09-10-2017, 15:15 | #44896 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile Power1 Format Done Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 75 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:07 Reconnect Power/Cable! |
09-10-2017, 17:35 | #44897 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Hum Aapke Dil Mein Age: 38
Member: 637860 Status: Offline Sonork: 100.1605309 Thanks Meter: 996 | Qmobile L15 Privacy Lock reset Done Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505071EA11A3572DB Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505071EA11A3572DB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xAC11BF7894B4E18EADFF5AF0A229024B INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Process block #1 Process block #2 Privacy Lock reset Ok! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
09-11-2017, 06:14 | #44898 (permalink) | ||
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile x30 read pattern lock done by cm2 and inferno tool failed QMOBILE X30 READ PATTERN LOCK DONE BY CM2 AND INFERNO TOOL FAILED Quote:
Read Phone Info Read Pattern Lock Quote:
Shahid | ||
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
09-11-2017, 07:42 | #44899 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | QMobile S2 Pro Read Factory File And Format Done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463832324D420087999A8963A7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM228 [eMMC] : FLASH_CID : 150100463832324D420087999A8963A7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xE6C52A7DD1C80CD8FB7A284F40E040B1 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:46 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463832324D420087999A8963A7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM228 [eMMC] : FLASH_CID : 150100463832324D420087999A8963A7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xE6C52A7DD1C80CD8FB7A284F40E040B1 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : QMobile ProdName : S2_Pro ProdModel : S2 Pro Device : S2_Pro AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : ALPS.W10.24.p0 [Read Ok] : preloader_p4200.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / p4200 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 2704 MiB Scatter saved to : H:\Smart Phones\Qmobile\MT6580__QMobile__S2_Pro__S2_Pro__6.0__ALPS.W10.24.p0\ All done! Done! Elapsed: 00:12:34 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
09-11-2017, 07:51 | #44900 (permalink) |
Freak Poster Join Date: Aug 2015 Location: Peace Age: 27
Member: 2441366 Status: Offline Sonork: Telegram: @FahadBoss10 Thanks Meter: 245 | Alcatel 4034A Network Unlock Done by CM2 Operation : SP Unlock [ v1.58 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464E31324D4206FC17EA268349 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM21N [eMMC] : FLASH_CID : 150100464E31324D4206FC17EA268349 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x5D9FA141E922137EF950925CCF5CF3C1 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SIM Lock Status : Locked! Unlocking now ... Unlock done! Done! Elapsed: 00:00:28 Reconnect Power/Cable! Br, Fahad Ahmad |
09-11-2017, 07:51 | #44901 (permalink) | |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Samsung clone j7220l hang on logo done by cm2 SAMSUNG CLONE J7220L HANG ON LOGO DONE BY CM2 Read Phone Info Full Factory Reset (All) Quote:
Shahid | |
09-11-2017, 08:04 | #44902 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Rivo 290 MT6261 Read Code Done By Flashing With Infinity CM2 Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 38 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 94C628DA459E7F46752288E65E57ABF6 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DF , [WINBOND] W25Q64DW [0] : FLASH_DIE : 00EF 0060 0017 0000 [0] : FLASH_LEN : 0x00800000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 1234 PLock|MobTrack : Not active Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
09-11-2017, 08:08 | #44903 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | intex force zx format done Code: Set mode to : SPD6531 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Device boot not done Check Drivers Try again Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 11 ] Open Port Failed! Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Read FullFlash [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Set FileInfo : Model Vendor : intex Model Name : force zx Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_W25Q32__intex-force zx.bin Done! Elapsed: 00:00:59 Reconnect Power/Cable! |
09-11-2017, 08:43 | #44904 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | RIVO RHYTHM RX200 FullFlash Done Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6582 , Project : a3566 , Storage : EMMC Files found : 12 , Set to Flash : 11 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 50 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100513832534D4200E671E003620F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS28 [eMMC] : FLASH_CID : 150100513832534D4200E671E003620F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xE6C52A7D5BA7D6F922020EB79C444817 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : a3566 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 4150 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000480000 Erase : 0x0000000002C80000-0x0000000101080000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0014 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:05:40 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:06:01 Reconnect Power/Cable! |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
09-11-2017, 08:59 | #44905 (permalink) |
No Life Poster Join Date: Dec 2012 Location: Khushab Punjab Pakistan
Member: 1857951 Status: Offline Sonork: 100.1638512 Thanks Meter: 261 | Lenovo A319 Flashing done with cm2 by .::Mustafa::. Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 227 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344732611101DBF0081972EF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611101DBF0081972EF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xC3555188930F4F98BCBB8B3C100837F0 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3872 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:00 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_huaqin72_cwet_1a_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:04:03 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:01:07 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:05:48 Reconnect Power/Cable! |
09-11-2017, 10:50 | #44906 (permalink) |
Freak Poster Join Date: Mar 2009 Location: MUMBAI Age: 35
Member: 987290 Status: Offline Sonork: 100.1653649 Thanks Meter: 48 | Nokia 3 frp reset done Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 4400014531303446159E0136192CB2A0 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 6104F [eMMC] : FLASH_CID : 450100444634303136019E15A0B2C319 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xA0C6537563ACA2BABFB64B8D58C3F76F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to GSM_IMRAN For This Useful Post: |
09-11-2017, 10:51 | #44907 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile M350 MT6580 FRP Reset Done 1 Click With Phardo Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463732324D42006A6ED3F663ED Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D42006A6ED3F663ED [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F395516FA2680EC8C0E1E74B263A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:59 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
09-11-2017, 11:37 | #44908 (permalink) |
Junior Member Join Date: Oct 2011 Location: Pakistan ..Punjab ..Bhakkar Age: 42
Member: 1678762 Status: Offline Thanks Meter: 0 | i6 METAL 2017 FRP SOULATION????? CM 2 INFO Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:24 Reconnect Power/Cable! |
09-11-2017, 12:00 | #44909 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung s7582 flash done Code: Phone found on COM16 Phone In Download mode... Port open Ok! LOKE received! Prepare Ok! Enter Setup... Setup Done! Try download PIT... Download PIT Ok! Start flashing! Flashing boot.img Flashing recovery.img Flashing dt-blob Flashing BcmCP.img Flashing cache.img Flashing hidden.img Flashing system.img Flashing param.lfs Flashing done Reboot phone... Phone Disconnected |
09-11-2017, 12:38 | #44910 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Mi2 2014818 MIUI 9 Mi Acc remove done Code: Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 13344186 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 03E59F67D65C49442318F8E52279F9D1 ID_BLOCK_L : EF662883741F4FC4F93499565C534D8E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : Xiaomi ProdName : wt88047 ProdModel : wt88047 Device : wt88047 AndroidVer: 5.1.1 Manufact. : Xiaomi SysPatch : LMY47V DevComTime: 06-09-2017 PM 5:52:03 QLMxCPU : MSM8916 USERData : NORMAL GCSec : NORMAL Done! Elapsed: 00:00:15 Reconnect Power/Cable! Code: Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 13344186 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 03E59F67D65C49442318F8E52279F9D1 ID_BLOCK_L : EF662883741F4FC4F93499565C534D8E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! MIAccount reset passed! Complete reset : > If device lock after WiFi - use RESET MI APP > PowerOn device, NOT power WiFi, SIM and etc. Make device setup > Reset MI APP. Device will not have MIServices anymore Done! Elapsed: 00:00:24 Reconnect Power/Cable! Code: Operation : Flash [ v1.15 ] ForceFlashing : Disabled Verify FW package ... Error : Firmware NOT selected! Nothing to do! Reconnect Power/Cable! Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 13344186 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 03E59F67D65C49442318F8E52279F9D1 ID_BLOCK_L : EF662883741F4FC4F93499565C534D8E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : Xiaomi ProdName : wt88047 ProdModel : wt88047 Device : wt88047 AndroidVer: 5.1.1 Manufact. : Xiaomi QLMxCPU : MSM8916 DevInfo : MSM8916__Xiaomi__Xiaomi__ANDR_v5.1.1__wt88047__wt88047__wt88047 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : misc.img [Read Ok] : splash.img [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : persist.img [Read Ok] : recovery.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8916 / eMMC Firmware Size : 1244 MiB Done! Elapsed: 00:02:44 Reconnect Power/Cable! |
