05-12-2018, 07:35 | #1 (permalink) |
Freak Poster Join Date: Feb 2017 Location: INDIA
Member: 2682035 Status: Offline Thanks Meter: 22 | Techno in2 failed cm2 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM42) MODE : PRELOADER PORT PORT : 42 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Identify [ v2.00 r2 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM42) MODE : PRELOADER PORT PORT : 42 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN BROM MODE! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
05-12-2018, 09:38 | #2 (permalink) | |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
find that from factory firmware or tool or if you have free time contact me via telegram https://t.me/kamal_singla | |
05-12-2018, 10:53 | #3 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
Thanks for your understanding..... Br. All infinity box users. | |
The Following 3 Users Say Thank You to Yusuf Lawal For This Useful Post: |
05-12-2018, 11:08 | #4 (permalink) | |
but if he have free time for test we can test if test ok (DA working) then he can upload DA on support no issue | |
The Following User Says Thank You to kamal_singla For This Useful Post: |
05-12-2018, 13:32 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, I have not tested on IN2 but tested on IN5, you can test and post result with this attached DA- Br. Infinity Box Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
05-12-2018, 14:10 | #7 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | YES @sneha;YOU R RIGHT BECAUSE ALL TECNO PHONE DA FILE IS MADE WITH AUTH HAVE FILE FOR THIS PHONE BUT UNABLE TO UPLOAD HERE LAST TIME UPLOAD AND EVERY ONE COPY BUT CM2MT2 UPCOMING UPDATE WILL SUPPORT @JayDi SIR HAVE THIS FILE AND @PASSIONATE_BOYS SIR UPLOADED FILE IS MADE FOR MT6735/MT6737 SO IT WILL NOT WORK GOOD LUCK |
The Following 3 Users Say Thank You to gracy_elec For This Useful Post: |
05-12-2018, 14:46 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Just for fun and right now - try select BQ in model list. I see just 3 SBC key pairs for MT6739. |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
09-25-2018, 07:23 | #9 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: Inside Universe
Member: 442808 Status: Offline Thanks Meter: 195 | Quote:
not booting by selecting 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM39) MODE : BOOTROM PORT : 39 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+SEL BROM : BOOTROM MODE : BQ : SEC_6739 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! | |
