registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.36 Rev : 1.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm704__03.82.mcusw PPM : rm704__03.82.ppm_m_c CNT : rm704__03.82.image_m_c_dgray_059K7P7 Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... Reboot.... Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : SGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.44_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! ===Flashing [MCU]=== File : rm704__03.82.mcusw Image : rm704__03.82.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:04 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:01:49 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:49 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip ===Flashing [PPM]=== File : rm704__03.82.ppm_m_c Image : package_m_c.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:16 Write , Start : 0x41BC0000 , Len : 0x0039353C Flashing , wait ... Region flash done, time : 00:00:05 ===Flashing [CNT]=== File : rm704__03.82.image_m_c_dgray_059K7P7 Image : package_m_c_dgray_059K7P7.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:03:09 Write , Start : 0x421C0000 , Len : 0x00A00000 Flashing , wait ... Region flash done, time : 00:00:16 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:05 No write data, skip Flashing done! Total flash time : 00:06:39 Reboot phone now... Reading Phone Info.... Connected phone - C2-00 Software Info: V 03.82 17-10-11 RM-704 (c) Nokia IMEI: 357416041628642 PPM version : V 03.82 17-10-11 RM-704 (c) Nokia M_C Product code: 059J4Z7 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 42 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:07:12 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok Check communication with phone.... ADL not support backup mode, rpl reading impossible SimLock Data saved... SimLock Key saved... RPL saved : D:\InfinityBox_install_BEST_v1.37.1\Backup\Cert\35 7416041628642_SIM.rpl Elapsed: 00:00:01 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
COM2 [VCP0] selected module v1.72 Device: Samsung-SCH-B239, B259, B279, F302 operation: Rebuild EFS/NV Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... error: can not get correct rebuild answer, test phone after operation error: operation failed Finished, time used: 17 sec |
Core version : 1.36 Rev : 1.3 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-588_40.0.003_prd.core.C00 PPM : RM-588_40.0.003_prd.rofs2.V05 PPM2 : RM-588_40.0.003_C02_prd.rofs3.fpsx CNT : RM588_40.0.003_001_001_U001.uda.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 40.0.003 Phone version : V 20.0.005 -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\351988044885979_SI M.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1C70000F918E0052C95DEE9A11DDB2732D41971B ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-588_40.0.003_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-588_40.0.003_prd.core.C00 Total 450 [450/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:32 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-588_40.0.003_prd.rofs2.V05 Found 1 areas to erase Erasing area 0x06EE0000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-588_40.0.003_prd.rofs2.V05 Total 111 [111/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:08 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-588_40.0.003_C02_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-588_40.0.003_C02_prd.rofs3.fpsx Total 29 [29/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:02 PPM Write done ===Flashing [CNT]=== Erase : Processing RM588_40.0.003_001_001_U001.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F47FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM588_40.0.003_001_001_U001.uda.fpsx Total 49 [49/0/0] blocks to write, writing... TIME : Write time : 00:00:04 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:49 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5230 Software Info: V ICPR72_10w42.2 26-11-10 RM-588 (c) Nokia IMEI: 351988044885979 Ape Version: V 40.0.003 Product code: 0596870 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:18 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
unicair un510c unlock sucessful checking version... Nov 23 2009QSC6010-UN510C Unicare 510 C version selected.. Offline... Downloading mode... Sending boot... patching in progress... patching in progress 50%... patching in progress 100%... Done... phones should be restart... Finished, time used: 24 sec |
Vodafone-345 unlock Done ! COM10 [VCP0] selected module v4.12 Device: Vodafone-345 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:728E:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 869 provider: V345X-2AVDLK1 customization: CM86KS50 customization: XM86KS50 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM86KS50 customization name adjusted flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00005330F4F4B4 flash: 2088BAFFFFFFFF:2088BA00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088BAFFFFFFFF:2088BA00000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Vodafone-345_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W0 8_36_SP1_V28_F1__system_log__00000000_20120212-085453.B0X.bin Finished, time used: 2 min 1 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
Huawei-C2607 unlocked COM15 [VCP0] selected module v1.71 Device: Huawei-C2607 operation: SP-unlock Phone should be Switched ON ! connecting... checking version... C2607C02B105 C2607C02B105 Huawei C2607 version B105 selected.. OFFLINE... downloading mode... erasing... patching in progress... pls wait... patching in progress 25%... patching in progress 50%... patching in progress 100%... DONE... Phones should be restarting now... Finished, time used: 47 sec |
unlocked s399 COM2 [VCP0] selected module v1.72 Device: Samsung-SCH-S259, S269, S299 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 17 sec |
registered to: saeedullah_khan Connect phone on selected interface... Core version : 1.36 Rev : 1.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-625_51.1.002_prd.core.C00 PPM : RM-625_51.1.002_prd.rofs2.V12 PPM2 : RM-625_51.1.002_C01_prd.rofs3.fpsx CNT : RM625_51.1.002_000_001_U003.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1EF000032FA400527DF5840BB8B84B96C32195CE ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! :) TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-625_51.1.002_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-625_51.1.002_prd.core.C00 Total 418 [418/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:30 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-625_51.1.002_prd.rofs2.V12 Found 1 areas to erase Erasing area 0x06CE0000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_51.1.002_prd.rofs2.V12 Total 81 [81/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:06 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-625_51.1.002_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_51.1.002_C01_prd.rofs3.fpsx Total 28 [28/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:02 PPM Write done ===Flashing [CNT]=== Erase : Processing RM625_51.1.002_000_001_U003.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F47FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM625_51.1.002_000_001_U003.uda.fpsx Total 60 [60/0/0] blocks to write, writing... TIME : Write time : 00:00:06 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:46 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5236 Software Info: V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia IMEI: 354850044189231 Ape Version: V 51.1.002 Product code: 059B7L6 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done ;D Done! Elapsed: 00:01:06 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1EF000032FA400527DF5840BB8B84B96C32195CE ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 11.48.0 Processing RAWLOADER... 2nd boot not accepted... Alive Request not done :( Boot error... :( Looks like ASIC not supported, or HW failure Supported : RapuYama, RAP3Gv4, BroadComm, RAPIDO If RAPIDO - use dead mode for read rpl/force local SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\InfinityBox_install_BEST_v1.37.5\Backup\Cert\35 4850044189231_SIM.rpl Phone disconected! Connect phone on selected interface... |
Huawei C2806 sp unlock done checking version... Apr 01 2009C2806C02B103 Apr 01 2009C2806C02B103 Huawei C2806 Apr 01 2009 selected.. OFFLINE... downloading mode... erasing... patching in progress... patching in progress 25%... patching in progress 50%... patching in progress 75%... patching in progress 100%... DONE... Phones should be restarting now... Finished, time used: 54 sec |
registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core version : 1.36 Rev : 1.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm243_07.20_prd_core.fpsx PPM : rm243_07.20_prd_vB21_01_mea_b.fpsx CNT : rm243_ENO_A_2009wk15v0.100.fpsx APE : rm243_07.20_prd_UDA_Nokia_Noir.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL2 Simlock read ... ok SimLock Data saved... SimLock Key saved... RPL saved : D:\InfinityBox_install_BEST_v1.37.5\Backup\Cert\35 9850014230366_SIM.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101021103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 204001105E6300520E120E9B755DA5B0C054FE87 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP ... Processing PASUBTOC ... Boot Done! :) TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 ADL Server confirm flashmode! Get req info : empty ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm243_07.20_prd_core.fpsx Found 3 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x0087FFFF, NAND, CMT Result: 0000 Erasing area 0x00B80000 - 0x04DFFFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader Partitioning : Ok [5] TIME : Erase time : 00:00:01 Write : Processing rm243_07.20_prd_core.fpsx Total 404 [404/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS*CORE] CMT : Writing Hash CERT [SOS+ROFS] TIME : Write time : 00:01:06 MCU Write done ===Flashing [PPM]=== Erase : Processing rm243_07.20_prd_vB21_01_mea_b.fpsx Found 1 areas to erase Erasing area 0x03300000 - 0x04DFFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm243_07.20_prd_vB21_01_mea_b.fpsx Total 164 [164/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFX] TIME : Write time : 00:00:31 PPM Write done ===Flashing [CNT]=== Erase : Processing rm243_ENO_A_2009wk15v0.100.fpsx Found 1 areas to erase Erasing area 0x00880000 - 0x00B7FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm243_ENO_A_2009wk15v0.100.fpsx Total 18 [18/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:02 CNT Write done ===Flashing [APE]=== Erase : Processing rm243_07.20_prd_UDA_Nokia_Noir.fpsx Found 1 areas to erase Erasing area 0x04E00000 - 0x07B3FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm243_07.20_prd_UDA_Nokia_Noir.fpsx Total 1 [1/0/0] blocks to write, writing... TIME : Write time : 00:00:00 APE Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:01:42 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6120 Software Info: V 07.20 05-10-09 RM-243 (c) Nokia IMEI: 359850014230366 Ape Version: 07.20 Product code: 0550022 Checking... SimLock status : Can't get status Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done ;D Done! Elapsed: 00:02:04 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
Core version : 1.36 Rev : 1.3 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm540__04.11.mcusw PPM : rm540__04.11.ppm_i CNT : rm540__04.11.image_i_0580820_001 Flashing phone now... Check files done... -> Check SW version... FlashFile version : 04.11 Phone version : 04.11 09-12-09 RM-540 (c) Nokia -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600000001020C192102034100 CPU ID : RAP3Gv4 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 2700020A7D6B0E49A3FD31EDF9BB1BDF2FDFC8F0 ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 Use RAP3Gv40_2nd.fg , Rev : 3.0 Ver : 11.48.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAP3Gv40_XSR17_alg.fg , Rev : 3.0 Ver : 11.48.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 352691043081470 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\352691043081470_2n d.rpl ===Flashing [MCU]=== Erase : Processing rm540__04.11.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm540__04.11.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 124 blocks TIME : Write time : 00:00:36 MCU Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM]=== Erase : Processing rm540__04.11.ppm_i Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm540__04.11.ppm_i Total writen 27 blocks TIME : Write time : 00:00:09 PPM Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [CNT]=== Erase : Processing rm540__04.11.image_i_0580820_001 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm540__04.11.image_i_0580820_001 Total writen 55 blocks TIME : Write time : 00:00:19 CNT Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ADL: Close_Session Content: 000300000000030000000300000000 ADL: Reboot Flashing done! Total flash time : 00:01:06 Reboot phone now... Reading Phone Info.... Connected phone - Nokia X3-00 Software Info: V 04.11 09-12-09 RM-540 (c) Nokia IMEI: 352691043081470 PPM version : V 04.11 09-12-09 RM-540 (c) Nokia I Product code: 0580697 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:02:33 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.36 Rev : 1.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm495__07.97.image_mena_a1_red Flashing phone now... Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\InfinityBox_install_BEST_v1.37.5\Backup\Cert\35 9371034026114_SIM.rpl Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 1690021269406B50A8FF8452E96C7B561F488768 CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm495__07.97.image_mena_a1_red ConvertImage: Page Size is 128K, no need convert Loader len: 308032, CHK: 048B ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:07 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : ASIC CMT select Ok ===Flashing [CNT]=== Erase : Processing rm495__07.97.image_mena_a1_red Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:43 Write : Processing rm495__07.97.image_mena_a1_red Total 656 [656/0/0] blocks to write, writing... TIME : Write time : 00:01:04 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:06:48 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5130c-2 Software Info: V 07.97 13-09-10 RM-495 (c) Nokia IMEI: 359371034026114 PPM version : V 07.97 13-09-10 RM-495 (c) Nokia MEN Product code: 0571593 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done ;D Done! Elapsed: 00:07:46 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
X2-00 security code done with best dongle. How? connect phone with normal mode on usb wait to install drivers then go to service tool and tick which optione which you wana do. it will automatically swich phone to test mode and do selected job very smoothly.:D Quote:
successfully 2 imeis repair for Chinesse Nokia E71 modulo v3.26 Action: "repair imei" Metodo de escritura de imei: modo-2 Canal de escritura de imei: imei #2 para dual sim/mono CPU Nuevo imei: 520019515573484 Modelo: Autodetect 6205-6239 NOR Checkeando datos, espere... El Telefono deberia estar APAGADO ! Mantenga Presionado el boton Power ! 19200 autodetect Iniciando [6225:8A03:8A00]... CPU: MT6225 alta velocidad de boot On chip: 0001:C403:000A status: FF Connecting at 19200, wait... Deje de presionar el boton power ahora ! Telefono detectado, espere... Hardware: MT6225,E03 Dato: 2006.06.14 Version: 1.0 Version: MAUI.GEMINI.W08.12.F2 Version: PUYANG25_GEMINI_HW detecting structure #2... 5 11Listo 67 byte(s) read imei: 35015020612533 coneccion Ok detecting structure #2... 5 11Listo 67 byte(s) read verificacion... verificacion lista: 52001951557348 Finalizado, tiempo usado: 34 sec Quite/coloque la bateria ahora ! |
zte mf190 unlock done with infinty cdma test report --------------------------------------------------------- HARDWARE : MF190 Ma COMPILE : May 16 2011 (17:51:47) REALEASE : Mar 01 2011 (01:00:00) SW Version : M6290A KPRZL 2 4 0105T --------------------------------------------------------- ESN(hex) : 00000000 ESN(hex) : 00000000 Phonce code : 0000 Finished, time used: 4 sec checking version... Compile : May 16 2011 Version : M6290A-KPRZL-2.4.0105 May 16 2011M6290A-KPRZL-2.4.0105 MF190 version May 16 2011 selected.. disable minlock... done... Finished, time used: 5 sec |
