40BH Product code : 059P7S4 Base Prd.code: 059N238 Module code : 0205120 Long Prod.SN : 0 Hardware info======= HWID : 2000 Battery: 4184 mV CMT BT: 19b5-22012 LCDVer: TPO Lock info =========== IMEI : 354605059023216 IMEI spNet : 3A 45 06 05 95 20 23 01 IMEI svNet : 33 45 06 05 95 20 23 11 F4 Sl Conf : 228-02-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : 1BE83ACF0EFEB284 Country : Switzerland Operator : Sunrise Lock info: Block 1 L1:Close; Error collect lock info, try again CRT308 Backup Created CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Unlock procedure started... Using F-bus count... Sending code 791275653751518 Level : 7 to SimLock Server... Simlock Server Answer: Unlock code Accepted! :) Done! Reading Phone Info.... Connected phone - 203 Software ver : V 20.52 27-09-12 RM-832 (c) Nokia IMEI : 354605059023216 XappVer : 000008CA PPM : V 20.52 27-09-12 RM-832 (c) Nokia C CNT : Content: c_059N1V1 V 20.52 27-09-12 RM-832 (c) Nokia Product SN : 41F9B40BH Product code : 059P7S4 Base Prd.code: 059N238 Module code : 0205120 Long Prod.SN : 0 Hardware info======= HWID : 2000 Battery: 4184 mV CMT BT: 19b5-22012 LCDVer: TPO Lock info =========== IMEI : 354605059023216 IMEI spNet : 3A 45 06 05 95 20 23 01 IMEI svNet : 33 45 06 05 95 20 23 11 F4 Sl Conf : 228-02-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : 1BE83ACF0EFEB284 Country : Switzerland Operator : Sunrise Lock info: Block 1 L1:Open; Error collect lock info, try again CRT308 Backup Created CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to said4 For This Useful Post: |
12-21-2016, 16:30 | #38597 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Mobicel ICON Qualcomm MSM 8909 [ Read INFO, Read FIRMWARE + FRP ] Mobicel Icon Qualcomm MSM 8909, done by Chinese Miracle-2 QLM/Qualcomm v1.04. Here is logs : Code: Operation : Identify [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 064E6DFF ID_BLOCK_I : 009600E1 ID_BLOCK_L : 5BF3348E73E155B2 ID_BLOCK_L : C060A78CDBB2647E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : Mobicel ProdName : Mobicel_Icon ProdModel : Icon Device : Mobicel_Icon AndroidVer: 6.0.1 Manufact. : Mobicel QLMxCPU : MSM8909 Done! Elapsed: 00:00:06 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 064E6DFF ID_BLOCK_I : 009600E1 ID_BLOCK_L : 5BF3348E73E155B2 ID_BLOCK_L : C060A78CDBB2647E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : Mobicel ProdName : Mobicel_Icon ProdModel : Icon Device : Mobicel_Icon AndroidVer: 6.0.1 Manufact. : Mobicel QLMxCPU : MSM8909 DevInfo : MSM8909__Mobicel__Mobicel__ANDR_v6.0.1__Icon__Mobicel_Icon__Mobicel_Icon Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : splash.img [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : sensor.bin [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8909 / eMMC Firmware Size : 2226 MiB Done! Elapsed: 00:03:22 Code: Operation : Reset Settings [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 064E6DFF ID_BLOCK_I : 009600E1 ID_BLOCK_L : 5BF3348E73E155B2 ID_BLOCK_L : C060A78CDBB2647E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:35 Reconnect Power/Cable! Br, |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
12-21-2016, 19:03 | #38598 (permalink) |
Freak Poster Join Date: Aug 2011
Member: 1639426 Status: Offline Sonork: khurram136 Thanks Meter: 94 | htc d820mu write done cm2 htc d820mu flashing done cm2 Code: Scatter Load Ok , BaseBand : MT6592 , Project : lcsh92_cwet_kk , Storage : EMMC Files found : 13 , Set to Flash : 12 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : htc Device Model : htc_a31mg_dug Device CPU : MT6592 Device IntName : a31mg_dug_hTC_Asia_India Device Version : 4.4.2 Device Compile : 11/12/2014 5:32:05 AM Device Project : ALPS.KK1.MP1.V2.10 Device ExtInfo : HTC Desire 820mu dual sim Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:30 Reconnect Power/Cable! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:28 Reconnect Power/Cable! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 15010051375853414201D75AE6C4C123 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX7 [eMMC] : FLASH_CID : 15010051375853414201D75AE6C4C123 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xAC1CBD9A1DEE8A0B85494ED9401E55AE INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6592 , Project : lcsh92_cwet_kk , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3852 mV BL : BatteryLevel Ok SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_lcsh92_cwet_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : COTA Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:05:49 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : COTA Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:14 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:06:23 Reconnect Power/Cable! |
The Following User Says Thank You to khurram136 For This Useful Post: |
12-22-2016, 05:16 | #38599 (permalink) | |
Freak Poster Join Date: Aug 2006 Location: Kishtwar/Islamaabad j&k Age: 45
Member: 326228 Status: Offline Thanks Meter: 31 | Quote:
Sir i need that readed file i hava to flash that version on a mobile because i flashed with ver 207 now there are only lines on display Thankyou | |
12-22-2016, 06:52 | #38602 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Qmobile A290 Factory Reset Done Without Any Trouble By Great Cm2 |
The Following User Says Thank You to amn32 For This Useful Post: |
12-22-2016, 07:02 | #38607 (permalink) |
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Qmobile i7i Read Backup For Future Work Done So Easy By Amazing King CM2 |
The Following 2 Users Say Thank You to amn32 For This Useful Post: |
12-22-2016, 07:03 | #38608 (permalink) |
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Qmobile E11 Security Code Read Done Just Single Button Of Amazing Cm2 |
12-22-2016, 07:03 | #38609 (permalink) |
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Xtreme Voice V40 Contacts Data Extract Done So Easy By Amazing Cm2 |
12-22-2016, 07:07 | #38610 (permalink) |
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Qmobile K160 Read security code done so easy by great cm2 just single click |
