06-15-2014, 15:39 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: bangladesh
Member: 926902 Status: Offline Sonork: 100.1655575 Thanks Meter: 517 | sucesfully flash symphony L30 100% Chinese Miracle II [MTK module] v 0.01 Load File File_Info : R015_SYMPHY_PCB01_gsm_MT6250_S00.SYMPHONY_L30_V003 _20130613.bin FileVersion : SYMPHONY_L30_V003_20130613 Load File Ok Operation : Flash [ v0.01 ] Operation : Flash [ v0.01 ] ======= Flash Files set for flashing : [ MCU ] : R015_SYMPHY_PCB01_gsm_MT6250_S00.SYMPHONY_L30_V003 _20130613.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 36 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : F21464F554B73C2DAD6EA6367AB77D23 BROM Protocol Version : 05 Setting... Setting done , result code 0x8000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Erase region , wait ... Write data , wait ... Write : R015_SYMPHY_PCB01_gsm_MT6250_S00.SYMPHONY_L30_V003 _20130613.bin Done! Elapsed: 00:00:40 Reconnect Power/Cable! ======= Flash Files set for flashing : [ MCU ] : R015_SYMPHY_PCB01_gsm_MT6250_S00.SYMPHONY_L30_V003 _20130613.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 36 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! Elapsed: 00:00:01 Reconnect Power/Cable! |
The Following User Says Thank You to SAJONDUTTA For This Useful Post: |
06-16-2014, 10:13 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Thank you very much for test report ! Please, in future post CM2-MTK test reports in this thread: http://forum.gsmhosting.com/vbb/f296...iatek-1827134/ |
