02-03-2006, 12:02 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | First of all check this: http://forum.gsmhosting.com/vbb/show...9&postcount=38 then: 1. Check Imei. Is it Ok ? 2. Try to flash other firmware/LP/Map with "Erase FFS" option checked. |
02-03-2006, 13:43 | #3 (permalink) | |
Junior Member Join Date: Nov 2002 Age: 48
Member: 17496 Status: Offline Thanks Meter: 0 | Quote:
ts me thank you///you right- imei is bad///,i do repair imei with infinity but not working what i can you do? | |
02-03-2006, 15:02 | #4 (permalink) | |
Insane Poster Join Date: Sep 2003 Location: Ukraine Age: 46
Member: 38419 Status: Offline Thanks Meter: 4 | Quote:
Imei bad, but this "1. Check Imei. Is it Ok ? 2. Try to flash other firmware/LP/Map with "Erase FFS" option checked." ---- don't work. I have backup, but.... B.R. | |
02-03-2006, 15:42 | #7 (permalink) |
Member: 17496 Status: Offline Thanks Meter: 0 | your mehod dont working Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 01227E22212200 Flash: 80E59F00000000 method: 02 Boot Done Set baud... 460800 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Old Imei: 354440000000000 Wait... . . . . Err: New Imei is the same as Old Imei Err: Operation aborted Finished Remove/Install battery now ! Time used: 20 sec |
02-15-2006, 19:17 | #9 (permalink) | |
Freak Poster Join Date: Mar 2005 Location: Ukraine,Kiev Age: 41
Member: 130762 Status: Offline Sonork: @martyn911 Thanks Meter: 127 | Quote:
Why... Anybody write russian into 49 version,that phone working and calling... | |
02-15-2006, 20:24 | #11 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
02-18-2006, 20:24 | #12 (permalink) |
Member: 130762 Status: Offline Sonork: @martyn911 Thanks Meter: 127 | In good we trust!!! No solution,russian and working network,how repair multimedia folder... All 3 firmfare from support not repair this problem... Any idea... How write backup file to phone... I'm reading eeprom and flash from NEC E101 O2 network in good multimedia in folder... Can I write this file in my E101 TIM network... |
02-18-2006, 20:43 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hi, it's very strange that after flashing main+lp+map you have problems with phone. send your backup to: [email protected] we will check it and then it will be possible to write it back. |
02-23-2006, 18:32 | #14 (permalink) | |
02-23-2006, 19:09 | #15 (permalink) | |
nec e 101 | ermac | Phone Unlocking Codes & Maps | 3 | 01-30-2007 20:20 |
NEC e616 I can't call, please help | mamytex | NEC | 3 | 07-16-2006 22:07 |
E700 Dont call | DANY77 | Samsung Hardware Repair | 8 | 10-29-2005 22:37 |
NEC 338 cannot make calls | felix | NEC | 5 | 06-07-2005 17:56 |
922 S3-D2 after repair dont call ;-( | Magic_GSM | Infineon C16X M51 & ARM7 M52 BASED | 2 | 12-22-2001 14:43 |
