05-28-2011, 11:12 | #12256 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Connect phone on selected interface... UFS S/N 113742 boot - Ok Connect phone on selected interface... Core version : 1.22 , Rev : 4.5 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm653_006.200 PPM : rm653_006.20ia CNT : rm6530_nai06.20ia Infineon flashing... Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 Boot Ok , 01AB Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 0020000000C08800 FLASH ID : ST, M58WR064 Boot Done! ===Flashing [MCU]=== File : rm653_006.200 Image : hw_b2_rm653_r06.200.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00800000 , Len : 0x00210000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x00210000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00C60000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00C60000 , Len : 0x0020A0C0 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00FFC000 , Len : 0x00004000 Erasing, wait ... Erase done Write , Start : 0x00FFC000 , Len : 0x00000040 Flashing , wait ... Region flash done Check : 7CCF ===Flashing [PPM]=== File : rm653_006.20ia Image : hw_b2_rm653_006.20ia.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x001F3900 Flashing , wait ... Region flash done Check : D0C0 ===Flashing [CNT]=== File : rm6530_nai06.20ia Image : hw_b2_rm6530_nai06.20ia.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00EB0000 , Len : 0x000D0000 Erasing, wait ... Erase done Write , Start : 0x00EB0000 , Len : 0x00054B00 Flashing , wait ... Region flash done Check : 19AB Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Afterflash settings... SW ver : V 06.20 01-12-10 RM-653 (c) Nokia IMEI : 354835048090535 PCode : 0590493 Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! All done! Connect phone on selected interface... |
05-28-2011, 11:39 | #12257 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | COM3 [VCP0] selected module v3.30 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:2203:0007 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BB33A_CY_L12EN_303_091123_HX8340_BYD_KSP2832AU_CTF _BT_FM_G Version: 25_GEMINI_HW ==================== New firmware found (v.3.30, database date: 16.05.2011): BB33A_CY_L12EN_303_091123_HX8340_BYD_KSP2832AU_CTF _BT_FM_G This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure #2... 5 11 done 67 byte(s) read imei: 35341900143093 connection Ok building list... done items to clear: 162 warning: wrong packet cs warning: wrong packet cs items cleared: 162 of 162 items remains: 0 Finished, time used: 36 sec Remove/Install battery now ! |
05-28-2011, 11:41 | #12258 (permalink) |
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Successfully imei repaired. Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: 25_GEMINI_HW Software version: BB33A_CY_L12EN_303_0 Software date: 2006.06.14 Barcode: MT012345678901234567 imei-1: 353419001430938 imei-2: 353419001430938 imei-3: 353419001430938 Finished, time used: 28 sec Remove/Install battery now ! Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-2: 353419001430938 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei-2: 353419001430839 verification Ok Finished, time used: 8 sec Remove/Install battery now ! |
05-28-2011, 11:48 | #12259 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Romania
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | W375 Motorola W375 succesully unlocked. Thank you Infinity Team. BR. COM164 [Serial2] selected Action: unlock Device: W375 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.0.62 HW version: MOTOROLA_H80S LP ver: 0062_003 Flex ver: FLEX_CF_002 cpu id: 08B6 imei eeprom: 353003012111xxxx required SW version: 0.0.62 sp-locked: 21403. Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _35300301211xxx_20110528-054506.34E.bin unlock step-1 Ok unlock step-2 Ok unlock step-3 Ok unlock step-4 Ok unlock step-5 Ok finished Ok Finished, time used: 35 sec Remove/Install battery now ! |
05-28-2011, 11:51 | #12260 (permalink) |
No Life Poster Join Date: May 2005 Location: SOUSSE / TUNISIA - 21959153 Age: 44
Member: 145225 Status: Offline Thanks Meter: 98 | J132 COM5 [VCP1] selected module v1.38 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20110526-140349.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 21 min 55 sec Remove/Install battery now ! |
05-28-2011, 12:31 | #12261 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... UFS S/N 113742 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:12 Reading Phone Info.... SW ver : IMEI : V 06.20 01-12-10 RH-125 (c) Nokia PPM : CNT : V 06.20 01-12-10 RH-125 (c) Nokia IA DSP Ver : 88620 PCode : 356229049596054 BPCode : HWID : 0204373 LCDVer : 3005 IMEI : V 06.20 01-12-10 RH-125 (c) Nokia Sl Conf : 424-F4-84149763934 Sl Prof : 0A4E54333931323-1 Sl Aux : 00000000 Hw Sig : Provider : Unknown providers Lock info: Done! |
05-28-2011, 13:06 | #12262 (permalink) |
No Life Poster Join Date: Mar 2008 Location: (¯`-._UK_.-´¯) Age: 43
Member: 727518 Status: Offline Sonork: 100:1588024 Thanks Meter: 502 | Huwei g7002 unlock successfully by infinity!!! USE PINFINDER CABLE L10C COM19 [VCP0] selected module v3.91 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G7002 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:4A03:0009 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: G5.2EG01V02.11 Version: P2 67 byte(s) read imei: 35645603141820 connection Ok 178 byte(s) read reading data... reading data #2... building new data... writing data... 166 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! |
05-28-2011, 13:40 | #12263 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading User code... User Code is: E-series code : Decrypt failed Done! Reading Phone Info.... Connected phone - Nokia E51 Software ver : V ICPR71_09w14.2 30-04-09 RM-244 (c) Nokia IMEI : 356795026688130 Ape Ver : 400.34.011 APE Var : 400.34.011400.34.011_v226_20.06 APE ADSP: 256 DSP Ver : siiri_ICPR71_09w10p1 APE Test: rm244EN78100.41.813v034 PPM : CNT : Product SN : SAQ093683 Product code : 0557995 Base Prd.code: 0545341 Module code : Long Prod.SN : 0 Hardware info======= HWID : 0803 Retu : 15 Tahvo : 22 Batery: 4959 mV Camera: CMT BT: APE BT: APE HW: 256 LCDVer: RF ic : Lock info =========== IMEI : 356795026688130 IMEI spNet : 3A 65 97 05 62 86 18 03 IMEI svNet : 33 65 97 05 62 86 18 33 F6 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created User Code : E-series code : Decrypt failed UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:13 Format File System... Operating mode is OK, no need change... Scanning FS parametres... Checking Data... Detected : 2 drive(s)... Start formating.... Using Series 60 format algorithm... ================================== Formating drive : C now... Step1 : OK Step2 : OK End format... ================================== Formating drive : D now... Step1 : OK Step2 : OK End format... ================================== Done! |
05-28-2011, 13:41 | #12264 (permalink) |
No Life Poster Join Date: Jul 2007 Location: UK Age: 45
Member: 553000 Status: Offline Thanks Meter: 2,302 | 3120c nokia flash done !! Connect phone on selected interface... Core version : 1.22 , Rev : 4.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm364__07.16.mcusw PPM : rm364__07.16.ppm_i CNT : rm364__07.16_ISM_007.image_i_ru_graphite Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006010C192101003000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 11800019E0AE4F50850740CC6A1FBF1B18E95E8C CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm364__07.16.mcusw Found 5 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x01480000 - 0x015FFFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0147FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:01 Write : Processing rm364__07.16.mcusw Total 112 [112/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:34 MCU Write done ===Flashing [PPM]=== Erase : Processing rm364__07.16.ppm_i Found 1 areas to erase Erasing area 0x01600000 - 0x01CBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:18 Write : Processing rm364__07.16.ppm_i Total 24 [24/0/0] blocks to write, writing... TIME : Write time : 00:00:30 PPM Write done ===Flashing [CNT]=== Erase : Processing rm364__07.16_ISM_007.image_i_ru_graphite Found 2 areas to erase Erasing area 0x01FC0000 - 0x03F9FFFF, NOR, CMT Result: 0000 Erasing area 0x01CC0000 - 0x01FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:59 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm364__07.16_ISM_007.image_i_ru_graphite Total 37 [37/0/0] blocks to write, writing... TIME : Write time : 00:00:41 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:06:06 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3120 classic Software Info: V 07.16 27-05-08 RM-364 (c) Nokia IMEI: 353101023122921 PPM version : V 07.16 27-05-08 RM-364 (c) Nokia I Product code: 0559107 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:06:58 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
05-28-2011, 14:36 | #12265 (permalink) |
Freak Poster Join Date: May 2009 Location: *JAVA*
Member: 1026340 Status: Offline Sonork: 100.1621159 Thanks Meter: 142 | 3110c blink.. Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm237__07.21.mcusw PPM : rm237__07.21.ppm_x CNT : rm237__07.21.image_x Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006010C192101001101 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 16C0020C85287F56CA8A182871F172F6EA07BC92 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm237__07.21.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:07 Write : Processing rm237__07.21.mcusw Total 944 [944/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [PAPUBKEYS] CMT : PAPUBKEYS skip, already sent CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:00:44 MCU Write done ===Flashing [PPM]=== Erase : Processing rm237__07.21.ppm_x Found 1 areas to erase Erasing area 0x01080000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:37 Write : Processing rm237__07.21.ppm_x Total 279 [279/0/0] blocks to write, writing... TIME : Write time : 00:00:13 PPM Write done ===Flashing [CNT]=== Erase : Processing rm237__07.21.image_x Found 1 areas to erase Erasing area 0x01520000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:54 Write : Processing rm237__07.21.image_x Total 356 [356/0/0] blocks to write, writing... TIME : Write time : 00:00:17 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:05:55 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3110c Software Info: V 07.21 05-11-08 RM-237 (c) Nokia. IMEI: 355220037044877 PPM version : V 07.21 05-11-08 RM-237 (c) Nokia. X Product code: 0581834 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Resetting LifeTimer Reset Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! Set phone to Normal mode... AfterFlash operations done... Done! Elapsed: 00:06:51 |
The Following User Says Thank You to sadermo For This Useful Post: |
05-28-2011, 15:26 | #12266 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... UFS S/N 110743 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! [DCT4+] read info... - Ok Operating mode is OK, no need change... Field 1 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 6 write - Ok Record 11 write - Ok Record 12 write - Ok Field 2 Record 0 write - Ok Field 3 Record 0 write - Ok Field 4 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 9 write - Ok Field 5 Record 0 write - Ok Field 7 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Field 8 Record 0 write - Ok Field 11 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Record 30 write - Ok Record 31 write - Ok Record 32 write - Ok Record 33 write - Ok Record 34 write - Ok Record 35 write - Ok Record 36 write - Ok Record 37 write - Ok Record 38 write - Ok Record 39 write - Ok Record 40 write - Ok Record 41 write - Ok Record 42 write - Ok Record 43 write - Ok Record 44 write - Ok Record 45 write - Ok Record 46 write - Ok Record 47 write - Ok Record 48 write - Ok Record 49 write - Ok Record 50 write - Ok Record 51 write - Ok Record 52 write - Ok Record 53 write - Ok Record 54 write - Ok Record 55 write - Ok Record 56 write - Ok Record 57 write - Ok Record 58 write - Ok Record 59 write - Ok Record 60 write - Ok Record 61 write - Ok Record 62 write - Ok Record 63 write - Ok Record 64 write - Ok Record 65 write - Ok Record 66 write - Ok Record 67 write - Ok Record 68 write - Ok Record 69 write - Ok Record 70 write - Ok Record 71 write - Ok Record 72 write - Ok Record 73 write - Ok Record 74 write - Ok Record 75 write - Ok Record 76 write - Ok Record 77 write - Ok Record 78 write - Ok Record 79 write - Ok Record 80 write - Ok Record 81 write - Ok Record 82 write - Ok Record 83 write - Ok Record 84 write - Ok Record 85 write - Ok Record 86 write - Ok Record 87 write - Ok Record 88 write - Ok Record 89 write - Ok Record 90 write - Ok Record 91 write - Ok Record 92 write - Ok Record 93 write - Ok Record 94 write - Ok Record 95 write - Ok Record 96 write - Ok Record 97 write - Ok Record 98 write - Ok Record 99 write - Ok Record 100 write - Ok Record 101 write - Ok Record 102 write - Ok Record 103 write - Ok Record 104 write - Ok Record 105 write - Ok Record 106 write - Ok Record 107 write - Ok Record 108 write - Ok Record 109 write - Ok Record 110 write - Ok Record 111 write - Ok Record 112 write - Ok Record 113 write - Ok Record 114 write - Ok Field 12 Record 0 write - Ok Record 2 write - Ok Field 13 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Record 30 write - Ok Record 31 write - Ok Record 32 write - Ok Record 33 write - Ok Record 34 write - Ok Record 35 write - Ok Record 36 write - Ok Record 37 write - Ok Record 38 write - Ok Record 39 write - Ok Record 40 write - Ok Record 41 write - Ok Record 42 write - Ok Record 43 write - Ok Record 44 write - Ok Record 45 write - Ok Record 46 write - Ok Record 47 write - Ok Record 48 write - Ok Record 49 write - Ok Record 50 write - Ok Record 51 write - Ok Record 52 write - Ok Record 53 write - Ok Record 54 write - Ok Record 55 write - Ok Record 56 write - Ok Record 57 write - Ok Record 58 write - Ok Record 59 write - Ok Record 60 write - Ok Record 61 write - Ok Record 62 write - Ok Record 63 write - Ok Record 64 write - Ok Record 65 write - Ok Record 66 write - Ok Record 67 write - Ok Record 68 write - Ok Record 69 write - Ok Record 70 write - Ok Record 71 write - Ok Record 72 write - Ok Record 73 write - Ok Record 74 write - Ok Record 75 write - Ok Record 76 write - Ok Record 77 write - Ok Record 78 write - Ok Record 79 write - Ok Record 80 write - Ok Record 81 write - Ok Record 82 write - Ok Record 83 write - Ok Record 84 write - Ok Record 85 write - Ok Record 86 write - Ok Record 87 write - Ok Record 88 write - Ok Record 89 write - Ok Record 90 write - Ok Record 91 write - Ok Record 92 write - Ok Record 93 write - Ok Record 94 write - Ok Record 95 write - Ok Record 96 write - Ok Record 97 write - Ok Record 98 write - Ok Record 99 write - Ok Record 100 write - Ok Record 101 write - Ok Record 102 write - Ok Record 103 write - Ok Record 104 write - Ok Record 105 write - Ok Record 106 write - Ok Record 107 write - Ok Record 108 write - Ok Record 109 write - Ok Record 110 write - Ok Record 111 write - Ok Record 112 write - Ok Record 113 write - Ok Record 114 write - Ok Record 115 write - Ok Record 116 write - Ok Record 117 write - Ok Record 118 write - Ok Record 119 write - Ok Record 120 write - Ok Record 121 write - Ok Record 122 write - Ok Record 123 write - Ok Record 124 write - Ok Record 125 write - Ok Record 126 write - Ok Record 127 write - Ok Record 128 write - Ok Record 129 write - Ok Record 130 write - Ok Record 131 write - Ok Record 132 write - Ok Record 133 write - Ok Record 134 write - Ok Record 135 write - Ok Record 136 write - Ok Record 137 write - Ok Record 138 write - Ok Record 139 write - Ok Record 140 write - Ok Record 141 write - Ok Record 142 write - Ok Record 143 write - Ok Record 144 write - Ok Record 145 write - Ok Record 146 write - Ok Record 147 write - Ok Record 148 write - Ok Record 149 write - Ok Record 150 write - Ok Record 151 write - Ok Record 152 write - Ok Record 153 write - Ok Record 154 write - Ok Record 155 write - Ok Record 156 write - Ok Record 157 write - Ok Record 158 write - Ok Record 159 write - Ok Record 160 write - Ok Record 161 write - Ok Record 162 write - Ok Record 163 write - Ok Record 164 write - Ok Record 165 write - Ok Record 166 write - Ok Record 167 write - Ok Record 168 write - Ok Record 169 write - Ok Record 170 write - Ok Record 171 write - Ok Record 172 write - Ok Record 173 write - Ok Record 174 write - Ok Record 175 write - Ok Record 176 write - Ok Record 177 write - Ok Record 178 write - Ok Record 179 write - Ok Record 180 write - Ok Record 181 write - Ok Record 182 write - Ok Record 183 write - Ok Record 184 write - Ok Record 185 write - Ok Record 186 write - Ok Record 187 write - Ok Record 188 write - Ok Record 189 write - Ok Record 190 write - Ok Record 191 write - Ok Record 192 write - Ok Record 193 write - Ok Record 194 write - Ok Record 195 write - Ok Record 196 write - Ok Record 197 write - Ok Record 198 write - Ok Record 199 write - Ok Record 200 write - Ok Record 201 write - Ok Record 202 write - Ok Record 203 write - Ok Record 204 write - Ok Record 205 write - Ok Record 206 write - Ok Record 207 write - Ok Record 208 write - Ok Record 209 write - Ok Record 210 write - Ok Record 211 write - Ok Record 212 write - Ok Record 213 write - Ok Record 214 write - Ok Record 215 write - Ok Record 216 write - Ok Record 217 write - Ok Record 218 write - Ok Record 219 write - Ok Record 220 write - Ok Record 221 write - Ok Record 222 write - Ok Record 223 write - Ok Record 224 write - Ok Record 225 write - Ok Record 226 write - Ok Record 227 write - Ok Record 228 write - Ok Record 229 write - Ok Record 230 write - Ok Record 231 write - Ok Record 232 write - Ok Record 233 write - Ok Record 234 write - Ok Record 235 write - Ok Record 236 write - Ok Record 237 write - Ok Record 238 write - Ok Record 239 write - Ok Record 240 write - Ok Record 241 write - Ok Record 242 write - Ok Record 243 write - Ok Record 244 write - Ok Record 245 write - Ok Record 246 write - Ok Record 247 write - Ok Record 248 write - Ok Record 249 write - Ok Field 14 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Field 15 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Field 16 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Field 17 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Field 18 Record 0 write - Ok Field 19 Record 0 write - Ok Field 22 Record 0 write - Ok Field 26 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Field 27 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Field 28 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Field 29 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Field 30 Record 0 write - Ok Field 32 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Field 33 Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Field 34 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Field 35 Record 0 write - Ok Field 36 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 17 write - Ok Record 18 write - Ok Record 20 write - Ok Field 37 Record 0 write - Ok Field 38 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Field 39 Record 0 write - Ok Field 40 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Field 41 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Field 46 Record 0 write - Ok Record 1 write - Ok Field 51 Record 1 write - Ok Field 54 Record 0 write - Ok Field 57 Record 0 write - Ok Field 60 Record 0 write - Ok Field 61 Record 0 write - Ok Field 62 Record 0 write - Ok Field 64 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Field 66 Record 0 write - Ok Field 68 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Field 69 Record 1 write - Ok Field 73 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Field 74 Record 0 write - Ok Field 91 Record 0 write - Ok Field 93 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Field 94 Record 0 write - Ok Field 100 Record 0 write - Ok Field 101 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 13 write - Ok Record 14 write - Ok Record 16 write - Ok Field 109 Record 0 write - Ok Field 111 Record 0 write - Ok Field 237 Record 0 write - Ok Field 238 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Record 30 write - Ok Record 31 write - Ok Record 32 write - Ok Record 33 write - Ok Record 34 write - Ok Record 35 write - Ok Record 36 write - Ok Record 37 write - Ok Record 38 write - Ok Record 39 write - Ok Record 40 write - Ok Record 41 write - Ok Record 42 write - Ok Record 43 write - Ok Record 44 write - Ok Record 45 write - Ok Record 46 write - Ok Record 47 write - Ok Record 48 write - Ok Record 49 write - Ok Record 50 write - Ok Record 51 write - Ok Record 52 write - Ok Record 53 write - Ok Record 54 write - Ok Record 55 write - Ok Record 56 write - Ok Record 57 write - Ok Record 58 write - Ok Record 59 write - Ok Record 60 write - Ok Record 61 write - Ok Record 62 write - Ok Record 63 write - Ok Record 64 write - Ok Record 65 write - Ok Record 66 write - Ok Record 67 write - Ok Record 68 write - Ok Record 69 write - Ok Record 70 write - Ok Record 71 write - Ok Record 72 write - Ok Record 73 write - Ok Record 74 write - Ok Record 75 write - Ok Record 76 write - Ok Record 77 write - Ok Record 78 write - Ok Record 79 write - Ok Record 80 write - Ok Record 81 write - Ok Record 82 write - Ok Record 83 write - Ok Record 84 write - Ok Record 85 write - Ok Record 86 write - Ok Record 87 write - Ok Record 88 write - Ok Record 89 write - Ok Record 90 write - Ok Record 91 write - Ok Record 92 write - Ok Record 93 write - Ok Record 94 write - Ok Record 95 write - Ok Record 96 write - Ok Record 97 write - Ok Record 98 write - Ok Record 99 write - Ok Record 100 write - Ok Record 101 write - Ok Record 102 write - Ok Record 103 write - Ok Record 104 write - Ok Record 105 write - Ok Record 106 write - Ok Record 107 write - Ok Record 108 write - Ok Record 109 write - Ok Record 110 write - Ok Record 111 write - Ok Record 112 write - Ok Record 113 write - Ok Record 114 write - Ok Record 115 write - Ok Record 116 write - Ok Record 117 write - Ok Record 118 write - Ok Record 119 write - Ok Record 120 write - Ok Record 121 write - Ok Record 122 write - Ok Record 123 write - Ok Record 124 write - Ok Record 125 write - Ok Record 126 write - Ok Record 127 write - Ok Record 128 write - Ok Record 129 write - Ok Record 130 write - Ok Record 131 write - Ok Record 132 write - Ok Record 133 write - Ok Record 134 write - Ok Record 135 write - Ok Record 136 write - Ok Record 137 write - Ok Record 138 write - Ok Record 139 write - Ok Record 140 write - Ok Record 141 write - Ok Record 142 write - Ok Record 143 write - Ok Record 144 write - Ok Record 145 write - Ok Record 146 write - Ok Record 147 write - Ok Record 148 write - Ok Record 149 write - Ok Record 150 write - Ok Record 151 write - Ok Record 152 write - Ok Record 153 write - Ok Record 154 write - Ok Record 155 write - Ok Record 156 write - Ok Record 157 write - Ok Record 158 write - Ok Record 159 write - Ok Record 160 write - Ok Record 161 write - Ok Record 162 write - Ok Record 163 write - Ok Record 164 write - Ok Record 165 write - Ok Record 166 write - Ok Record 167 write - Ok Record 168 write - Ok Record 169 write - Ok Record 170 write - Ok Record 171 write - Ok Record 172 write - Ok Record 173 write - Ok Record 174 write - Ok Record 175 write - Ok Record 176 write - Ok Record 177 write - Ok Record 178 write - Ok Record 179 write - Ok Record 180 write - Ok Record 181 write - Ok Record 182 write - Ok Record 183 write - Ok Record 184 write - Ok Record 185 write - Ok Record 186 write - Ok Record 187 write - Ok Record 188 write - Ok Record 189 write - Ok Record 190 write - Ok Record 191 write - Ok Record 192 write - Ok Record 193 write - Ok Record 194 write - Ok Record 195 write - Ok Record 196 write - Ok Record 197 write - Ok Record 198 write - Ok Record 199 write - Ok Record 200 write - Ok Record 201 write - Ok Record 202 write - Ok Record 203 write - Ok Record 204 write - Ok Record 205 write - Ok Record 206 write - Ok Record 207 write - Ok Record 208 write - Ok Record 209 write - Ok Record 210 write - Ok Record 211 write - Ok Record 212 write - Ok Record 213 write - Ok Record 214 write - Ok Record 215 write - Ok Record 216 write - Ok Record 217 write - Ok Record 218 write - Ok Record 219 write - Ok Record 220 write - Ok Record 221 write - Ok Record 222 write - Ok Record 223 write - Ok Record 224 write - Ok Record 225 write - Ok Record 226 write - Ok Record 227 write - Ok Record 228 write - Ok Record 229 write - Ok Record 230 write - Ok Record 231 write - Ok Record 232 write - Ok Record 233 write - Ok Record 234 write - Ok Record 235 write - Ok Record 236 write - Ok Record 237 write - Ok Record 238 write - Ok Record 239 write - Ok Record 240 write - Ok Record 241 write - Ok Record 242 write - Ok Record 243 write - Ok Record 244 write - Ok Record 245 write - Ok Record 246 write - Ok Record 247 write - Ok Record 248 write - Ok Record 249 write - Ok Field 239 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 7 write - Ok Record 8 write - Ok Record 9 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Record 13 write - Ok Record 14 write - Ok Record 15 write - Ok Record 16 write - Ok Record 17 write - Ok Record 18 write - Ok Record 19 write - Ok Record 20 write - Ok Record 21 write - Ok Record 22 write - Ok Record 23 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 27 write - Ok Record 28 write - Ok Record 29 write - Ok Record 30 write - Ok Record 31 write - Ok Record 32 write - Ok Record 33 write - Ok Record 34 write - Ok Record 35 write - Ok Record 36 write - Ok Record 37 write - Ok Record 38 write - Ok Record 39 write - Ok Record 40 write - Ok Record 41 write - Ok Record 42 write - Ok Record 43 write - Ok Record 44 write - Ok Record 45 write - Ok Record 46 write - Ok Record 47 write - Ok Record 48 write - Ok Record 49 write - Ok Record 50 write - Ok Record 51 write - Ok Record 52 write - Ok Record 53 write - Ok Record 54 write - Ok Record 55 write - Ok Record 56 write - Ok Record 57 write - Ok Record 58 write - Ok Record 59 write - Ok Record 60 write - Ok Record 61 write - Ok Record 62 write - Ok Field 241 Record 0 write - Ok Record 1 write - Ok Field 242 Record 0 write - Ok Field 247 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Done! Elapsed: 00:00:44 Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:12 Reading Phone Info.... SW ver : IMEI : PPM : 0573014 CNT : ICPR81_09w17_U DSP Ver : 5221032617410 PCode : V 05.01 23-09-09 RH-122 (c) Nokia BPCode : V 05.01 23-09-09 RH-122 (c) Nokia IA HWID : LCDVer : 0568809 IMEI : Sl Conf : 303-73-800 Sl Prof : - Sl Aux : Hw Sig : Provider : Unknown providers Lock info: Done! |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
05-28-2011, 15:27 | #12267 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Core version : 1.22 , Rev : 4.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm217__07.30.mcusw PPM : rm217__07.30.ppm_b CNT : rm217__07.30.image_ctv_cn_black Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006010C192101001101 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 07400102532C8C5654B709DE4E1BF8C548B17273 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm217__07.30.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:46 Write : Processing rm217__07.30.mcusw Total 944 [944/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:01:49 MCU Write done ===Flashing [PPM]=== Erase : Processing rm217__07.30.ppm_b Found 1 areas to erase Erasing area 0x01080000 - 0x015FFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:14 Write : Processing rm217__07.30.ppm_b Total 264 [264/0/0] blocks to write, writing... TIME : Write time : 00:00:53 PPM Write done ===Flashing [CNT]=== Erase : Processing rm217__07.30.image_ctv_cn_black Found 1 areas to erase Erasing area 0x01600000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:30 Checking content info... Resetting phone... Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm217__07.30.image_ctv_cn_black ConvertImage: Page Size is 64K, converting... ConvertImage: File converted Loader len: 248320, CHK: 36E3 ADL -> Sending loader... Reset connection... ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok Write : Processing rm217__07.30.image_ctv_cn_black_128 Total 296 [296/0/0] blocks to write, writing... TIME : Write time : 00:00:45 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:05:00 Reboot phone now... Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:06:12 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-28-2011, 15:34 | #12268 (permalink) |
No Life Poster Join Date: Dec 2007 Location: pakistan Age: 41
Member: 653398 Status: Offline Thanks Meter: 670 | matrix m1 format done COM7 [VCP0] selected module v3.30 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7D03:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0013:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0013:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFF0013:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFF0013:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFF0013:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0013:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.30, database date: 16.05.2011): GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.M8708_P3 _MATRIX_GS_T4S1_V01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.M8708_P3 _MATRIX_GS_T4S1_V01.BIN project-id: M8708_P3_MATRIX_GS_T4S1_V01, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.M8708_P3 _MATRIX_GS_T4S1_V01__ffs... file saved: C:\InfinityBox\ChineseMiracle\GOLDDRAGON25_GEMINI_ PCB01_GPRS_MT6225_S00.M8708_P3_MATRIX_GS_T4S1_V01_ _ffs_20110528-162458.B0E.bin flash: 2088C4FFFF0013:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088C4FFFF0013:2088C400000000 Finalization Done Finished, time used: 2 min 31 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
05-28-2011, 15:35 | #12269 (permalink) |
Member: 653398 Status: Offline Thanks Meter: 670 | nktel 2008 flash done COM12 [VCP0] selected module v3.30 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware 5800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_ABROAD_S 5_TM_V1_1_6__NKTEL-2008_16m_En_Ru_Fr_Th_Vn_Hi_Farsi_Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:3703:0006 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:00000000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:00000000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:00000000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:00000000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:00000000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:00000000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 0000000018F09FE518F09FE518F09FE500009FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: c:\InfinityBox\ChineseMiracle\backup_security\id.F 3A4FBE6.[5800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_ABROAD_S 5_TM_V1_1_6.BIN_20C7D0CB].rpl rom info detection finished device-id: F3A4FBE6 rom info ver: 04 sw version: 5800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_ABROAD_S 5_TM_V1_1_6.BIN project-id: N96_P11_ABROAD_S5_TM_V1.1.6, CBD0C720 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98000300000001:00000000000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: 5800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_ABROAD_S 5_TM_V1_1_6__ffs... file saved: C:\InfinityBox\ChineseMiracle\5800_ABROAD_PCB01_GP RS_MT6225_S00.N96_P11_ABROAD_S5_TM_V1_1_6__ffs_201 10528-185945.B0E.bin flash: 98000300000001:00000000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: c:\InfinityBox\ChineseMiracle\backup_security\5800 _ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_ABROAD_S5_TM _V1_1_6__system_log_F3A4FBE6_20C7D0CB_20110528-190048.B0X.bin Area: Firmware flash: 98000300000001:00000000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: c:\InfinityBox\ChineseMiracle\backup_security\5800 _ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_ABROAD_S5_TM _V1_1_6__system_log_F3A4FBE6_20C7D0CB_20110528-190111.B0X.bin Finished, time used: 3 min 22 sec Remove/Install battery now ! |
05-28-2011, 16:03 | #12270 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | registered to: saeedullah_khan Connect phone on selected interface... UFS S/N 113742 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:11 Reading Phone Info.... SW ver : V 04.10 24-04-10 RM-653 (c) Nokia IMEI : 354333048243437 PPM : V 04.10 24-04-10 RM-653 (c) Nokia IA PCode : 0595001 BPCode : 0591994 HWID : 1000 LCDVer : WIN:BOHAIv94 NT39121 IMEI : 354333048243437 Sl Conf : 001-01-00000000000 Sl Prof : 000000000003000-2 Sl Aux : 000B0000 Hw Sig : 041B4B118DF7E120 Provider : Default Test Operator Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! |
