01-22-2020, 12:49 | #62131 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | Lenovo A319 Flash Code: Brand : Lenovo ProdName : A319 ProdModel : Lenovo A319 Device : A319 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : A319_ROW_DS_S313_150427 Done! Elapsed: 00:00:13 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040503A29D4122B9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A29D4122B9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C253A7970FBEE20E8A868809E2A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3728 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x0000000094840000 Flash Pre-Erase Done, time used : 00:00:03 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:04:34 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:53 Reconnect Power/Cable! |
01-22-2020, 12:50 | #62132 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | DANY-*******4G Frp Code: Model Name : sg7067ka Model Brand : SPRD Model Device: sp9832a_2h11 AndrVersion : 7.0 BaseBand CPU: SP9832A_2H11_VOLTE CompileDate : 8/3/2019 1:30:57 AM Project Ver : DANY-*******4GXX-20180627-V Model Ext : SP9832A ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:36 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 15 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9832 eMMC LoaderV1 (c) Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000031E9F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:01:11 Reconnect Power/Cable! |
01-22-2020, 12:53 | #62133 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | Nokia 1 Hang Format Code: Brand : Nokia ProdName : Frontier_00WW ProdModel : Nokia 1 Device : FRT AndroidVer: 8.1.0 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 484A0190613447385119A532931F7D48 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4G8 [eMMC] : FLASH_CID : 90014A483847346132A51951487D3593 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD5229C2531E3B5F6901971EE9173247B INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
01-22-2020, 13:43 | #62135 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Call me c785 hang on logo done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v1.1 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : IMEI[2] : Done! Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Format FileSystem [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v1.1 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_146 E9CE685D5_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
01-22-2020, 14:17 | #62136 (permalink) |
No Life Poster Join Date: Feb 2011 Location: ( United States Of Islam ) Age: 35
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | WIKO__JERRY_ FLASH DON Code: Card found : CE90936C , v0139 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.04 Load IDBase v1119 Ok! VER : BP_R1.0.0 LEN : 8D1E86E7 CPU : SC77xx VER : V2806AN_6.0_WIK_FR_18 Operation : Identify [ v2.04 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : rom.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... ProtoEx : : TRCC not supported! FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : MRA58K release-keys Ver. Incmt : 134 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-12-05 Build Time : 1487865723 Product Board : v2806 Board Platform : sc8830 Product Info : v2806 Product Model : JERRY Product Brand : WIKO Product Name : v2806 Product Device : v2806 Product Manfct : WIKO Update DataBase ... Platform Version: MOCORTM_14B_7731C_W16.xx.x_Debug Project Version: sc7731C_CP0_modem BASE Version: TM_BASE_W16.xx.x MMI Version: sc7731C_modem HW Version: sc7731C_CP0_modem CMP_Time : 07-04-2016 13:42:20 MODEM TAG : MOCORTM_14B_7731C_W16.xx.x_Debug_TM_BASE_W16.xx.x_sc7731C_CP0_modem_sc7731C_CP0_modem_sc7731C_modem UserData : STATE : PLAIN Done! Elapsed: 00:01:11 Operation : Read FW [ v2.04 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Read FW [ v2.04 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : rom.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... ProtoEx : : TRCC not supported! FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : MRA58K release-keys Ver. Incmt : 134 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-12-05 Build Time : 1487865723 Product Board : v2806 Board Platform : sc8830 Product Info : v2806 Product Model : JERRY Product Brand : WIKO Product Name : v2806 Product Device : v2806 Product Manfct : WIKO AndroidVer : 6 VlnrLevel : 0x01 SC8830__WIKO__JERRY__6.0__MRA58K__v2806 Read : prodnv.img ExtSparse : Compression ratio : 21% Read : phase.cfg Read : wmodem.bin Read : wdsp.bin Read : wnvitem.bin Read : modem_wcn.img Read : wcnnvitem.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Read : boot.img Read : system.img ExtSparse : Compression ratio : 97% Make : persist.img Read : sysinfo.bin ExtSparse : Compression ratio : 10% Make : cache.img Read : recovery.img Make : userdata.img Read : u-boot.bin Read : u-boot-spl.bin Firmware size : 0x88857250 ( 2.13 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:10:39 Open : rom.pac VER : BP_R1.0.0 LEN : 0x8D1E86E7 CPU : SC77xx VER : V2806AN_6.0_WIK_FR_18 Reading package ... Read package finished! Patch Level : MRA58K Display ID : MRA58K release-keys Ver. Incmt : 151 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2017-05-05 Build Time : 1513865869 Product Board : v2806 Board Platform : sc8830 Product Info : v2806 Product Model : JERRY Product Brand : WIKO Product Name : v2806 Product Device : v2806 Product Manfct : WIKO Operation : Flash Firmware [ v2.04 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : rom.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x17 PMTMng : Update PMT Ok! CODE : prodnv.img ERASE : UBOOT UBOOT : u-boot-spl-16k.bin CODE : SC7702_pike_modem_AndroidM.dat CODE : DSP_DM_G2.bin CODE : SC8800G_pike_wcn_dts_modem.bin CODE : boot.img CODE : recovery.img FSIMG : system.img FSIMG : userdata.img CODE : boot_logo.bmp CODE : fastboot_logo.bmp ERASE : WRUNTIMENV1 ERASE : WCNRUNTIMENV1 FSIMG : cache.img ERASE : MISC FSIMG : persist.img CODE : sysinfo.img UBOOT : u-boot.bin Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:04:34 |
01-22-2020, 14:27 | #62137 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile d10 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : C1254F041E52EF9CE8D8990F47728A3B BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
01-22-2020, 18:09 | #62138 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Redmi Note 3 Code: Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 652 [MSM8976] ID_BLOCK_S : 010CE310 ID_BLOCK_L : 0E4BD8F6464DB3E6EFE14F36AA18E0D7 ID_BLOCK_L : D4205AF93C1F37E7906BA89BE4529EC3 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : BJNB4R Boot Ok! Flash Chain : 48 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : adspso.bin Flashing : sec.dat Flashing : splash.img Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : boot.img Flashing : recovery.img Flashing : system.img Flashing : cache.img Flashing : persist.img Flashing : misc.img Flashing : mdtp.img Flashing : cust.img Flashing : cmnlib.mbn Flashing : keymaster.mbn Flashing : cmnlib.mbn Flashing : keymaster.mbn Flashing : userdata.img Flashing : gpt_backup0.bin Wipe data ... BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:02:49 Reconnect Power/Cable! |
01-22-2020, 20:01 | #62139 (permalink) |
Freak Poster Join Date: Feb 2015 Location: Dominican Republic
Member: 2342599 Status: Offline Thanks Meter: 98 | Epik K501 Plus 8.1 FRP Done By CM2SP2 Selected PCD PH4003 GO and connected keeping vol- Card found : AA747CDA , v0138 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.03 Load IDBase v10107 Ok! Operation : Format FS / Reset Settings [ v2.03 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : PCD : PH4003 GO Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:46 |
The Following User Says Thank You to starlyn1232 For This Useful Post: |
01-23-2020, 07:22 | #62140 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Four mobile S555 max2 rivacy Lock reset Done Operation : Reset Privacy Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 44000145313034465E09013665B0C27E Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 6104F [eMMC] : FLASH_CID : 45010044463430313601095E7EC26365 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x033C521702BF44B4B4661B8AE9A764A2 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Process block #1 Process block #2 Privacy Lock reset Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
01-23-2020, 07:24 | #62141 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile i6 metal 2018 restart Problem done with cm2 Operation : Format FS / Reset Settings [ v2.04 ] Mode : Reset Settings [ Format FS ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Reconnect Power/Cable! Done! Elapsed: 00:00:30 Last edited by Nadeem Waris; 01-23-2020 at 07:27. Reason: title rong |
01-23-2020, 07:25 | #62142 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile i6 metal 2018 Frp Remove done With cm2 Operation : Format FS / Reset Settings [ v2.04 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:30 Last edited by Nadeem Waris; 01-23-2020 at 07:27. Reason: title name chaneg |
01-23-2020, 08:05 | #62143 (permalink) |
Freak Poster Join Date: Apr 2010
Member: 1280685 Status: Offline Thanks Meter: 59 | Samsung Guru Music 2 SM-B350E PhoneLock Code: Operation : Read User Code [ v1.25 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 ÀA Boot Ok CPU ID : 6530 , FDLStat : 00C0 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Check data... Can take some time User Code : 1234 Done! Elapsed: 00:00:17 |
01-23-2020, 10:54 | #62145 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Infinix X5010 frp remove done Operation : Format FS / Reset Settings [ v2.04 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:30 |
