02-16-2010, 20:07 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: INDIA
Member: 237007 Status: Offline Thanks Meter: 75 | Touchscreen calibrate NOT possible COM4 [VCP0] selected module v3.07 Action: touchscreen calibration mode: 4 Model: Autodetect 6228-6229 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8E03:000A status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: T600_V04_EnFrArRuSpPeVi_SIGMATEL Version: T600_V04_HW 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-4)... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error: detection failed (20 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't detect eeprom structure id error: operation failed ! Finished, time used: 23 sec Remove/Install battery now ! i am using 4mode and complete formate(ffs) but same problem PLEASE help me |
The Following User Says Thank You to sekar98425 For This Useful Post: |
02-16-2010, 20:44 | #2 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: Faisalabad pakistan
Member: 900083 Status: Offline Thanks Meter: 601 | Quote:
brother just read full flash and try with automatic nmethod with flash file | |
The Following User Says Thank You to /\/\A/\/| For This Useful Post: |
Bypass damaged Touchscreen calibration solution... | InfinitySupport | Infinity-Box | 223 | 10-28-2010 16:51 |
how to skip touchscreen calibration in c2000 | sayedhas | SpiderMan | 5 | 08-10-2008 03:54 |
Touchscreen calibration OK by MODE-2 | Chandreshswami | Infinity-Box | 4 | 08-02-2008 10:19 |
n82 I can not work Touchscreen Calibration | ahmedasmet | Infinity-Box | 4 | 06-25-2008 07:11 |
Bypass damaged Touchscreen calibration solution ( ChineseMiracle v2.45) | Ja\/\/aD | Service Products News & Updates | 0 | 05-25-2008 12:47 |
