Old 10-21-2017, 06:58   #45676 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
LENOVO TAB T2 A7-10F PATTERN LOCK REMOVE Done
SUCCESSFULLY REMOVE PATTERN LOCK(LENOVO TAB T2 A7-10F)USB
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 35 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8127
BB_CPU_NME : [MediaTek] MT8127_S00
BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8D
NAND Flash : NOT INSTALLED
eMMC Flash : 15010038575044335200C0BDF802A241
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , R3DPW
[eMMC] : FLASH_CID : 15010038575044335200C0BDF802A241
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xFD096D459CAA24C99E0B7AF0C651EBCA
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : Lenovo
ProdName : Tab2A7-10F
ProdModel : Tab2A7-10F
Device : Tab2A7-10F
AndroidVer: 4.4.2
MTKxCPU : MT8127
MTKxPRJ : T2-A7-10F_S000044_150811_ROW
SECURITY :
BTMAC Addr : XXXXXXXXXXX
WiFi MAC : XXXXXXXXXX
Done!
Elapsed: 00:00:09
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 35 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8127
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:32
THANKS INFINITY-BOX TEAM
The Following 2 Users Say Thank You to gracy_elec For This Useful Post:
Old 10-21-2017, 07:01   #45677 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Huawei Y220 MT6572 NAND Restart Probelam Fix Only Formate With Infinity CM2
Wait for phone...
Phone found! [ 37 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
NAND Flash : 00AD00BC00900055005600AD00BC0000
eMMC Flash : NOT INSTALLED
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x00A4 , [Hynix] H9DA4VH2GJMMCR_4EM
[NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2
DEV RID : 0xD9C8F39514D0808FA7869080E77225ED
EXT RAM : 0x10000000 [256 MiB]
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:15
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 10-21-2017, 07:06   #45678 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
MI REDMI 4X PATTERN LOCK REMOVE Done
SUCCESSFULLY REMOVE PATTERN LOCK (MI REDMI 4X)USB
Operation : Identify [ v1.15 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 435 [MSM8940]
ID_BLOCK_S : A9D1668A
ID_BLOCK_I : 0006B0E1
ID_BLOCK_L : 84CD5E7CC0C7096C657FC9BC10827A5D
ID_BLOCK_L : 9B651FB6795072A85736D3D6A115C184
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RH64AB
Boot Ok!
Brand : Xiaomi
ProdName : santoni
ProdModel : Redmi 4X
Device : santoni
AndroidVer: 6.0.1
Manufact. : Xiaomi
SysPatch : MMB29M
QLMxCPU : MSM8937
Done!
Elapsed: 00:00:08
Operation : Reset Settings [ v1.15 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:27
The Following 3 Users Say Thank You to gracy_elec For This Useful Post:
Old 10-21-2017, 07:31   #45679 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobilw X2 Music SPD7715 NAND Logo Stuck Recover Done Only Formate With Infinity CM2
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 23 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7715 Loader NAND v1.1 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected NAND Flash , Structure detect Ok!
Formatting NAND Flash
Format UserData
Format Ok!
Format Cache
Format Ok!
Done!
Elapsed: 00:00:24
Old 10-21-2017, 07:34   #45680 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile I6 Metal 1 SPD77xx Pattren Reset Done With King Infinity CM2
Set mode to : SP [SC773x] eMMC [Android 5.x]
Set mode to : SP [SC773x] eMMC [Android 6.x]
Set mode to : [AltLDR] SP [SC773x] eMMC [Android 6.x]
3. Insert cable
Phone found! [ 23 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v1.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:24
Old 10-21-2017, 07:44   #45681 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile R400 MT6261 Read code Done With King Infinity CM2
Card found : S/N : A19EC787 , v0136
Operation : Read UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 16 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 117D5722591E3CEF148C00A8E4DB9CF8
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 1144
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:10
Old 10-21-2017, 07:56   #45682 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile L7 SPD6531 Illagel Use Fix Only Formate With King Infinity CM2
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:11
Old 10-21-2017, 08:06   #45683 (permalink)
monusah25's Avatar
Member: 2650572
Sonork: 100.107126
Thanks Meter: 151
Smile Lenovo Vibe C (A2020) FRP Remove Done With GREAT Cm2
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 210 [MSM8x09]
ID_BLOCK_S : 09AA14CD
ID_BLOCK_I : 009600E1
ID_BLOCK_L : DA2A40BE1985B2BD6ADF311ED9A03018
ID_BLOCK_L : 611CA20D0E91394A4FAEE3D82AC5D3F8
Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
Boot Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:27
The Following User Says Thank You to monusah25 For This Useful Post:
Old 10-21-2017, 08:15   #45684 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
QMobile L1 Classic factory reset Done :)
Set mode to : SPD6531
Operation : Check/Read Info [ v1.25 ]
3. Insert battery
Phone found! [ 52 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
Elapsed: 00:00:03
Operation : Read FullFlash [ v1.25 ]
3. Insert battery
Phone found! [ 52 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Read Flash Content
Read Ok , collect info
Set FileInfo :
Model Vendor : q
Model Name   : L1 classic
Saved to : F:\1+Flashing Software\1+Infinity Box\CM2SPD\Read_out\SPD6531_00400000_W25Q32__q-L1 classic.bin
Done!
Elapsed: 00:00:35
Operation : Format File System / Reset Settings [ v1.25 ]
3. Insert battery
Phone found! [ 52 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:06
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 10-21-2017, 08:48   #45685 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
MICROMAX Q332 FRP REMOVE Done
SUCCESSFULLY REMOVE FRP (MICROMAX Q332)USB
Wait for phone...
Phone found! [ 49 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 90014A48344732611101AF549035426F
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x20000000
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A48344732611101AF549035426F
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xFD096D45C79564C9D0F97D8382B2FB8E
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
Brand : Micromax
ProdName : Q332
ProdModel : Micromax Q332
Device : Q332
AndroidVer: 5.1
MTKxCPU : MT6580
MTKxPRJ : ALPS.L1.MP6.V2_LCSH6580.WE.L_P59
SECURITY :
IMEI_SW [1] : XXXXXXXXXXXXX
IMEI_SW [2] : XXXXXXXXXXXXX
MODEM :
BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_P5_1_wg_n
EXTRA :
LCD : Not info available
LCD Res : 854x480
TOUCH [0] : mstar2xxx####
TOUCH [1] : mstar2238
CAM [0] : ov2680_mipi_raw
CAM [1] : ov5670_mipi_raw
CAM [2] : hi542_mipi_raw
CAM [3] : hi542sub_mipi_raw
MODEM : lcsh_6580_we_l_hspa_3gb1b8_mcx_v4
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:17
Wait for phone...
Phone found! [ 49 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:37
Old 10-21-2017, 10:17   #45686 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
LENOVO A6000 BLUE SCREEN RECOVER Done
SUCCESSFULLY RECOVER BLUE SCREEN(LENOVO A6000)USB
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 0D56E1C6
ID_BLOCK_I : 007050E1
ID_BLOCK_L : C3255FA7169C898463D83825E2B93911
ID_BLOCK_L : 0D40CE6152FD6DE61BDABF747EB1AFAC
Pickup loader from firmware package
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Brand : Lenovo
ProdName : Kraft-A6000
ProdModel : Lenovo A6000
Device : Kraft-A6000
AndroidVer: 4.4.4
Manufact. : LENOVO
SysPatch : KTU84P
QLMxCPU : MSM8916
Done!
Elapsed: 00:00:10
Operation : Flash [ v1.15 ]
ForceFlashing : Disabled
Verify FW package ...
Verification passed!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Flash Chain : 112
Flashing now
Flashing : NON-HLOS.bin
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : emmc_appsboot.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : hyp.mbn
Flashing : hyp.mbn
Flashing : splash.img
Flashing : sec.dat
Flashing : boot.img
Flashing : system_1.img
Flashing : system_2.img
Flashing : system_3.img
Flashing : system_4.img
Flashing : system_5.img
Flashing : system_6.img
Flashing : system_7.img
Flashing : system_8.img
Flashing : system_9.img
Flashing : system_10.img
Flashing : system_11.img
Flashing : system_12.img
Flashing : system_13.img
Flashing : system_14.img
Flashing : system_15.img
Flashing : system_16.img
Flashing : system_17.img
Flashing : system_18.img
Flashing : system_19.img
Flashing : system_20.img
Flashing : system_21.img
Flashing : system_22.img
Flashing : system_23.img
Flashing : system_24.img
Flashing : system_25.img
Flashing : system_26.img
Flashing : system_27.img
Flashing : system_28.img
Flashing : system_29.img
Flashing : system_30.img
Flashing : persist_1.img
Flashing : cache_1.img
Flashing : cache_2.img
Flashing : cache_3.img
Flashing : cache_4.img
Flashing : cache_5.img
Flashing : recovery.img
Flashing : userdata_1.img
Flashing : userdata_2.img
Flashing : userdata_3.img
Flashing : userdata_4.img
Flashing : userdata_5.img
Flashing : userdata_6.img
Flashing : userdata_7.img
Flashing : userdata_8.img
Flashing : userdata_9.img
Flashing : userdata_10.img
Flashing : userdata_11.img
Flashing : userdata_12.img
Flashing : userdata_13.img
Flashing : userdata_14.img
Flashing : userdata_15.img
Flashing : userdata_16.img
Flashing : userdata_17.img
Flashing : userdata_18.img
Flashing : userdata_19.img
Flashing : userdata_20.img
Flashing : userdata_21.img
Flashing : userdata_22.img
Flashing : userdata_23.img
Flashing : userdata_24.img
Flashing : userdata_25.img
Flashing : userdata_26.img
Flashing : userdata_27.img
Flashing : userdata_28.img
Flashing : userdata_29.img
Flashing : userdata_30.img
Flashing : userdata_31.img
Flashing : userdata_32.img
Flashing : userdata_33.img
Flashing : userdata_34.img
Flashing : userdata_35.img
Flashing : userdata_36.img
Flashing : userdata_37.img
Flashing : userdata_38.img
Flashing : userdata_39.img
Flashing : userdata_40.img
Flashing : userdata_41.img
Flashing : userdata_42.img
Flashing : userdata_43.img
Flashing : userdata_44.img
Flashing : userdata_45.img
Flashing : userdata_46.img
Flashing : userdata_47.img
Flashing : gpt_main0.bin
Flashing : gpt_backup0.bin
Flash sequence completed!
Applying patches for storage # 0
Records : 26
Patch sequence completed!
BootConfig set to 0x00
Flashing done!
Done!
Elapsed: 00:06:34
Old 10-21-2017, 10:53   #45687 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile Xl40 MT6261 Read code Done With Great Infinity CM2
Wait for phone...
Phone found! [ 16 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : 53E225E660AB35A050CC811E23CC8F72
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 0852
Done!
Elapsed: 00:00:07
Old 10-21-2017, 11:00   #45688 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile X25 MT6572 Logo Hang Recover Done By Flashinh With Infinity CM2
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4834473164040501A19D5681AB
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040501A19D5681AB
DEV RID : 0xD9C8F3958B8BC4D9972557DBFD63D717
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:26
Old 10-21-2017, 12:16   #45689 (permalink)
NadeemSandhu1's Avatar
Member: 2077858
Thanks Meter: 128
Huawei y336-u02 repair imei done
Set mode to : SP [SC8830] NAND [Generic]
Operation : Repair Security [ v1.27 ]
2. Insert cable
3. In case of SVC init problems - connect with hold "VolDown" button!
Phone found! [ 7 ]
Port Opened
Sync...
InitSvc Done
Wait for phone...
Sync...
Phone Initial Info :
Platform : MOCORTM_14B_TSHARK28_HUAWEI_W15.19_P1_Debug
Project : sc7731g_CP0_modem
HWInfo : sc7731g_CP0_modem
Compile : 05-06-2015 20:18:45
Phone Security Info :
IMEI [1] : 80000000000614
IMEI [2] : 00000000000014
BT_ADDR : 000000000000
Read Ok!
Write new security data :
IMEI1 : 354967459874568
IMEI2 : 354984785984680
Write done!
Elapsed: 00:00:28
The Following User Says Thank You to NadeemSandhu1 For This Useful Post:
Old 10-21-2017, 12:40   #45690 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
SAMSUNG E1200Y USER LOCK REMOVE Done
SUCCESSFULLY REMOVE USER LOCK(SAMSUNG E1200Y)USB
Operation : Check/Read Info [ v1.27 ]
3. Insert battery
Phone found! [ 44 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
CPU ID : 6530 , FDLStat : 00C0
[0] Flash DIE : 00C8 0060 0017 0000
[0] Flash VEN : GigaDevice , GD25LQ64
[0] Flash CAP : 00800000
Elapsed: 00:00:09
3. Insert battery
Phone found! [ 44 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:14
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.89915 seconds with 10 queries
