tablet smartpad mx10 PROBLEM the tablet was working normally but it has touch issues, so i flashed it using original firmware downloaded from official site, by mistake i downloaded the wrong firmware SN and flashed it, the tablet get killed, i redownloaded the correct firm corresponding to the correct sn 1707, and flashed it using other tools, the tablet is back to life but hangs in logo so i used the original loader spflash tool downloaded from the official site to flash it , the flash completed but with error at the end ( i do not remeber witch error i got ), the tablet get killed another time, i tried to flash it with InfinityBox CM2MT2 but i get error also here is log : Operation : Identify [ v2.13 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM50) MODE : BOOTROM PORT : 50 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1724 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 1501004B545330304D002D2E26358DCF DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 4B000115303053542E2D004DCF8D3526 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 DA : EMI : Failed to get EMI info from selected source! DA : Failed to configure DA! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! i tried to initialise the preloader using InfinityBox CM2MTK 1.58 here is the log : Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 50 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 4B000115303053542E2D004DCF8D3526 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! write preloader User selected Preloader file : preloader_elink8735b_6tb_m.bin Operation : Init Preloader [ v1.58 ] Supported HW by Preloader : FlashID [0] CID : 1501004B3758564D42 , Name : K7XVMB , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 1501004B3858564D42 , Name : K8XVMB , Vendor : 15 , [SAMSUNG] FlashID [2] CID : 90014A483847326404 , Name : H8G2d , Vendor : 90 , [HYNIX] FlashID [3] CID : FE014E50314A39354C , Name : P1J95L , Vendor : FE , [MICRON] FlashID [4] CID : 90014A484147346404 , Name : HAG4d , Vendor : 90 , [HYNIX] FlashID [5] CID : 90014A483847316505 , Name : H8G1e , Vendor : 90 , [HYNIX] FlashID [6] CID : 700100563130303038 , Name : V10008 , Vendor : 70 , [KINGSTON] FlashID [7] CID : 15010049345A4D4D42 , Name : I4ZMMB , Vendor : 15 , [SAMSUNG] FlashID [8] CID : 1501004938584D4D42 , Name : I8XMMB , Vendor : 15 , [SAMSUNG] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 50 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 4B000115303053542E2D004DCF8D3526 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:23 Reconnect Power/Cable! official site : https://mediacomeurope.it/prodotto/M...-mx-10-hd-lite what i observed is that the tablet stuck in brom mode no preloader mode (preloader erased ) now i am stuck how to revive it help me please |
Hello, Select preloader from Factory firmware in EMI tab and post result |
Operation : Identify [ v2.13 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM50) MODE : BOOTROM PORT : 50 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1724 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 1501004B545330304D002D2E26358DCF DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 4B000115303053542E2D004DCF8D3526 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : MT6752 EMI : SRC : preloader_elink8735b_6tb_m.bin EMI : CNT : 0009 EMI : [00] : ID : 1501004B3758564D42 : VEN : SAMSUNG | DEV : K7XVMB : RAM : [ 1,00 GB ] EMI : [01] : ID : 1501004B3858564D42 : VEN : SAMSUNG | DEV : K8XVMB : RAM : [ 1,00 GB ] EMI : [02] : ID : 90014A483847326404 : VEN : HYNIX | DEV : H8G2d : RAM : [ 1,00 GB ] EMI : [03] : ID : FE014E50314A39354C : VEN : MICRON | DEV : P1J95L : RAM : [ 1,00 GB ] EMI : [04] : ID : 90014A484147346404 : VEN : HYNIX | DEV : HAG4d : RAM : [ 1,00 GB ] EMI : [05] : ID : 90014A483847316505 : VEN : HYNIX | DEV : H8G1e : RAM : [ 1,00 GB ] EMI : [06] : ID : 700100563130303038 : VEN : KINGSTON | DEV : V10008 : RAM : [ 1,00 GB ] EMI : [07] : ID : 15010049345A4D4D42 : VEN : SAMSUNG | DEV : I4ZMMB : RAM : [ 2,00 GB ] EMI : [08] : ID : 1501004938584D4D42 : VEN : SAMSUNG | DEV : I8XMMB : RAM : [ 2,00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DA : Failed to configure DA! ERROR : 00000BC4 : DEVICE NOT FOUND Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
