07-04-2020, 20:52 | #1 (permalink) |
No Life Poster Join Date: Sep 2010
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | tecno cf8 dead after flashed Load IDBase v518137 Ok! Operation : Identify [ v2.11 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM67) MODE : BOOTROM PORT : 67 Error : Failed to open port! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.11 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM67) MODE : BOOTROM PORT : 67 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2012 | Manual : Disabled BROM : SOCID : B3F425C02DB135CBBD94301F67BC524BA666B47A80E0615361 FEDB71DF5EE47F BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4002 0000 [0200] F3: 4002 0000 00: 1005 0000 F3: 4002 0000 [0200] F3: 4001 00E0 01: 102A 0001 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
07-08-2020, 20:11 | #6 (permalink) |
Insane Poster Join Date: Mar 2014 Location: Sudan
Member: 2148927 Status: Offline Thanks Meter: 16 | You need Techno Flash Tool to restore your device. Download the tool from the link below and download an official flash. Good luck http://www.mediafire.com/file/cqene9...%255D.zip/file Sent from my SM-G935F using Tapatalk |
07-08-2020, 21:06 | #7 (permalink) | |
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | help Quote:
