03-16-2019, 10:11 | #57526 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I2 SPD77XX Dead Set Alive Done By Flashing With King Infinity CM2 Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : QMobile_i2_MP_11_03.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : QMobile_i2_MP_11_03 File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : LOGO.bmp File : charge.bmp File : prodnv.img File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 41 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : NVM Update Current ID : NV_W Current Part : wfixnv1 [FlashProc] : Ok! [FlashProc] : NVM Update Current ID : NV_WCN Current Part : wcnfixnv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC7702_sc7731g_band128.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_G2.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : SC8800G_x30g_wcn_dts_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : LOGO.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : charge.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:06:49 Reconnect Power/Cable! |
03-16-2019, 10:25 | #57527 (permalink) |
Freak Poster Join Date: Jan 2012 Location: Sylhet Korim Ullah Market Age: 28
Member: 1714226 Status: Offline Sonork: 100.1683394 Thanks Meter: 243 | G-TAB P7072G mt6572 User lock reset done by cm2 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 150100385750443352000A05B471147B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , R3DPW [eMMC] : FLASH_CID : 150100385750443352000A05B471147B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x09E7E732D5142F428A618A95CA48F2DD INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSGS Ok! LSSDB Ok! LSSWL Ok! LSSSH Ok! LSSKY Ok! Security Settings : Clear Ok! [Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button! [Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset! [Info] : If phone stuck on "Logo" : 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
The Following User Says Thank You to rubelgsm For This Useful Post: |
03-16-2019, 13:11 | #57528 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | VIVO Y91I 1816 AND:8.1.0 MT6765 READ NVRAM BAG BRUSH PATTERN & FRP Done SUCCESSFULLY READ NVRAM BAG BRUSH PATTERN LOCK & FRP(VIVO Y91I 1816 AND:8.1.0 MT6765)USB THANKS INFINITY-BOX TEAM |
The Following 5 Users Say Thank You to gracy_elec For This Useful Post: |
03-16-2019, 13:57 | #57529 (permalink) |
Freak Poster Join Date: Aug 2015 Location: karachi
Member: 2451024 Status: Offline Sonork: 100.1670074 Thanks Meter: 16 | Nokia 3310 TA-1022 Card found : 36AD2680 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.10 Operation : Reset Settings ( Format FS ) [ v1.10 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! Erase BLK #0 Erase BLK #1 Erase BLK #2 Erase BLK #3 Format Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to KHALIDAKA For This Useful Post: |
03-16-2019, 14:32 | #57530 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Nokia TA-1006 SPD Pin Reset Done With King Infinity CM2 Card found : 8C25B0A1 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.10 Operation : Reset Settings ( Format FS ) [ v1.10 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Reset Settings ( Format FS ) [ v1.10 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! Erase BLK #0 Erase BLK #1 Erase BLK #2 Erase BLK #3 Format Ok! Done! Elapsed: 00:02:34 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to azhergoga007 For This Useful Post: |
03-16-2019, 15:09 | #57531 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile M95 SPD77XX Logo Stuck Fix Only Flash With King Infinity CM2 Card found: S/N : A19EC787 , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0] Loading : last.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7730_UMS PacVersion : m95 FastCheck : 0x005360DB6E Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128_SC2662H.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system File : userdata.img File : hong1.bmp File : hd720_kpoc_charge.bmp File : cache.img File : u-boot.bin File : SC7730_UMS.xml Load Ok! Operation : Flash [ v1.27 ] Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : last.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7730_UMS PacVersion : m95 File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128_SC2662H.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system File : userdata.img File : hong1.bmp File : hd720_kpoc_charge.bmp File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 41 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC7702_sc7731g_band128_SC2662H.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_G2.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : SC8800G_x30g_wcn_dts_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : hong1.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : hd720_kpoc_charge.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:04:57 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
03-16-2019, 15:40 | #57532 (permalink) |
Freak Poster Join Date: Aug 2016 Location: Karachi (PAKISTAN)
Member: 2609063 Status: Offline Thanks Meter: 103 | Qtab V2 2018 CM2 RKT Frp one click Card found : 58544BD9 , v0137 Infinity-Box RockChip Service Tool [RKT] v2.01 Operation : Identify [ v2.01 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : Normal [ LOADER OPEN ] SoC CPU : 312A Flash CSx : 0x00 Flash Type : 2C64643CA5 [ NAND ] Flash Vend : MICRON Flash Size : 0x000000020A000000 ( 8.16 GiB ) Flash Info : 8388608/16384/32/40/1 Connect Ok! Brand : QTab ProdName : QTab_V2_2018 ProdModel : V2 2018 Device : V2_2018 AndroidVer: 8.1.0 Manufact. : Qmobile SysPatch : OPM6.171019.030.E1 RKTxPRJ : QTab_V2_2018_V1.7_2018-08-31 Done! Elapsed: 00:00:05 --------------------------------------------------------- Card found : 58544BD9 , v0137 Infinity-Box RockChip Service Tool [RKT] v2.01 Operation : Reset Settings [ v2.01 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : Normal [ LOADER OPEN ] SoC CPU : 312A Flash CSx : 0x00 Flash Type : 2C64643CA5 [ NAND ] Flash Vend : MICRON Flash Size : 0x000000020A000000 ( 8.16 GiB ) Flash Info : 8388608/16384/32/40/1 Connect Ok! Remove FRP 0 ... FRP removed! Wiping UserData ... Wipe DATA Ok! Done! Elapsed: 00:00:10 |
The Following 2 Users Say Thank You to babarmughal For This Useful Post: |
03-17-2019, 00:39 | #57533 (permalink) |
Freak Poster Join Date: Aug 2017 Location: Ukraine
Member: 2750401 Status: Offline Thanks Meter: 134 | Clear FRP ZP920+ done 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6752 BB_CPU_NME : [MediaTek] MT6732|MT6752_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8F NAND Flash : NOT INSTALLED eMMC Flash : 150100523832314D4200BAD9EC37C139 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D4200BAD9EC37C139 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x55922AFD2D453845E3A6AB9D72FA5CFE INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
03-17-2019, 00:41 | #57534 (permalink) |
Member: 2750401 Status: Offline Thanks Meter: 134 | bravis_A553 frp done 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : E5011230313130303010F1020E0464F7 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xE5 , OEM : 0112 [eMMC] : FLASH_INF : [NOT_IN_BASE] , 00011 [eMMC] : FLASH_CID : E5011230313130303010F1020E0464F7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D4400000 [eMMC] : FLASH_UCP : 7492 MiB [eMMC 8 GiB] DEV RID : 0x55922AFDAC81416BD4575962427C1940 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
03-17-2019, 06:01 | #57535 (permalink) |
Member: 1714226 Status: Offline Sonork: 100.1683394 Thanks Meter: 243 | IKON IK-800W User Lock Reset Done Boy CM2 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D4330344702069C859E1083 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E2C00000 [eMMC] : FLASH_UCP : 3628 MiB [eMMC 4 GiB] DEV RID : 0x09E7E732C105DD5E6D6ABD817F4EC0FC INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSDB Ok! LSSWL Ok! LSSSH Ok! LSSGS Ok! Security Settings : Clear Ok! [Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button! [Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset! [Info] : If phone stuck on "Logo" : 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
03-17-2019, 07:12 | #57536 (permalink) |
Member: 953334 Status: Online Sonork: 100.1614005 Thanks Meter: 15,428 | Vgotel i255 Flash Done Operation : Flash [ v1.58 ] ======= Flash Files set for flashing : [ MCU ] : FISE61M_11C_PCB01_GSM_MT6261_S00.MAUI_11C_W13_52_M P_V2_F15.BIN.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 69 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : F11F7F40E7193DC29176C9A060118172 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : FISE61M_11C_PCB01_gsm_MT6261_S00.MAUI_11C_W13_52_M P_V2_F15.bin FileVersion : MAUI.11C.W13.52.MP.V2.F15 Flash now Erase region , wait ... Write data , wait ... Write : FISE61M_11C_PCB01_GSM_MT6261_S00.MAUI_11C_W13_52_M P_V2_F15.BIN.bin Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
03-17-2019, 07:27 | #57537 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile A300 MT6572 Hanging Probelm Fix Only Formate With King Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 258 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048601A36718417F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A36718417F [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395A1D2CB077219FF7313E08FDB INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
03-17-2019, 08:08 | #57538 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile X32 V2 SPD7731 FRP Reset Done With King Infinity CM2 Card found: S/N : A19EC787 , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 41 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000012ABF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
03-17-2019, 08:23 | #57539 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile Power R1000 SPD6531 Pin Reset Done With King Infinity CM2 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 41 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
03-17-2019, 09:57 | #57540 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile S1 Pro MT6580 FRP Reset Done With King Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 258 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463732324D420051ACCE8C539D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D420051ACCE8C539D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F395E4349E5D4089E62F585EDB18 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
