05-05-2008, 21:30 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | ***...:::Trend T-100 (Dead) Successful Format with PINFinder:::...*** rx tx suceessfuly found then second use infinity mainsoft select brand trend t-100 in service tab select full flash. 3rd format the phone. phone successfuly format & working perfect.not extra cable use. thanks infinity team. here complete log & pics. :::::::::Backup LOG::::::::: COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:1E040400000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00700000 flash: 01227E22022201:18E59F00000000 checking area[00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00700000 detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00700000-007FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [flash]... file saved: C:\Documents and Settings\Khadim Hussain\Desktop\trend t-100 backup_flash_20080506-004028.B0M Finished, time used: 999 sec Remove/Install battery now ! :::::::::::Formating LOG::::::::::: COM3 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 110 sec Remove/Install battery now ! |
05-06-2008, 17:12 | #2 (permalink) | |
Thank you for detailed test report ! | |
05-07-2008, 13:13 | #3 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | Quote:
Dear Khadim Great work from infinity i have advice for you that NEVER EVER show your serial number of your devices in any forum or public places REMEBER IT hope you understand that pictures you uploaded its showing your serial numbers Br Faisal_Computer | |
The Following User Says Thank You to Faisal_Computer For This Useful Post: |
successful format ( DEAD) new version E71i | zeroualot_7 | Infinity-Box | 8 | 12-31-2009 17:16 |
Successfully formatting samsung f488 with mc tool | farid29 | MC-Tool | 0 | 03-20-2009 20:10 |
Ztc N82-1 Successfully Formatted With Infinity | amit_varietymob | Infinity-Box | 5 | 07-22-2008 08:06 |
Tv Y390 3gsm Successfully Formatted With Infinity | amit_varietymob | Infinity-Box | 1 | 02-14-2008 23:26 |
