COM1 [Serial0] selected module v3.62 Device: Alcatel-303X, 303A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:BC6A:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.C4 471940.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_481CB0D4].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: C4471940 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN project-id: MAUI.08A.W08.36.SP1.V9, D4B01C48 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 26C provider: 363A-2BRGDO3 customization: CI26NJ33 customization: XI26NJ33 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XI26NJ33 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-303X,303A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V9__system_log_C4471940_481CB0D4_2010 1103-043138.B0X.bin Finished, time used: 2 min 52 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
Motorola W377 unlock done!!! COM19 [VCP0] selected module v1.38 Loading data, wait... Device: Motorola-W377 Action: unlock Press Power button now ! rom version: 0411 Connecting... booting... finalizing... working, one more step... flash: 0089:8813 working... Finished, time used: 48 sec Remove/Install battery now ! |
Kp110 unlock done COM3 selected module v1.39 Device: LG-KP110 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 352008020912603 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352008020912603_LG-KP110_20101103-124511.B1E.bin .... Check flash Done Check space ... current eeprom imei: 352008020912603 ................................ finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 250 sec Remove/Install battery now ! |
COM2 [VCP2] selected module v3.63 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:4703:A00C status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.44 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203378128 connection Ok 186 byte(s) read reading data... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 13 sec Remove/Install battery now ! smart-card: disconnected |
CIK.4.01Aug 20 2010 MICROMAX C111 20 August 2010 selected.. Offline.. Downloading mode.. patching in progress.. patching in progress 50%... patching in progress 100%.. Done.. Finished, time used: 18 sec |
Zte f285 COM30 [QCUSB_COM30_1] selected module v1.30 Device: ZTE-S130 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... send spc... disabling minlock... Done... Phones should be restarting now... Finished, time used: 6 sec |
vodafone 340 unlock COM3 [VCP0] selected module v3.63 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:0F03:A00A status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.34 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203100850 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 11 min 36 sec Remove/Install battery now ! |
Huawei-C5005 unlock done!! SW : C5005C53B115BOOT: 6000P1B102S--------------------------------------------------------- HARDWARE: SCNRZ...* COMPILE : Jan 08 2009 REALEASE: Jun 29 2006 SW Version : QSC6030-SCNRZ-....--------------------------------------------------------- Phonce code : 0000SPC : SPC2 : 002563Finished, time used: 17 sec --------------------------------------------------------- COM82 [QCUSB_COM82_2] selected module v1.33 Device: Huawei-C5005 operation: SP-unlock Phone should be Switched ON ! connecting... checking version... C5005C53B115 Huawei C5005 version B115 selected.. downloading mode... wait conecting... sending command... patching in progres... patching in progres 10%... patching in progres 20%... patching in progres 30%... patching in progres 40%... patching in progres 50%... patching in progres 60%... patching in progres 70%... patching in progres 80%... patching in progres 90%... pls wait... Done... Phones should be restarting now... Finished, time used: 57 sec |
Huawei c2806 done checking version... Apr 01 2009C2806C02B103 Apr 01 2009C2806C02B103 Huawei C2806 Apr 01 2009 selected.. OFFLINE... downloading mode... erasing... patching in progress... patching in progress 25%... patching in progress 50%... patching in progress 75%... patching in progress 100%... DONE... Phones should be restarting now... Finished, time used: 57 sec |
Nokia 5130 via usb done after a month Friends, I had one nokia 5130 from a 1.5 month ago,tried on mx key with usb & fbus also. not solved. today using BEST SOLVED 100% with flash file 7.97. Nice tool.... proud to be customer of infinity team. Connect phone on selected interface... FlashFile verify disabled Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_mena_a1 CNT : rm495__07.97.image_mena_a1_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 26000103CBB17D56E6994D412CC2DB23BA5A6CAB CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm495__07.97.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:41 Write : Processing rm495__07.97.mcusw Total 1178 [1178/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:57 MCU Write done ===Flashing [PPM]=== Erase : Processing rm495__07.97.ppm_mena_a1 Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:06 Write : Processing rm495__07.97.ppm_mena_a1 Total 388 [388/0/0] blocks to write, writing... TIME : Write time : 00:00:19 PPM Write done ===Flashing [CNT]=== Checking content info... Check Image : Content size is 128k, use direct write mode Erase : Processing rm495__07.97.image_mena_a1_red Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:05 Write : Processing rm495__07.97.image_mena_a1_red Total 656 [656/0/0] blocks to write, writing... TIME : Write time : 00:00:32 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:10:42 Reboot phone now... -> Flashing Failed! :( Maybee HW error, or Downgrade try???! Anyway - try reinsert battery and PowerUp phone manualy Phone is on now. |
Haier C5000 done HA5000MV03 Haier C5000 version 03 selected.. OFFLINE... disabling minlock... Done... Phones should be restarting now... Finished, time used: 5 sec |
nokia 6131 flashed ok :p card found: S/N ********* registered to: shah khalid Connect phone on selected interface... UFS S/N******boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Files Set for Flashing : MCU : rm115__06.10.mcusw PPM : rm115__06.10.ppm_g CNT : rm115__06.10.image_g FlashFile verify disabled Backup enabled, Will read Certificates now... Backup CRT308 CRT308 Backup Created... :) Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 1C90000C21D76B5660F8AB3396D95D246A27E9AE CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 002F0001 < SPANSION => 72NS256N FLASHID : 002F0001 , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : 192FC6AD7BF7A1A4419A3953F3856B1F3F7D4A3600 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 356298014199491 CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 20480 byte(s) Cert Read done! NPC Certificate saved... RPL saved : L:\Best_v1.09\Best\Backup\Cert\356298014199491.rpl Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 1C90000C21D76B5660F8AB3396D95D246A27E9AE CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 002F0001 < SPANSION => 72NS256N FLASHID : 002F0001 , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : 192FC6AD7BF7A1A4419A3953F3856B1F3F7D4A3600 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT select Ok Erase : Processing rm115__06.10.mcusw CMT select Ok Found 9 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00020000 - 0x0007FFFF CMT , NOR , Area : 0x00080000 - 0x000DFFFF CMT , NOR , Area : 0x00100000 - 0x001FFFFF CMT , NOR , Area : 0x00200000 - 0x002DFFFF CMT , NOR , Area : 0x002E0000 - 0x00EDFFFF CMT , NOR , Area : 0x00EE0000 - 0x00EF7FFF CMT , NOR , Area : 0x00EF8000 - 0x00EFFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:57 Write : Processing rm115__06.10.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [PMM_CONF] CMT: Writing Hash CERT [SBIF_CONF] Total writen 849 blocks TIME : Write time : 00:01:22 Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 1C90000C21D76B5660F8AB3396D95D246A27E9AE CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 002F0001 < SPANSION => 72NS256N FLASHID : 002F0001 , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : 192FC6AD7BF7A1A4419A3953F3856B1F3F7D4A3600 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT select Ok Erase : Processing rm115__06.10.ppm_g CMT select Ok Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00F00000 - 0x0145FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:19 Write : Processing rm115__06.10.ppm_g Total writen 274 blocks TIME : Write time : 00:00:27 Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 1C90000C21D76B5660F8AB3396D95D246A27E9AE CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 002F0001 < SPANSION => 72NS256N FLASHID : 002F0001 , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : 192FC6AD7BF7A1A4419A3953F3856B1F3F7D4A3600 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT select Ok Erase : Processing rm115__06.10.image_g CMT select Ok Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01460000 - 0x01FDFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:54 Write : Processing rm115__06.10.image_g Total writen 324 blocks TIME : Write time : 00:00:32 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 6131 Software Info: V 06.10 16-02-07 RM-115 (c) Nokia. IMEI: 356298014199491 Product code: 0532325 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
COM14 [VCP0] selected module v3.25 Action: read unlock codes unlock method: read codes Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:A103:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: S3300_SUNTEL Version: S3300_MB_V1.0 detecting structure #2... 5 11 done 67 byte(s) read imei: 35578000010938 connection Ok detecting structure #1... 1warning: wrong packet cs 2 5 8 9 10 12 13 14 done 178 byte(s) read 166 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 81430 Finished, time used: 26 sec Remove/Install battery now ! |
5130 repair cmaera Configuration... done Checking Camera Configoration... Check phone mode... Phone in Normal mode Seting Local mode... wait... Local mode set CAM1 HW : NIMMIIIIRRFF06150018 CAM1 SW ver : XXXXXX Updating Camera #1 Configuration... Upload done, checking... CAM1 SW ver : 002008 Configuration Ok! Secondary Camera #2 configuration info not exist Done! Phone disconected! |
another Sagem-my220x unlocked:D Code: module v1.78 |
