08-14-2008, 12:59 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2006 Age: 38
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | succsessfully unlocked lg kp130 in infinity box Device: LG-KP130 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 352126023033860 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352126023033860_LG-KP130_20080814-172335.B1E.bin ........ version: - Check flash Done Check space... current eeprom imei: 352126023033860 ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 44 sec Remove/Install battery now ! |
08-14-2008, 15:54 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
08-15-2008, 14:12 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Here is an instruction how to get cable/pinout information: 1. run Infinity-Box Shell 2. select required model 3. see detailed information about cable/pinout Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
08-21-2008, 19:36 | #7 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Setif ALGERIA Age: 44
Member: 80990 Status: Offline Sonork: 100.1583974 Thanks Meter: 312 | COM3 [VCP0] selected Device: LG-KP130 Checking data, wait... advanced flash detection active Action: unlock unlock method: enhanced Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 352126024069574 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352126024069574_LG-KP130_20080821-203300.B1E.bin ........ version: - Check flash Done Check space... current eeprom imei: 352126024069574 Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 30 sec Remove/Install battery now ! |
succsessfully unlocked nec n343i with infinity box | Harkishan singh | Infinity-Box | 4 | 10-27-2009 21:55 |
successfully unlocked LG KP130 with infinity box | dennis1 | Infinity-Box | 1 | 09-02-2009 14:33 |
succsessfully unlock lg kg110 with infinity box | Harkishan singh | Infinity-Box | 4 | 02-18-2009 20:30 |
succsessfully unlocked motorola w377 with infinity box | Harkishan singh | Infinity-Box | 5 | 11-11-2008 08:12 |
succsessfully unlocked lg kp202 wiyh infinity box | Harkishan singh | Infinity-Box | 3 | 09-24-2008 09:28 |
