06-03-2009, 07:36 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: in the office Age: 38
Member: 352329 Status: Offline Thanks Meter: 38 | TV200 testpoint???? hi i have a tv200 user code phone i cant connet software because i dont have testpoint <rx,tx> any body have testpoint or pinout??? please help me advance thanks |
06-03-2009, 22:50 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software If it does supported- i can teach how to find pinout in minutes. Just by measuring voltage on phone system connector pins. |
07-03-2009, 15:41 | #3 (permalink) | |
Freak Poster Join Date: May 2008
Member: 769105 Status: Offline Sonork: 072623812 Thanks Meter: 9 | Quote:
07-03-2009, 21:57 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
ZTC TV200 pinout | proton | Chinese Models & Cloned Phones | 9 | 04-16-2011 13:59 |
Questions of tv200... | Leandro_980 | Chinese Models & Cloned Phones | 2 | 10-19-2008 14:15 |
tv200 | -==unloOok==- | SpiderMan | 6 | 09-13-2008 10:55 |
Spreadtrum Cpu Tv800 ,tv200,t838,t818,t819 %% Oke | serdartelekom | Chinese Models & Cloned Phones | 2 | 07-13-2008 07:29 |
