02-28-2006, 17:15 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Location: no Life Age: 50
Member: 69564 Status: Offline Thanks Meter: 19 | s299 _enter nck |
02-28-2006, 19:03 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Please, check this: http://forum.gsmhosting.com/vbb/show...9&postcount=38 and include log file when you describe the problem. |
03-01-2006, 01:19 | #3 (permalink) |
Member: 69564 Status: Offline Thanks Meter: 19 | Log opened: [2/28/2006] [11:38:46 PM] App: D:\infinity orig\new_inst\Bird01_v112\Bird01.exe [Infinity Box] v.1.12A Loading, wait... S/N: 05xx:01xx Current device: S288 Done Current device: S299 COM5 ready COM5 selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Read info... Flash ID: 8954 Read info Ok Set baud... 230400 Set baud Ok Check flash... Check flash Ok Check space... In progress[FULL]... Finished Remove/Install battery now ! Time used: 920 sec COM5 selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Read info... Flash ID: 8954 method: 02 Read info Ok Set baud... 230400 Set baud Ok Check flash... Check flash Ok Check space... In progress[EEP]... Active: NCK: 73656788 Inactive: PCK: 00000000 Finished Remove/Install battery now ! Time used: 33 sec Loading... S299_v185_Main_En_Fr.32M.bin Loaded COM5 selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Read info... Flash ID: 8954 method: 02 Read info Ok Set baud... 230400 Set baud Ok Check flash... Check flash Ok Check space... Check space Ok Write... Write: Firmware Write Ok Close... Close Ok Restart... Restart Ok Finished Remove/Install battery now ! Time used: 228 sec COM5 selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Read info... Flash ID: 8954 method: 02 Read info Ok Set baud... 230400 Set baud Ok Check flash... Check flash Ok Check space... Active: NCK: 73656788 Inactive: PCK: 00000000 Finished Remove/Install battery now ! Time used: 20 sec all connection is ok |
How to Enter NCK Code for Bird S299 | kungpaoski | Infinity-Box | 2 | 04-21-2008 08:01 |
How to Enter NCK Code for Bird S299 | ASHRIFF | Infinity-Box | 0 | 08-23-2007 07:56 |
how to enter NCK codes in Bird S299 | meneleo | Infinity-Box | 13 | 01-08-2007 09:24 |
s299 nck problem | MARKIE41 | Infinity-Box | 5 | 10-25-2006 21:01 |
I Would Like To Flash My S299 With Infinity | Mansoor | Infinity-Box | 13 | 07-10-2006 15:11 |
