02-15-2023, 11:10 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Unable to Boot/Read Firmware MT8168 CPU.. device working i just need to backup fw.. preloader mode boot info; Code: Operation: Identify Device [ v2.42 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FLASH PORT: BOTH [ B + P ] [+] Read Deep info: PRL, HW, DEBUG [+] Auto-EMI [+] FireFly UNI-Proto [+] Vendor-Specific Analyzer [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM101) MODE: PRELOADER PORT; PORT: 101 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init... Init passed CHIP: MT8168 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0100 EVOL: 0x0000 HWC: 0x8168 TYPE: LEGACY [MTK] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x01 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT8168 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started NAND: OK CID: 000000000000000000000000 EMMC: OK CID: 00000000000000000000000000000000 DA v0.0.0 DA: EXT_RAM NOT initialized EMMC: OK CID: 00000000000000000000000000000000 NAND: OK CID: 000000000000000000000000 DRAM: 0x0000 DA: DRAM ready Boot to 2nd DA... Boot 2nd DA fail: 0x000007D4 BROM: DOWNLOAD DA FAIL Fail to init protocol Disconnect battery and cable - Check USB drivers - Change cable - Change USB port - Do not use USB-hub - Select another base|model|DA Try again Reconnect Power/Cable now mtk mode boot info; Code: Operation: Identify Device [ v2.42 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FLASH PORT: BOTH [ B + P ] [+] Read Deep info: PRL, HW, DEBUG [+] Auto-EMI [+] FireFly UNI-Proto [+] Vendor-Specific Analyzer [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM99) MODE: BOOTROM; PORT: 99 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init... Init passed CHIP: MT8168 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0100 EVOL: 0x0000 HWC: 0x8168 TYPE: LEGACY [MTK] MEID: F696ADF6F720F5AED5E30A3F8FE8BE29 BROM: Sec Level: 0x000000E0 Mode: EXT VER: 0x05 BL: 0xFE [BOOTROM] BROM: EMI: Search EMI: Not found AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT8168 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA SEND Error: 0x00000001 DEVICE NOT FOUND Unknown reason : Check cable and battery! Retrieve device config... Unknown HW configuration Fail to init protocol Disconnect battery and cable - Check USB drivers - Change cable - Change USB port - Do not use USB-hub - Select another base|model|DA Try again Reconnect Power/Cable now |
