05-01-2011, 10:02 | #11551 (permalink) |
No Life Poster Join Date: Sep 2008 Location: BD - UK Age: 44
Member: 861464 Status: Offline Sonork: 100.1597346 noor Thanks Meter: 172 | best successfull flash c1-01 registered to: noortel DLL not found... Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - C1-01 Software ver : V 04.40 23-02-11 RM-607 (c) Nokia IMEI : 355962042114076 Ape Ver : APE Var : APE ADSP: DSP Ver : APE Test: PPM : V 04.40 23-02-11 RM-607 (c) Nokia MS CNT : Product SN : HUB848279 Product code : 059D2S0 Base Prd.code: 0585582 Module code : 0204427 Long Prod.SN : 0 Hardware info======= HWID : 1000 Retu : Tahvo : Batery: 3997 mV Camera: CMT BT: 19b5-22012 APE BT: APE HW: LCDVer: AUO RF ic : Lock info =========== IMEI : 355962042114076 IMEI spNet : 3A 55 69 02 24 11 04 07 IMEI svNet : 33 55 69 02 24 11 04 17 F1 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : F09FDDB773E3C49E Provider : Default Test Operator Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; CRT308 Backup Created... User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Core version : 1.20 , Rev : 4.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm607__04.40.mcusw PPM : rm607__04.40.ppm_a CNT : rm607__04.40.image_a_0595346 Flashing phone now... Check files done... -> SWversion check skipped : UserIni mode selected Backup CRT308 data... CRT308 Backup Created... Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... Reboot.... Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.37_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! ===Flashing [MCU]=== File : rm607__04.40.mcusw Image : rm607__04.40.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00040000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40080000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40080000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 4/5 Erase , Start : 0x400A0000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x400A0000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 5/5 Erase , Start : 0x40400000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:19 Write , Start : 0x40400000 , Len : 0x01780000 Flashing , wait ... Region flash done, time : 00:00:34 ===Flashing [PPM]=== File : rm607__04.40.ppm_a Image : package_a.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:20 Write , Start : 0x41C00000 , Len : 0x00387830 Flashing , wait ... Region flash done, time : 00:00:04 ===Flashing [CNT]=== File : rm607__04.40.image_a_0595346 Image : package_a_0595346.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42200000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:03:27 Write , Start : 0x42200000 , Len : 0x00B40000 Flashing , wait ... Region flash done, time : 00:00:14 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:05 No write data, skip Flashing done! Total flash time : 00:07:17 Reboot phone now... Reading Phone Info.... Connected phone - C1-01 Software Info: V 04.40 23-02-11 RM-607 (c) Nokia IMEI: 355962042114076 PPM version : V 04.40 23-02-11 RM-607 (c) Nokia A Product code: 059D2S0 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Set phone to Normal mode... AfterFlash operations done... Done! Connect phone on selected interface... Elapsed: 00:07:51 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! |
The Following 3 Users Say Thank You to noor012345 For This Useful Post: |
05-01-2011, 10:32 | #11552 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ---- Age: 35
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | Dead 6300 Alive COM6 [Serial2] selected module v3.29 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0E03:0006 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: MT6225_GEMINI_PCB01_GPRS_MT6225_S00.SYGJ_6300_2_8_ 3_2.BIN project-id: SYGJ.6300.2.8.3.2, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: MT6225_GEMINI_PCB01_GPRS_MT6225_S00.SYGJ_6300_2_8_ 3_2__ffs... file saved: C:\InfinityBox\ChineseMiracle\MT6225_GEMINI_PCB01_ GPRS_MT6225_S00.SYGJ_6300_2_8_3_2__ffs_20110501-142718.B0E.bin flash: 89881200010001:89881200000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 89881200010001:89881200000000 Finalization Done Finished, time used: 2 min 39 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to madni shah For This Useful Post: |
05-01-2011, 10:54 | #11553 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Another Korean 5800 is unlocked card found: S/N ------- registered to: Akramjon Connect phone on selected interface... UFS S/N ----- boot - Ok Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 5800 XpressMusic Software ver : V ICPR72_09w20.15 30-12-09 RM-356 (c) Nokia IMEI : 359339039983761 Ape Ver : V 10.4.101 APE Var : V 10.4.101V 10.4.101 V 10.4.101 APE ADSP: 256 DSP Ver : tube_ICPR72_09w19_1_p1 APE Test: eno_version PPM : CNT : Product SN : MYN387147 Product code : 0588615 Base Prd.code: 0592755 Module code : Long Prod.SN : 0 Hardware info======= HWID : 1104 Retu : 16 Tahvo : 22 Batery: 4283 mV Camera: CMT BT: APE BT: APE HW: 256 LCDVer: RF ic : 17141716 Lock info =========== IMEI : 359339039983761 IMEI spNet : IMEI svNet : Conf key : 8000000000000000 Provider key : 4500000088401881 Provider : Unknown Provider Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= User code : Crypted UserDataExLevel : Low [Gallery] Done! Connecting to server... Server have 526 free slot(s) Approx. time of calculation for first free slot: 44 Hour Unlock procedure started... Server version: 0.195.700 There are 526 free slots on the server. Looking for jobs...You have no current jobs. Archived jobs: 359339039983761: Code: #pw+664640199718856+7# 354855049711814: Code: #pw+961467730573518+7# 354316046719557: Code: #pw+325827225356089+7# Using F-bus count... Sending code 664640199718856 Level : 7 to SimLock Server... Simlock Server Answer: Unlock code Accepted! Done! |
The Following 3 Users Say Thank You to Namangan For This Useful Post: |
05-01-2011, 12:26 | #11554 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlock A136 COM3 [VCP1] selected module v1.68 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20110428-234627.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20110428-234628.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20110428-234634.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20110428-234647.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 57 sec Remove/Install battery now ! |
The Following User Says Thank You to gsmcrazy1 For This Useful Post: |
05-01-2011, 13:15 | #11555 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Code: Processing Server SX4 Auth Checking SDD key... Check SD : Key is Ok Connecting to server... Connect to server Ok, checking SX4 Server : Online, Ready SX4, processing Step #1 SX4, processing Step #2 SX4, processing Step #3 SX4 Result : Ok XD |
The Following 3 Users Say Thank You to Dzirt For This Useful Post: |
05-01-2011, 13:20 | #11556 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Unknown
Member: 603971 Status: Offline Thanks Meter: 730 | X3 Flash Done. Code: ===Flashing [MCU]=== Erase : Processing rm540__08.50.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm540__08.50.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 124 blocks TIME : Write time : 00:00:51 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing rm540__08.50.ppm_meac Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm540__08.50.ppm_meac Total writen 22 blocks TIME : Write time : 00:00:10 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing rm540__08.50.image_meac_0583978_004 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm540__08.50.image_meac_0583978_004 Total writen 53 blocks TIME : Write time : 00:00:26 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:01:30 Reboot phone now... |
The Following 3 Users Say Thank You to ahmadge For This Useful Post: |
05-01-2011, 13:57 | #11557 (permalink) |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | Code: 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 743B4D0F66C4A7278C4D8483000EAFE5604BF61A APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000294 CMT EM1 ID : 00000B21 CMT PUB ID : 02E0010BD08100545C65DB05F21B1F736051020F CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 582DB35096C57ABD62812468D2987E8588C0CF0200 Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok FLASHID : 00A100EC , APE , NAND APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLCNT : 00FFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_sam_nand_xsr.fg , Rev : 0.0 Ver : 1.47.0 APE Algo sent APE PAPUB : AB1F68D2E4D7D0487762E37D74EA7D923C341FBC00 Transmission mode : Dual (Ddr, TX2) Boot Done! Init Service mode... Wait... SimLock status : SimLock is Ok Security status : Security is Ok SDD Key status : SD Data is Ok PA_SimLock Version : PA_SL phone detected Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core version : 1.20 , Rev : 4.0 Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm89_m128_h20_ks_prod_306330904_c00_combined.bin PPM : rm89_m128_h20_ks_prod_306330904_v08_variant.bin Check FlashFiles, Please, wait... -> SWversion check skipped : Manual mode selected Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 743B4D0F66C4A7278C4D8483000EAFE5604BF61A APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000294 CMT EM1 ID : 00000B21 CMT PUB ID : 02E0010BD08100545C65DB05F21B1F736051020F CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 582DB35096C57ABD62812468D2987E8588C0CF0200 Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok FLASHID : 00A100EC , APE , NAND APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLCNT : 00FFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_sam_nand_xsr.fg , Rev : 0.0 Ver : 1.47.0 APE Algo sent APE PAPUB : AB1F68D2E4D7D0487762E37D74EA7D923C341FBC00 Transmission mode : Dual (Ddr, TX2) Boot Done! Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing rm89_m128_h20_ks_prod_306330904_c00_combined.bin Found 3 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x0052FFE5 CMT , NOR , Area : 0x006A0000 - 0x006EFFFF CMT , NOR , Area : 0x00F00000 - 0x00FEFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok Found 3 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x00000000 - 0x0007FFFF APE , NAND , Area : 0x00080000 - 0x000803FF APE , NAND , Area : 0x000C0000 - 0x0377FFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:39 Transmission mode : Dual (Ddr, TX2) Write : Processing rm89_m128_h20_ks_prod_306330904_c00_combined.bin CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [ADL] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] APE: Writing Hash CERT [KEYS] APE: Writing Hash CERT [X-LOADER] APE: Writing Hash CERT [PRIMAPP] APE: Writing Hash CERT [SOS+LOADER] APE: Writing Hash CERT [ADL] APE: Writing Hash CERT [SOS+XZIP] APE: Writing Hash CERT [PASUBTOC] APE: Writing Hash CERT [PAPUBKEYS] APE: Writing Hash CERT [SOS*CORE] Total writen 1207 blocks TIME : Write time : 00:03:47 Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing rm89_m128_h20_ks_prod_306330904_v08_variant.bin Found 1 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x02180000 - 0x0377FFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm89_m128_h20_ks_prod_306330904_v08_variant.bin Total writen 1534 blocks TIME : Write time : 00:02:14 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia E61 Software Info: V 3.0533.6 31-10-06 RM-89 (c) Nokia. IMEI: 356211000674906 Product code: 0530096 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
The Following 3 Users Say Thank You to nadirghazi For This Useful Post: |
05-01-2011, 14:26 | #11558 (permalink) |
No Life Poster Join Date: Apr 2008 Location: INSIDE OCLHASHCAT
Member: 751235 Status: Offline Sonork: 100.1662008 Thanks Meter: 526 | Reading Phone Info.... Connected phone - Nokia N97 Software ver : V ICPR72_09w44.11 20-01-10 RM-505 (c) Nokia IMEI : 359374033805512 Ape Ver : v 21.0.102 APE Var : v 21.0.10221.0.102.17.0121.0.102.C01.01 APE ADSP: 256 DSP Ver : gadget_ICPR72_09w43_p1 APE Test: 0.072 PPM : CNT : 21.0.102.uda_4_001 Product SN : CRG323447 Product code : 0576560 Base Prd.code: 0570816 Module code : Long Prod.SN : 0 Hardware info======= HWID : 4072 Retu : 16 Tahvo : 22 Batery: 4560 mV Camera: CMT BT: APE BT: APE HW: 256 LCDVer: RF ic : |Vapaus_5.1 | Aura_?.? Lock info =========== IMEI : 359374033805512 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User code : Crypted UserDataExLevel : Low [Gallery] Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Elapsed: 00:00:11 Set phone in Normal mode... Restarting... Done! Phone disconected! Connect phone on selected interface... |
The Following 2 Users Say Thank You to THE GREAT ONE For This Useful Post: |
05-01-2011, 15:04 | #11559 (permalink) |
Member: 603971 Status: Offline Thanks Meter: 730 | N97 Flash Done. Code: --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101031103 CPU ID : RAPIDO v11 , Features : Dead-Test EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1B60010CE6800052963256A9254235F5112BD85C ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! :) TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-505_22.0.110_prd.core.C00 Found 4 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x0AB9FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-505_22.0.110_prd.core.C00 Total 477 [477/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:41 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-505_22.0.110_prd.rofs2.V15 Found 1 areas to erase Erasing area 0x079A0000 - 0x09C9FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-505_22.0.110_prd.rofs2.V15 Total 90 [90/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:08 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-505_22.0.110_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09CA0000 - 0x0AB9FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-505_22.0.110_C01_prd.rofs3.fpsx Total 6 [6/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:00 PPM Write done ===Flashing [CNT]=== Erase : Processing RM505_507_22.0.110_uda_4_001.uda.fpsx Found 1 areas to erase Erasing area 0x0ABA0000 - 0x0F71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM505_507_22.0.110_uda_4_001.uda.fpsx Total 36 [36/0/0] blocks to write, writing... TIME : Write time : 00:00:03 CNT Write done ===Flashing [APE]=== Erase : Processing RM505_APE_ONLY_ENO_09w23_v0.072.fpsx Found 1 areas to erase Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM505_APE_ONLY_ENO_09w23_v0.072.fpsx Total 16 [16/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:01 APE Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:55 |
The Following 4 Users Say Thank You to ahmadge For This Useful Post: |
05-02-2011, 08:15 | #11560 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM15 [VCP2] selected module v3.29 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 351993013788824 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9503:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL.BIN project-id: T600_V04_EnFrArRuSpPeVi_SIGMATEL, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... ....................... ffs/eeprom: detect std location pass #1... .................................................. .... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok element #2 imei default found: 13579024681122 Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 2088C4FFFFFFFF:2088C400000000 flash: 2088C4FFFFFFFF:2088C400000000 Write: imei Write Done ====> Finalization ... ffs formatting... flash: 2088C4FFFFFFFF:2088C400000000 Finalization Done Finished, time used: 2 min 51 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to joni_rajpura For This Useful Post: |
05-02-2011, 08:34 | #11561 (permalink) |
No Life Poster Join Date: Aug 2007 Location: GREAT INDIA
Member: 559113 Status: Offline Sonork: 100.1596477 Thanks Meter: 760 | Huawei-C2802 sp unlock done .... COM7 [VCP1] selected module v1.49 Device: Huawei-C2802 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... disable minlock... Phones should be restarting now... Finished, time used: 3 sec |
The Following User Says Thank You to sonu arya For This Useful Post: |
05-02-2011, 08:39 | #11562 (permalink) |
Member: 559113 Status: Offline Sonork: 100.1596477 Thanks Meter: 760 | Huawei-C2906 sp unlock done .... module v1.49 Device: Huawei-C2906 operation: SP-unlock Phone should be Switched ON ! connecting... checking version... C2906C53B108 C2906C53B108 Huawei C2906 version B108 selected.. OFFLINE... downloading mode... erasing... patching in progress... patching in progress 20%... patching in progress 40%... patching in progress 60%... patching in progress 80%... patching in progress 100%... DONE... Phones should be restarting now... Finished, time used: 54 secH |
05-02-2011, 09:00 | #11563 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 352366031395196 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 355256026276294 verification Ok Finished, time used: 3 sec Remove/Install battery now ! |
05-02-2011, 09:01 | #11564 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-2: 135790246811220 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei-2: 352009029545816 verification Ok Finished, time used: 3 sec Remove/Install battery now ! |
05-02-2011, 09:10 | #11565 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | 5030 flash done Code: Phone found! Series 40 Device detected! [DCT4+] read info... - Ok Read and Check phone data... Checking bus... DCT4 mode selected 1st boot Ok , UPP : 2293 Sending 2nd... Use : u3_2nd.fia 2nd boot sent MCUcfg Ok , 03 FL [01] : ID 002088C0 , rev 00007321 , ST , Not In Base FL [02] : ID 00000001 , rev 00000000 , EMPTY , Not Used FLCNT : AD7EB61A23100340C605E40120A26514 Sending Algo... Use : u3_st_i.fia Algorithm sent MSID : 84493FC27A30DA2EAA1BBB7D7D05 DMSID : 17CABAE900E3633EA8000000 EFAID : 5CFF50478B31368F6E9377C8 Set FAID Ok Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... Phone found! Series 40 Device detected! [DCT4+] read info... - Ok Reading Phone Info.... SW ver : IMEI : 356074035627459 PPM : V 03.75 21-04-09 RM-524 (c) Nokia EL DSP Ver : PR81_09w06_UPP PCode : 0578359 BPCode : 0572837 HWID : 1002 LCDVer : UNKWN: IDs: 7f:ff:7f IMEI : 356074035627459 Sl Conf : 001-01-00000000000 Sl Prof : 000000000003000-2 Sl Aux : 000B0000 Hw Sig : C5EFFCD6B5F4629B Provider : Default Test Operator Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! Core version : 1.20 , Rev : 4.0 Selected FlashSettings : Files Set for Flashing : MCU : rm524_005.010 PPM : rm524_005.01ej CNT : rm5240_nai05.01ej ===Flashing [MCU]=== Processing : rm524_005.010 1st boot Ok , UPP : 2293 Sending 2nd... Use : u3_2nd.fia 2nd patched Ok 2nd boot sent MCUcfg Ok , 03 FL [01] : ID 002088C0 , rev 00007321 , ST , Not In Base FL [02] : ID 00000001 , rev 00000000 , EMPTY , Not Used FLCNT : AD7EB61A23100340C605E40120A26514 Sending Algo... Use : u3_st_i.fia Algo patched Ok Algorithm sent Claudia Ok MSID : 84E63018302CBE4C7002E7EEE4BC DMSID : 3E4EBAE900E3633EA8000000 EFAID : 2B3337219B3BBF68CA0C03E9 Set FAID Ok Erase : Processing rm524_005.010 Erasing area 0x01000000 - 0x0100FFFF Erasing area 0x01010000 - 0x0179FFFF Erasing area 0x017A0000 - 0x017EFFFF Erasing area 0x01F00000 - 0x01FDFFFF Erase done , in 00:03:31 Write : Processing rm524_005.010 Init Write Mode Ok Write done , in 00:00:14 Perm.Data restored Ok MCU flash done ===Flashing [PPM]=== Processing : rm524_005.01ej 1st boot Ok , UPP : 2293 Sending 2nd... Use : u3_2nd.fia 2nd patched Ok 2nd boot sent MCUcfg Ok , 03 FL [01] : ID 002088C0 , rev 00007321 , ST , Not In Base FL [02] : ID 00000001 , rev 00000000 , EMPTY , Not Used FLCNT : AD7EB61A23100340C605E40120A26514 Sending Algo... Use : u3_st_i.fia Algo patched Ok Algorithm sent Claudia Ok MSID : 840C79E9939C9E8381F671DD42B6 DMSID : 3E4EBAE900E3633EA9000000 EFAID : 0FC5BE8EB066877FDCC18931 Set FAID Ok Erase : Processing rm524_005.01ej Erasing area 0x01250000 - 0x0125FFFF Erasing area 0x01260000 - 0x0174FFFF Erase done , in 00:02:00 Write : Processing rm524_005.01ej Init Write Mode Ok Write done , in 00:00:16 Perm.Data restored Ok PPM flash done ===Flashing [CNT]=== Processing : rm5240_nai05.01ej 1st boot Ok , UPP : 2293 Sending 2nd... Use : u3_2nd.fia 2nd patched Ok 2nd boot sent MCUcfg Ok , 03 FL [01] : ID 002088C0 , rev 00007321 , ST , Not In Base FL [02] : ID 00000001 , rev 00000000 , EMPTY , Not Used FLCNT : AD7EB61A23100340C605E40120A26514 Sending Algo... Use : u3_st_i.fia Algo patched Ok Algorithm sent Claudia Ok MSID : 84E63018302CBE4C7002E7EEE4BC DMSID : 3E4EBAE900E3633EA8000000 EFAID : 2B3337219B3BBF68CA0C03E9 Set FAID Ok Erase : Processing rm5240_nai05.01ej Erasing area 0x01750000 - 0x0178FFFF Erase done , in 00:00:06 Write : Processing rm5240_nai05.01ej Init Write Mode Ok Write done , in 00:00:01 Perm.Data restored Ok CNT flash done Switch jaf to FBUS... FbusMode set Ok Phone connected Reading Phone Info.... Software Info: V 05.01 23-09-09 RM-524 (c) Nokia IMEI: 356074035627459 PPM version : V 03.75 21-04-09 RM-524 (c) Nokia EL Product code: 0578359 Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Flashing done Connect phone on selected interface... Phone found! Series 40 Device detected! [DCT4+] read info... - Ok Reading Phone Info.... SW ver : V 05.01 23-09-09 RM-524 (c) Nokia IMEI : 356074035627459 PPM : V 05.01 23-09-09 RM-524 (c) Nokia EJ DSP Ver : PR81_09w17_U PCode : 0578359 BPCode : 0572837 HWID : 1002 LCDVer : UNKWN: IDs: 7f:ff:7f IMEI : 356074035627459 Sl Conf : 001-01-00000000000 Sl Prof : 000000000003000-2 Sl Aux : 000B0000 Hw Sig : C5EFFCD6B5F4629B Provider : Default Test Operator Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! |
