Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 355705005454751 verification Ok Finished, time used: 2 sec Remove/Install battery now ! Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-2: 135790246811220 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei-2: 355256024727546 verification Ok Finished, time used: 2 sec Remove/Install battery now ! |
ALCATEL 305X UNLOCKED module v3.71 Device: Alcatel-305X, 305A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:BB92:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.FBCF6 610.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_1382AAEA].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: FBCF6610 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, EAAA8213 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 166 provider: 305X-2DVDKE1 customization: CP16CH10 customization: XP16CH10 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP16CH10 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__system_log_FBCF6610_1382AAEA_201 01230-000755.B0X.bin Finished, time used: 3 min 15 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
COM8 [VCP0] selected module v3.71 Action: read unlock codes unlock method: read codes Model: Huawei-G6600 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2UM01V01.04 Version: BYD35_09A_PMWY_HW 82 byte(s) read imei: 35751003811253 connection Ok 189 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 Finished, time used: 19 sec Remove/Install battery now ! |
COM13 ready Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 356072006400187 verification Ok Finished, time used: 4 sec Remove/Install battery now ! Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-2: 135790246811220 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei-2: 356072006400203 verification Ok Finished, time used: 2 sec Remove/Install battery now ! |
Action: "sp-unlock" Code: unlock method: smart fast |
Device: Samsung-SCH-S259 Action: unlock Code: Phone should be Switched ON ! |
Device: Samsung-SCH-B319 Action: unlock Code: Phone should be Switched ON ! |
Device: Samsung-SCH-S339 Action: unlock Code: Phone should be Switched ON ! |
COM12 [VCP0] selected module v1.41 Device: ZTE-C3xx-TATA operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... send spc... disabling minlock... Done... Phones should be restarting now... Finished, time used: 7 sec |
[B]NOKIA 6303I FLASHING DONE BY BEST Selected FlashSettings : SafeFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm638__07.10.mcusw PPM : rm638__07.10.ppm_meac Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created... :) Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Can't verify Bootrom :( Try again... -> Error answer from BootRom -> Boot fail... Flashing failed... Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Selected FlashSettings : SafeFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm638__07.10.mcusw PPM : rm638__07.10.ppm_meac Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created... :) Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Batery valtage : 3794 mV -> Batery voltage less, than 3,8V (3794mV). Continue at user risk Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600000001020C192102054100 EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 1D600117B6360049D16508C5AED263382ECA214A ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 Use RAP3Gv40_2nd.fg Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAP3Gv40_XSR17_alg.fg Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 353402049129795 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\Best\Backup\Cert\353402049129795_2nd.rpl ===Flashing [MCU]=== Erase : Processing rm638__07.10.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm638__07.10.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 125 blocks TIME : Write time : 00:00:42 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing rm638__07.10.ppm_meac Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm638__07.10.ppm_meac Total writen 25 blocks TIME : Write time : 00:00:09 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:53 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6303i classic Software Info: V 07.10 25-03-10 RM-638 (c) Nokia IMEI: 353402049129795 PPM version : V 07.10 25-03-10 RM-638 (c) Nokia MEC Product code: 0594553 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:02:17 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
sfr 115 unlock ok COM10 [VCP1] selected module v3.71 Action: "sp-unlock" unlock method: smart fast Model: SFR-115 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:4A99:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: EFS-SFR-R9SM-P109A17V1.0.4B01 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35403004308774 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! |
Virgin-VM621i Unlock Done COM9 [VCP0] selected module v3.71 Device: Virgin-VM621i Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:4903:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:08EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.5176B F63.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_C4B7397C].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 5176BF63 rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN project-id: MAUI.06B.W07.28.SP1.V38, 7C39B7C4 code offset: 00020000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 266 provider: 600X-2EVRGB1 customization: CJ26CW10 customization: XJ26CW10 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XJ26CW10 customization name adjusted flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XJ26CW10 customization name adjusted flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35765602086926 flash: 98000300000001:08EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:08EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Virgin-VM621i_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W0 7_28_SP1_V38__system_log_5176BF63_C4B7397C_2010123 0-214536.B0X.bin Finished, time used: 3 min 18 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
ot-203 done COM3 [VCP0] selected module v3.63 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:62FA:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 37H provider: 203X-2AALBG1 customization: CM37BU33 customization: XM37BU33 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM37BU33 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35247403570630 flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0101231-105501.B0X.bin Finished, time used: 1 min 44 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
Touch calibration done ....... COM4 [VCP0] selected module v3.25 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.FXD-6100_02_V1_0_030_090715__fullflash_20101231-151047.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:6A03:0007 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: FXD-6100_02_V1.0.030_090715 Version: PCBAV3.1 80 byte(s) read imei: 35350303092756 connection Ok 512 byte(s) read 253 byte(s) read reading data #2... 512 byte(s) read calibration value: 0 writing data... verification... verification Ok Finished, time used: 21 sec Remove/Install battery now ! |
