02-15-2021, 10:49 | #65941 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile X30 Flash Code: Brand : TINNO ProdName : QMobile X30 ProdModel : QMobile X30 Device : QMobile X30 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344732611101D777F23562F3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611101D777F23562F3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C25C382E611EF76B8ECC50E699A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3901 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:10 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:54 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:19 Reconnect Power/Cable! |
02-15-2021, 10:55 | #65942 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | GFive Sunlight Format Code: Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_138955BC79A3_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:52 Reconnect Power/Cable! |
02-15-2021, 10:55 | #65943 (permalink) |
No Life Poster Join Date: Dec 2007 Location: shirdi..sai baba.. Age: 36
Member: 662678 Status: Offline Thanks Meter: 2,539 | Lava Z61P SPD SC9863x Password Unlock FRP Unlock No Need Flash No Dead Risk Working S Lava Z61P SPD SC9863x Password Unlock FRP Unlock No Need Flash No Dead Risk Working Solution Infinity Box Boom Boom |
The Following 2 Users Say Thank You to ..::ohm::.. For This Useful Post: |
02-15-2021, 10:57 | #65944 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | moto e(6) plus Frp Code: Patch Level : PTBS29.401-58-2 Display ID : PTBS29.401-58-2 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-12-01 Build Time : 23.11.2020 Product Model : moto e(6) plus Product Brand : motorola Product Name : pokerp_reteu_64 Product Device : pokerp Product Manfct : motorola Product Info : pokerp Product Board : p161bn Board Platform : mt6765 USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] STORAGE : LifeStatus : eMMC : NOT implemented in selected DA! Done! Elapsed: 00:00:24 Operation : Reset Settings/Format FS [ v2.16 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled BROM : SOCID : 35F19777538E9C188C89049E09689CCD4FB6A730827D4CF6147F8E4B043723D4 AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC_1848_PTB29.138.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 13014E53304A394E381012DB34848643 EMMC: VEN : MICRON | OEM : 4E01 | DEV : S0J9N8 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 35ACFE857C9C314EDBBA153CAC2351E DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
02-15-2021, 10:57 | #65945 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Moto C Plus Flash Code: Patch Level : NRD90M.01.040 Display ID : NRD90M.01 040 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-08-05 Build Time : 27.03.2019 Product Model : Moto C Plus Product Brand : motorola Product Name : panell_23_d Product Device : panell_d Product Board : MT6737 Product Manfct : motorola Board Platform : mt6737m USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption ***) IMEI : IMEI_NVRAM data damaged [ Empty ] NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Done! Elapsed: 00:00:26 Preloader [HW DEV] Info : EMI : DEV : MT6752 EMI : SRC : preloader_a158.bin EMI : CNT : 0003 EMI : [00] : eMMC : DDR3 : ID : 150100514531334D42 : VEN : SAMSUNG | DEV : QE13MB : RAM : [ 2.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ] Operation : Write Flash [ v2.16 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :11 [FL] : Set : preloader_A158.bin [FL] : Set : lk-sign.bin [FL] : Set : boot-sign.img [FL] : Set : recovery-sign.img [FL] : Set : logo-sign.bin [FL] : Set : secro-sign.img [FL] : Set : trustzone-sign.bin [FL] : Set : trustzone-sign.bin [FL] : Set : system-sign.img [FL] : Set : cache-sign.img [FL] : Set : userdata-sign.img [FL] : Total size : 0x994264C0 [ 2.39 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM21) MODE : PRELOADER PORT PORT : 21 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100514536334D420321A6E4C93257 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100514536334D420321A6E4C99457 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1A57926BB4402120EDECB20EDFD0A51E STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : True (CUST) SEC_DL : SECURE USB DL ENABLED SEC_ID : 0x61366135623265356165383564376366 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000080000 Erase : 0x0000000001C80000 : 0x0000000004D80000 Erase : 0x0000000006B00000 : 0x0000000126500000 [FL] : RePartition [FL] : RePartition Ok! SecInit : LK SecInit : BOOT SecInit : RECOVERY SecInit : LOGO SecInit : SECRO SecInit : TEE1 SecInit : TEE2 SecInit : SYSTEM SecInit : CACHE SecInit : USERDATA [FL] : Flashing now ... Write : PRELOADER Update bootloader code ... Update bootloader Ok! Write : LK Write : BOOT Write : RECOVERY Write : LOGO Write : SECRO Write : TEE1 Write : TEE2 Write : SYSTEM Write : CACHE Write : USERDATA SEC_DL : WRITE INFO : OK SEC_DL : True (CUST) SEC_DL : SECURE USB DL ENABLED SEC_ID : 0x61366135623265356165383564376366 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:03:59 Reconnect Power/Cable! |
02-15-2021, 11:04 | #65946 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Oale X1 Flash Code: Patch Level : LMY47I Display ID : Z6U190HF_V018En Ver. CodeName : REL Ver. Release : 5.1 Sec. Patch : 2016-03-01 Build Time : 03.02.2018 Product Model : gxq6580_weg_l Product Brand : alps Product Name : full_gxq6580_weg_l Product Device : gxq6580_weg_l Product Manfct : alps Board Platform : mt6580 Product Info : gxq6580_weg_l IMEI[0] : IMEI[1] : NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Done! Elapsed: 00:00:26 Preloader [HW DEV] Info : EMI : DEV : MT6752 EMI : SRC : preloader_gxq6580_we_m.bin EMI : CNT : 000F EMI : [00] : eMMC : DDR2 : ID : 110100303034474530 : VEN : TOSHIBA | DEV : 004GE0 : RAM : [ 512.00 MB ] EMI : [01] : eMMC : DDR2 : ID : 1501004B3758564D42 : VEN : SAMSUNG | DEV : K7XVMB : RAM : [ 1.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 110100303038473730 : VEN : TOSHIBA | DEV : 008G70 : RAM : [ 1.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100513732534D42 : VEN : SAMSUNG | DEV : Q72SMB : RAM : [ 1.00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100463732324D42 : VEN : SAMSUNG | DEV : F722MB : RAM : [ 1.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 880103455042313030 : VEN : FORESEE | DEV : EPB100 : RAM : [ 1.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 700100454838434538 : VEN : KINGSTON | DEV : EH8CE8 : RAM : [ 1.00 GB ] EMI : [07] : eMMC : DDR3 : ID : 700100454838454538 : VEN : KINGSTON | DEV : EH8EE8 : RAM : [ 1.00 GB ] EMI : [08] : eMMC : DDR3 : ID : 150100513832334D42 : VEN : SAMSUNG | DEV : Q823MB : RAM : [ 2.00 GB ] EMI : [09] : eMMC : DDR3 : ID : 1501003030434E5630 : VEN : SAMSUNG | DEV : 00CNV0 : RAM : [ 1.00 GB ] EMI : [0A] : eMMC : DDR3 : ID : 8801034E4361726420 : VEN : FORESEE | DEV : NCard : RAM : [ 1.00 GB ] EMI : [0B] : eMMC : DDR3 : ID : 150100303058505630 : VEN : SAMSUNG | DEV : 00XPV0 : RAM : [ 1.00 GB ] EMI : [0C] : eMMC : DDR3 : ID : 9901994F726967696E : VEN : UNKNOWN | DEV : Origin : RAM : [ 1.00 GB ] EMI : [0D] : eMMC : DDR3 : ID : 13014E51324A393551 : VEN : MICRON | DEV : Q2J95Q : RAM : [ 1.00 GB ] EMI : [0E] : eMMC : DDR3 : ID : 90014A483847316505 : VEN : HYNIX | DEV : H8G1e : RAM : [ 1.00 GB ] Operation : Write Flash [ v2.16 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :9 [FL] : Set : preloader_gxq6580_we_m.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : recovery.img [FL] : Set : logo.bin [FL] : Set : secro.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x57D26D7C [ 1.37 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 30000115564E433004150130CB811408 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 1501003030434E563001150481481CB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : 00CNV0 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8B9D41DF22D34A505E1BE3E67E03BE60 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (CUST) SEC_DL : SECURE USB DL DISABLED SEC_ID : 0x35464646304237304435444533464335 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000080000 Erase : 0x0000000001C80000 : 0x00000000E3380000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader code ... Update bootloader Ok! Write : LK Write : BOOT Write : RECOVERY Write : LOGO Write : SECRO Write : SYSTEM Write : CACHE Write : USERDATA [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:02:00 Reconnect Power/Cable! |
02-15-2021, 11:06 | #65947 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Jazz Digit Flash Code: Patch Level : KOT49H Display ID : Digit_M42421DG_SW19 Ver. CodeName : REL Ver. Release : 4.4.2 Build Time : 25.11.2020 Product Model : Digit4G Product Brand : Digit Product Name : Digit4G Product Device : Digit4G Product Manfct : alps Board Platform : mt6739 Product Info : Digit4G USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption ***) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] STORAGE : LifeStatus : eMMC : NOT implemented in selected DA! Done! Elapsed: 00:00:19 Created by Infinity-Box (c) 2020 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Patch Level : KOT49H Display ID : Digit_M42421DG_SW15 Ver. CodeName : REL Ver. Release : 4.4.2 Build Time : 22.08.2020 Product Model : Digit4G Product Brand : Digit Product Name : Digit4G Product Device : Digit4G Product Manfct : alps Board Platform : mt6739 Product Info : Digit4G Preloader [HW DEV] Info : EMI : DEV : MT6739 EMI : SRC : preloader_fise6731_kaie_s_e_k.bin EMI : CNT : 0006 EMI : [00] : eMMC : DDR3 : ID : 700100454534454434 : VEN : KINGSTON | DEV : EE4ED4 : RAM : [ 512.00 MB ] EMI : [01] : eMMC : DDR3 : ID : F40122426977696E20 : VEN : BIWIN | DEV : Biwin : RAM : [ 512.00 MB ] EMI : [02] : eMMC : DDR3 : ID : 150100463558354342 : VEN : SAMSUNG | DEV : F5X5CB : RAM : [ 512.00 MB ] EMI : [03] : eMMC : DDR3 : ID : 150100464A32354142 : VEN : SAMSUNG | DEV : FJ25AB : RAM : [ 512.00 MB ] EMI : [04] : eMMC : DDR3 : ID : FE014E50314A39344D : VEN : MICRON | DEV : P1J94M : RAM : [ 512.00 MB ] EMI : [05] : eMMC : DDR3 : ID : 90014A483447326111 : VEN : HYNIX | DEV : H4G2a : RAM : [ 512.00 MB ] Operation : Write Flash [ v2.16 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :17 [FL] : Set : preloader_fise6731_kaie_s_e_k.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : mcupmfw.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : loader_ext.img [FL] : Set : loader_ext.img [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x20E87698 [ 526.53 MB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : MEID : D6E95DB5D790196A6950D0084FA2820C BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1836 | Manual : Enabled BROM : SOCID : 373EDB37E874169813B0277E011F6E0C381612988968908B397F0DFB31F39362 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6739 EMI : SRC : preloader_fise6731_kaie_s_e_k.bin EMI : CNT : 0006 EMI : [00] : eMMC : DDR3 : ID : 700100454534454434 : VEN : KINGSTON | DEV : EE4ED4 : RAM : [ 512.00 MB ] EMI : [01] : eMMC : DDR3 : ID : F40122426977696E20 : VEN : BIWIN | DEV : Biwin : RAM : [ 512.00 MB ] EMI : [02] : eMMC : DDR3 : ID : 150100463558354342 : VEN : SAMSUNG | DEV : F5X5CB : RAM : [ 512.00 MB ] EMI : [03] : eMMC : DDR3 : ID : 150100464A32354142 : VEN : SAMSUNG | DEV : FJ25AB : RAM : [ 512.00 MB ] EMI : [04] : eMMC : DDR3 : ID : FE014E50314A39344D : VEN : MICRON | DEV : P1J94M : RAM : [ 512.00 MB ] EMI : [05] : eMMC : DDR3 : ID : 90014A483447326111 : VEN : HYNIX | DEV : H4G2a : RAM : [ 512.00 MB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: FE014E50314A39344D1286FC765A4211 EMMC: VEN : MICRON | OEM : 4E01 | DEV : P1J94M EMMC: BOOT1 : 0x00100000 [ 1.00 MB ] BOOT2 : 0x00100000 [ 1.00 MB ] RPMB : 0x00100000 [ 1.00 MB ] USER : 0xE9800000 [ 3.65 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 54CED87A31D16288D5EE8FDE1CE93B6D DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000002E88000 Erase : 0x0000000003688000 : 0x0000000004000000 Erase : 0x0000000008800000 : 0x0000000000A00000 Erase : 0x0000000009500000 : 0x0000000007200000 Erase : 0x0000000010C00000 : 0x0000000000200000 Erase : 0x0000000010E20000 : 0x00000000D71DBE00 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : MD1IMG Write : MD1DSP Write : SPMFW Write : MCUPMFW Write : LK Write : LK2 Write : LOADER_EXT1 Write : LOADER_EXT2 Write : BOOT Write : LOGO Write : TEE1 Write : TEE2 Write : SYSTEM Write : CACHE Write : USERDATA [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:01:14 Reconnect Power/Cable! |
02-15-2021, 11:08 | #65948 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | GFive Sunlight Format Code: Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1A8B3EB91DD0_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
02-15-2021, 11:12 | #65949 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Lava iris702 Format Code: Brand : Lava ProdName : iris702 ProdModel : iris702 Device : iris702 AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : alps-mp-m0.mp1-V2.34_lava6580.weg.m_P30 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463732324D420045C7C40A4373 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D420045C7C40A4373 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD5229C2528706CC607164A555EC6C137 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
02-15-2021, 11:13 | #65950 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung Galaxy J1(2016) Flash Code: Brand : Samsung ProdName : Samsung Galaxy J1(2016) ProdModel : Samsung Galaxy J1(2016) Device : Samsung Galaxy J1(2016) AndroidVer: 4.2.2 MTKxCPU : MT6582 MTKxPRJ : J8216_2G_5.1.1_V1.0 Done! Elapsed: 00:00:10 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6582 , Project : j8216 , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Samsung Device Model : Samsung Galaxy J1(2016) Device CPU : MT6582 Device IntName : Samsung Galaxy J1(2016) Device Version : 4.2.2 Device Compile : 11/1/2016 6:29:10 AM Device Project : J8216_2G_5.1.1_V1.0 Device ExtInfo : Samsung Galaxy J1(2016) Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E35575A4D42015F62542FA0A1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D42015F62542FA0A1 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C257B56B719710B96F4F55AC36A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : j8216 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3910 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x00000000E4C20000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:04:04 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:21 Reconnect Power/Cable! |
02-15-2021, 11:14 | #65951 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix X650C Frp Code: Patch Level : PPR1.180610.011 Display ID : X650C-H626DEJ-P-200820V301 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-09-05 Build Time : 20.08.2020 Product Model : Infinix X650C Product Brand : Infinix Product Name : H626 Product Device : Infinix-X650C Product Manfct : INFINIX MOBILITY LIMITED Product Info : x650c_h626 Product Board : Infinix-X650C Board Platform : mt6765 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption *) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] STORAGE : LifeStatus : eMMC : NOT implemented in selected DA! Done! Elapsed: 00:00:24 Operation : Reset Settings/Format FS [ v2.16 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Disabled BROM : SOCID : BF397CD01AF404B4603DC4943171A656EEAD5E83F64AE580AB597556FB119606 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 15010044483644414202194D903F274F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DH6DAB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : FD7CED705A0E75315C1F0E1C139BAA36 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
02-15-2021, 11:20 | #65952 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile Q Infinity B Frp Code: Model Name : Q_Infinity_B Model Brand : Qmobile Model Device: Q_Infinity_B AndrVersion : 7.0 BaseBand CPU: SP7731CEA CompileDate : 5/5/2018 8:03:00 AM Project Ver : QMobile_Q Infinity B_MP_16_04 Model Ext : QMobile Q Infinity B ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:34 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC Loader v7 InfinityBox Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000000EE7F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
02-15-2021, 11:21 | #65953 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | TECNO KC3 Frp Code: Patch Level : PPR1.180610.011 Display ID : KC3-H627G-P-200727V307 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-08-05 Build Time : 27.07.2020 Product Model : TECNO KC3 Product Brand : TECNO Product Name : H627 Product Device : TECNO-KC3 Product Manfct : TECNO MOBILE LIMITED Product Info : kc3_h627mt62 Product Board : TECNO-KC3 Board Platform : mt6765 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption *) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] STORAGE : LifeStatus : eMMC : NOT implemented in selected DA! Done! Elapsed: 00:00:27 Operation : Reset Settings/Format FS [ v2.16 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM21) MODE : PRELOADER PORT PORT : 21 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Disabled BROM : SOCID : 7BB164BB71CDF16764B0028411736A040B2B51B9BBFBA5EBBF321AC370DBE4EE AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 90014A68433961503301C35660AB607 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hC9aP3 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E133A3EB198039E5CD95F256B8380B4A DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
02-15-2021, 12:23 | #65954 (permalink) |
Freak Poster Join Date: Mar 2011 Location: ..::PAKISTAN::.. Age: 29
Member: 1530955 Status: Offline Sonork: 100.1627356 Thanks Meter: 223 | oppo reno2f Red Flash File Without open With CM2 World First%%% oppo reno2f Red Flash File Without open With CM2 World First%%% file link youtube Description https://www.youtube.com/watch?v=_0lpe-EcvzE |
The Following 2 Users Say Thank You to JUNAID ARAIN For This Useful Post: |
02-15-2021, 13:01 | #65955 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | itel L6005 Pattern Remove Done With King Cm2 Operation : Format FS / Reset Settings [ v2.11 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel L6002P Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0004 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:03:25 |
