08-14-2017, 11:09 | #44266 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | 1ST IN INFINITY BOX MAI132 XIOMI REDMI 4x DONE WITH CM2:- READ PATTERN Code: Operation : Read PatternLock [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 6AB1A871 ID_BLOCK_I : 0006B0E1 ID_BLOCK_L : EDAA3915A7AE12454C00D0970BFB0334 ID_BLOCK_L : 7B85FF5699B0528877D6F3F681F52164 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RH64AB Boot Ok! Error : FS verification fail! Encrypted or damaged! Reconnect Power/Cable! Code: Operation : Reset Settings [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 6AB1A871 ID_BLOCK_I : 0006B0E1 ID_BLOCK_L : EDAA3915A7AE12454C00D0970BFB0334 ID_BLOCK_L : 7B85FF5699B0528877D6F3F681F52164 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RH64AB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:33 Reconnect Power/Cable! PHONE DONE WBR sahil2000ind |
The Following 2 Users Say Thank You to sahil2000ind For This Useful Post: |
08-14-2017, 13:05 | #44267 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung e1200y format done Code: Set mode to : SPD6530_SAMSUNG Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 00C0 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
08-14-2017, 13:07 | #44268 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | lava iris x1 grand flash done Code: Operation : Check / Read Info [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847326404050DA26BB5324D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A483847326404050DA26BB5324D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xC1F94A5C47204BF77E0A008631E8A8C4 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : iris ProdName : iris X1 Grand ProdModel : iris X1 Grand Device : X1 Grand AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.42 SECURITY : IMEI_SW [1] : 9114248538----- IMEI_SW [2] : 9114248538----- BTMAC Addr : 3C970EFB48DD WiFi MAC : 3C970EFE561E MODEM : BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V58_1_wg_n EXTRA : LCD [0] : otm8019a_fwvga_dsi_vdo_dijing LCD [1] : ili9806e_fwvga_dsi_vdo_txd LCD Res : 854x480 TOUCH [0] : ft6x36 TOUCH [1] : gt1x TOUCH [2] : msg2138a CAM [0] : gc2355mipi_raw CAM [1] : ov8865_mipi_raw CAM [2] : ov8865DL_mipi_raw MODEM : sprocomm82_we_kk_hspa_band18 LOCALE : en_US es_ES ru_RU zh_CN pt_BR fr_FR tr_TR in_ID ms_MY vi_VN ar_EG pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA da_DK fi_FI nb_NO sv_SE en_GB bn_BD bn_IN hi_IN ne_NP Done! Elapsed: 00:00:26 Reconnect Power/Cable! Operation : HW Test [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847326404050DA26BB5324D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A483847326404050DA26BB5324D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xC1F94A5C47204BF77E0A008631E8A8C4 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Processing] FlashMemory Read-Write test [eMMC] : [HYNIX] , d2G8 , 0x1D2000000 , 7456 MiB [eMMC] : CID : 90014A483847326404050DA26BB5324D [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! All Done! Done! Elapsed: 00:00:53 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6582 , Project : sprocomm6582_w_l , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.56 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847326404050DA26BB5324D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A483847326404050DA26BB5324D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xC1F94A5C47204BF77E0A008631E8A8C4 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : sprocomm6582_w_l , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3978 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x0000000083600000 Flash Pre-Erase Done, time used : 00:00:03 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_sprocomm6582_w_l.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:06 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:20 Reconnect Power/Cable! |
08-14-2017, 13:55 | #44269 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Samsung Org I9060I Hanging Probelam Fix Done With Great Infinity CM2 SM S/N: A19EC787 Version: 0100 Phone found on COM7 Phone In Download mode... Port open Ok! LOKE received! Prepare Ok! Enter Setup... Setup Done! Try download PIT... Download PIT Ok! Start flashing! Flashing spl.img Flashing sboot.bin Flashing sboot2.bin Flashing param.lfs Flashing boot.img Flashing recovery.img Flashing system.img Flashing SPRDCP.img Flashing SPRDDSP.img Flashing nvitem.bin Flashing cache.img Flashing hidden.img Flashing done Reboot phone... Phone Disconnected |
08-14-2017, 14:55 | #44270 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | coolpad note5 [3600I] read rom and format done Code: Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15 Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8952] ID_BLOCK_S : 01C71823 ID_BLOCK_I : 009720E1 ID_BLOCK_L : 23D76A45984336D62315F53E5C9B1DE4 ID_BLOCK_L : C78F65321FCD95F0D14BBFAC0B5DF9AC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8952 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX14MB Boot Ok! Error : Failed to read initial info! Erased/Damaged device??? Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8952] ID_BLOCK_S : 01C71823 ID_BLOCK_I : 009720E1 ID_BLOCK_L : 23D76A45984336D62315F53E5C9B1DE4 ID_BLOCK_L : C78F65321FCD95F0D14BBFAC0B5DF9AC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8952 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX14MB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8952] ID_BLOCK_S : 01C71823 ID_BLOCK_I : 009720E1 ID_BLOCK_L : 23D76A45984336D62315F53E5C9B1DE4 ID_BLOCK_L : C78F65321FCD95F0D14BBFAC0B5DF9AC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8952 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX14MB Boot Ok! Brand : Coolpad ProdName : CP3600I ProdModel : Coolpad 3600I Device : CP3600I AndroidVer: 6.0.1 Manufact. : YuLong QLMxCPU : MSM8952 DevInfo : MSM8952__YuLong__Coolpad__ANDR_v6.0.1__Coolpad_3600I__CP3600I__CP3600I Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : devcfg.mbn [Read Ok] : adspso.bin [Read Ok] : ddr.bin [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : param.cfg [Read Ok] : emmc_appsboot.mbn [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : cache.img [Read Ok] : persist.img [Read Ok] : misc.img [Read Ok] : lsplash.img [Read Ok] : mdtp.img [Read Ok] : cmnlib.mbn [Read Ok] : cmnlib64.mbn [Read Ok] : keymaster.mbn [Read Ok] : system.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8952 / eMMC Firmware Size : 3565 MiB Done! Elapsed: 00:15:45 Reconnect Power/Cable! Last edited by rehmani; 08-14-2017 at 15:02. |
08-14-2017, 15:05 | #44271 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Rivo S530 Read Firmware / Read User Code Done :) World First ! (bla bla .......etc) Code: Chinese Miracle II [RDA module] v 1.05 Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 6E076B01 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4009 CPU_CN : RDA Micro CT , RDA8851X ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 8809 , 00400000 Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! Read Flash now ... Read Ok, 4194304 bytes read Verify file... Target BbCpu : CT8851C Target Flash : flsh_spi32m Project Name : C41_RIVO_V02_0803 Project Info : 8851C_QVGA_X915 [BIN] Saved as : C41_RIVO_V02_0803_8851C_QVGA_X915_CT8851C_flsh_spi32m.bin Make FlashFiles FATNV Check passed FSCSC Check passed CALIB Check passed [IFF] File saved to : F:\1+Flashing Software\1+Infinity Box\CM2RDA\Flash\IFF\C41_RIVO_V02_0803_8851C_QVGA_X915_CT8851C_flsh_spi32m.iff [CAL] File saved to : F:\1+Flashing Software\1+Infinity Box\CM2RDA\Flash\IFF\C41_RIVO_V02_0803_8851C_QVGA_X915_CT8851C_flsh_spi32m.ifc Build done Done Elapsed: 00:00:49 Reconnect Power/Cable! Operation : Read User Code Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 6E076B01 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4009 CPU_CN : RDA Micro CT , RDA8851X ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 8809 , 00400000 Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! Read UDA now , wait ... Read done, sorting EXTData Following items found : Item : WAP_MM Item : CSW Item : VDS1 Item : NVRAM Required data found, extracting code UserCode : 7318 Elapsed: 00:00:17 Done Reconnect Power/Cable! |
08-14-2017, 15:15 | #44272 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Anywhere
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 531 | LENOVO IdeaTab format done Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BF1G4 [eMMC] : FLASH_CID : 1501004D3447314642036B7906A98F0D [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x4B1992B17898365D64B06123A3EC0BB8 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear RDP Clear Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
08-14-2017, 16:21 | #44273 (permalink) |
Freak Poster Join Date: May 2012 Location: Pakistan Panjab, Sahiwal
Member: 1758871 Status: Offline Sonork: Zaka Ullah Bhatti Thanks Meter: 144 | Rivo PZ38 flash file Read done Rivo PZ38 flash file Read Done CM2 -------------------------------------------------------------- Card found : S/N : DB1129A0 , v0135 Chinese Miracle II [MTK module] v 1.58 Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 1F01005345503430344A000007B453B5 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x1F , OEM : 0100 [eMMC] : FLASH_INF : [NOT_IN_BASE] , 404PE [eMMC] : FLASH_CID : 1F01005345503430344A000007B453B5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000EA000000 [eMMC] : FLASH_UCP : 3744 MiB [eMMC 4 GiB] DEV RID : 0xA3471DB2F8E7C9775886D15ABEF2216F INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : PZ38 ProdName : PZ38 ProdModel : PZ38 Device : PZ38 AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : S126AWG_S23_XBQ_FWVGA_V01.06.1137 [Read Ok] : preloader_hongyu6580_weg_l.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / hongyu6580_weg_l / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1129 MiB Scatter saved to : C:\Users\Bismillah\Desktop\MT6580__PZ38__PZ38__PZ3 8__5.1__S126AWG_S23_XBQ_FWVGA_V01.06.1137\ All done! Done! Elapsed: 00:07:05 Reconnect Power/Cable! --------------------------------------------------------- Zaka ullah bhatt i http://gsm-testedfile.********.com |
08-14-2017, 18:54 | #44274 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,770 | TECNO W3 FRP LOCK DONE BY CM2 Check / Read Info [ v1.58 ] Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464E58324D42062F95B226348B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM2XN [eMMC] : FLASH_CID : 150100464E58324D42062F95B226348B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xDEC55C37059744CF3BEBB4BB93C20A8B INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : TECNO ProdName : TECNO-W3 ProdModel : TECNO-W3 Device : TECNO-W3 AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : W3-H806A1-M-170222V112 SECURITY : IMEI_SW [1] : 357213089223786 IMEI_SW [2] : 357213089223794 BTMAC Addr : D47DFC5EAABC WiFi MAC : D47DFC5D85C4 MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V57_P5_1_wg_n EXTRA : LCD : Not info available :( LCD Res : 854x480 CAM [0] : hi545_mipi_raw CAM [1] : hi545_mipi_raw_dmegc CAM [2] : gc2355_mipi_raw MODEM : H806_A_BOM LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:12 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464E58324D42062F95B226348B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM2XN [eMMC] : FLASH_CID : 150100464E58324D42062F95B226348B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xDEC55C37059744CF3BEBB4BB93C20A8B INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
08-14-2017, 19:02 | #44275 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,770 | TECNO T371 READFLASH DONE BY CM2 Check / Read Info [ v1.58 ] Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 91 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : DE2E0C07E60A57A077537A5EFBA27EB0 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : DL255_T371_PCB01_gprs_MT6261_S00.T371-DL255A1-AF-170518V6.bin FileVersion : T371-DL255A1-AF-170518V6 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 91 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : DE2E0C07E60A57A077537A5EFBA27EB0 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : DL255_T371_PCB01_gprs_MT6261_S00.T371-DL255A1-AF-170518V6.bin FileVersion : T371-DL255A1-AF-170518V6 [ScatCFG] : MT6261 / T371-DL255A1-AF-170518V6 / NOR , SF Firmware saved to : C:\InfinityBox\CM2MTK\Read_out\DL255_T371_PCB01_gprs_MT6261_S00\ Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
08-15-2017, 06:42 | #44276 (permalink) |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 737 | tecno t350 read code read firmware done by cm2 Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 34 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 18B5F15F6ABFEFF2BB1A7F7864B72C87 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : DL180_T350_IR_PCB01_gprs_MT6261_S00.T350-DL180D1-AS-IR-170607V7.bin FileVersion : T350-DL180D1-AS-IR-170607V7 Done! Elapsed: 00:00:05 Reconnect Power/Cable! Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 34 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 18B5F15F6ABFEFF2BB1A7F7864B72C87 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 1236 PLock|MobTrack : Not active Done! Elapsed: 00:00:57 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 34 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 18B5F15F6ABFEFF2BB1A7F7864B72C87 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : DL180_T350_IR_PCB01_gprs_MT6261_S00.T350-DL180D1-AS-IR-170607V7.bin FileVersion : T350-DL180D1-AS-IR-170607V7 Saved to : F:\InfinityBox\CM2MTK\Read_out\DL180_T350_IR_PCB01_gprs_MT6261_S00.T350-DL180D1-AS-IR-170607V7.bin Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
08-15-2017, 08:32 | #44277 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile E4 Clicess MT6261 Read Code Done By Great Infinity CM2 Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 69 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 28F012C9964494EF174C27B0925F7724 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 3610 MobileTracker : 3610 , Privacy Lock : 3610 Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
08-15-2017, 09:40 | #44278 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Paris Age: 28
Member: 2483507 Status: Offline Thanks Meter: 81 | LG K350Z reset FRP Done Code: Infinity-Box LG Service Tool [ LGS ] v1.03 Operation : Reset Settings/Format FS [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! Format UserData Format Cache Format done Erase FRP#0 block Ok! Erase FRP#1 block Ok! Reconnect Power/Cable! Done! Elapsed: 00:00:50 |
08-15-2017, 09:50 | #44279 (permalink) |
Freak Poster Join Date: Apr 2016 Location: BEHIND OF YOUR GIRL FRIEND...
Member: 2559619 Status: Offline Sonork: 100.1672420 Thanks Meter: 205 | Samsung s7582 restart problem solve by flash with cm2 samsung module SAMSUNG S7582 RESTART PROBLEM SOLVE BY FLASH WITH CM2 SAMSUNG MODULE BR RIZU007 |
08-15-2017, 09:58 | #44280 (permalink) |
Member: 2559619 Status: Offline Sonork: 100.1672420 Thanks Meter: 205 | Samsung core 2 g355h hang on logo solve by flash with cm2 sam module SAMSUNG CORE 2 G355H HANG ON LOGO SOLVE BY FLASH WITH CM2 SAM MODULE BR RIZU007 |
The Following User Says Thank You to RIZU007 For This Useful Post: |
