03-14-2009, 22:27 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | <<< Trend T-101 dead after flash >>> COM4 [VCP0] selected module v1.64 Device: Trend-T101 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, time used: 23 sec Remove/Install battery now ! |
The Following User Says Thank You to khadim100 For This Useful Post: |
03-15-2009, 08:07 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | is battery was full when you trying to flash ? Please try to flash again with fully charged battery if no luck then rehot it and try again and post results Br Faisal_Computer |
03-16-2009, 21:25 | #7 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
p.s. in future any thread with problem description like "the same", "still same", "same problem", "not work" etc. will be closed due to we can not help if we do not see any problem explanation | |
06-10-2009, 16:49 | #10 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | @InfinitySupport I encountered the same problem while flashing Trend T101 with files from support site. Same error occured "error: erase failed: 00400000" Then I made search on the forum and come to this thread. I selected model "BSNL-G200" from the list and used T101 files from the support site. All the process goes very well (no more error: erase failed: 00400000) but phone couldn't be turned ON. Then I used this file from support "Digibee-BSNL-G200CF_Jan-16-2008.B1M" and flashed the phone and the result is fully working phone. Thank you very very much for this wonderful tip. Now one question arise here why this error occur while selcted model is T101 and why flashfiles of T101 from support site are not working???? Best Regards! yawarniazi |
The Following 3 Users Say Thank You to yawarniazi For This Useful Post: |
01-26-2010, 06:16 | #11 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | @Infinity After flash these flash file i have got a dead phone. Trend-T101_ULC2_Apr-18-2008.B1M Trend-T101_2007-Nov-12.B1M But i make search on google then i reach on this thread I follow instruction that write yawarniazi. I flash this file "Digibee-BSNL-G200CF_Jan-16-2008.B1M" now phone is alive and i has change IMEI of this phone. ==== log: [1/26/2010 10:02:58 AM] ==== COM23 [VCP0] selected module v1.72 Device: Digibee-BSNL-G200CF Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL Z c 0 A d 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20100126-100312.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20100126-100313.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20100126-100314.B1E.bin backup critical area Done Check memory ... unlocking... lock found lock type #1 found operation done Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Write Done Finished, time used: 125 sec Remove/Install battery now ! ==== log: [1/26/2010 10:05:45 AM] ==== COM23 [VCP0] selected module v1.72 Device: Digibee-BSNL-G200CF Checking data, wait... Action: "repair imei" new imei: 354401005889664 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL N W 0 A X 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20100126-100559.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20100126-100559.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20100126-100600.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_imei-area_20100126-100604.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_lock-area_20100126-100607.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found imei found #2 Check memory Done Write ... Erasing: imei-area Writing: imei-area Erasing: lock-area Writing: lock-area Erasing: eeprom-security Writing: eeprom-security Write Done Finished, time used: 33 sec Remove/Install battery now ! Finished |
The Following 3 Users Say Thank You to Shakeel_pattoki For This Useful Post: |
05-12-2010, 20:50 | #13 (permalink) |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Infinity team help plz i cant boot fone after flash with available firmware on support area but agin can boot with backup but ieme damage like(000496250000) and also no sim massege after backup ????????? |
<<< SAM C160 NO SERVICE AFTER FLASH - Final Solution >>> | khadim100 | UST Pro II | 42 | 09-09-2011 06:04 |
trend 101 dead after flash | usman0000 | Infinity-Box | 1 | 01-21-2010 22:54 |
trend 101 died after flash | Maiwand khan | Infinity-Box | 13 | 08-22-2009 12:09 |
<<< w610i dead after unlock >>> | khadim100 | SETool2 | 8 | 08-19-2009 09:48 |
