12-09-2009, 09:13 | #31 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Shahdadpur Age: 33
Member: 600482 Status: Offline Thanks Meter: 85 | ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081037479287 ==> get_sw_version sw ver: P1.2PU03V01.01 ==> get_sec_version sec ver: 00.3231Et(4242) ==> sec_get_security_status result: 00 sw_version_length: 4242 boot_core_state: 4242 system_access_level: 03 key_type: 4242 ==> sec_verify_system_code result: 05 ==> sec_get_security_status result: 00 sw_version_length: 4242 boot_core_state: 4242 system_access_level: 03 key_type: 4242 ==> sec_get_lock_status result: 00 lock status (522): 010001004800E0000200010028011800030001004001B80004 000E00F801000010000100F801100011000E00080200001200 0E000802000013000E000802000014000E000802000001013B F7000000000000000000000000000000000100000001010101 00000000090000000000000000000000000000000100010032 F7010000000000000000000505000000000000000000000000 00000000000000000000000000000000000000000000000000 00050500000000000000000000000000000000000000000000 00000000000000000000000000000000050500000000000000 00000000000000000000000000000000000000000000000000 00000000000005050000000000000000000000000000000000 00000000000000000000000000000000000000000000012F10 010000000000207F076FFFFFFFFF0000090000000001000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000132743008310632040141003F00000000: last error: No errors ==> close_com_port => operation finished Please, send operation.log file to support Include in your mail phone name and full text from phone back label DO NOT run this test many times, it's enough to read information only once ! |
The Following User Says Thank You to jan123 For This Useful Post: |
12-09-2009, 09:15 | #32 (permalink) |
Member: 600482 Status: Offline Thanks Meter: 85 | plz.help infinity team => module version: v. => operation (3) started: COM4 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081037479287 ==> get_sw_version sw ver: P1.2PU03V01.01 ==> get_sec_version sec ver: 00.3231Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status: 020A ==> unlock... verification result: F06001005612010000010105020503050405020000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 ==> restore original mode... last error: No errors => operation finished ==> close_com_port Finished, time used: 20 sec Power Off/On phone now ! |
12-09-2009, 10:12 | #33 (permalink) |
Temporary banned !! Join Date: Apr 2007
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | ANOTHER HUAWEI T156 UFONE 100% UNLOCK => module version: v. => operation (3) started: COM6 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081037479287 ==> get_sw_version sw ver: P1.2PU01V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status: 020A ==> unlock... verification result: F06001005612010000040105020503050405F19DFCFF0000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 ==> restore original mode... last error: No errors => operation finished ==> close_com_port Finished, time used: 19 sec Power Off/On phone now ! ANOTHER HUAWEI T156 1000% UNLOCK DONE |
The Following User Says Thank You to m_tahir1 For This Useful Post: |
12-10-2009, 07:42 | #34 (permalink) |
No Life Poster Join Date: Oct 2007 Location: MX-Key and me ...The Best
Member: 617692 Status: Offline Thanks Meter: 306 | => module version: v. => operation (3) started: COM5 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> check_comm_link last error: Timeout while receiving - please check connection and that DUT is ON => operation finished ==> close_com_port Finished, time used: 11 sec Power Off/On phone now ! |
12-11-2009, 08:13 | #36 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Pakistan Age: 39
Member: 693282 Status: Offline Sonork: 100.1602586 Thanks Meter: 41 | => module version: v.1.72 => operation (3) started: COM3 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081039228583 ==> get_sw_version sw ver: P1.2PU01V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status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restore original mode... last error: No errors => operation finished ==> close_com_port still lock phone what should we do about this error |
12-11-2009, 08:30 | #37 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 37
Member: 199814 Status: Offline Thanks Meter: 1,960 | phone is still locked Quote:
T156 new by ufone | prime_master786 | FuriousGold | 8 | 03-07-2010 13:58 |
Successful unlock ufone NEW T156 by INFINITY | DUNIYA JAMAL | Infinity-Box | 3 | 12-09-2009 17:10 |
ulock new t156 ufone | ZAHID338 | Infinity-Box | 2 | 12-04-2009 23:14 |
ufone new T156 unlocked with new update | hasnain | FuriousGold | 1 | 11-12-2009 18:18 |
how can ulock motorola c123 ufone | Abidqadeer | Infinity-Box | 2 | 02-08-2009 20:03 |
