12-08-2006, 10:35 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 131118 Status: Offline Thanks Meter: 40 | unable to find tp on this BenQ M100 help needed i am unable to find testpoint on this board pic attached Back Label : BenQ 56F52(M100)99.G8121.B0D S/N=BoD45100751 bar code IMEI: 354803xxxxxxxxx Bar Code Made by BenQ Last edited by ejazkhan9; 12-08-2006 at 11:02. Reason: more information added |
12-12-2006, 13:51 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | What is phone state ? Is it working or has some problems ? software show message about wrong model selection when eeprom structure can't be recognized like M100. probably eeprom damaged. |
12-13-2006, 09:46 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | What do you mean "dead" ? Is it possible to flash it again ? Did you tried to use different flash files sets ? Use main+LP the same version for flashing. give me log to see flashing process (please, no need to make any screenshot, need to see only text, not pictures). log is in "operation.log" file. also, if phone come to you with "restart" problem - check hardware ! p.s. what do you think, how I can help to you but your short reports like "not work" or "dead" ? let's describe problem detailked and not spam board with tonns of short messages like "dead". |
12-13-2006, 12:00 | #12 (permalink) | |
Member: 131118 Status: Offline Thanks Meter: 40 | Quote:
App: C:\Program Files\InfinityBox\BModule\BModule.exe Loading data, wait... [Infinity Box] v1.23 S/N: 0206:0108 Wait... Current model: O2X1i,O2XLI Done Current model: BenQ M100 Loading file [version 02]... M100_Main_v128[1].6BM.bin Loaded Loading file [version 02]... M100_LP_v128_BQME[1].6BP.bin Loaded COM5 selected Device: BenQ M100 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Skip: Flex Write: Language Pack Skip: Eeprom Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Err: Probably wrong model selected. Continue anyway ? Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:885300010001 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:885300010001 Write: Language Pack Writing Done Finished Remove/Install battery now ! Time used: 354 sec Phone it not Powering on i again flash with same file > > > COM5 selected Device: BenQ M100 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Skip: Flex Write: Language Pack Skip: Eeprom Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Err: Probably wrong model selected. Continue anyway ? Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:885300010001 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:885300010001 Write: Language Pack Writing Done Finished Remove/Install battery now ! Time used: 27 sec still phone is not powering on WBR | |
12-14-2006, 14:25 | #15 (permalink) |
Member: 131118 Status: Offline Thanks Meter: 40 | @ infinity Team thx i flashed my phone with other files which r on support site my phone is alive now but hanging problem is still there. i think its a hardware problem thx again for ur help BR |
Sorry, Unable to find bootloader for this RAP ID !? | mamepap | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-20-2010 05:44 |
e63 Sorry, Unable to find bootloader for this RAP ID ! | godlfc | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 01-30-2010 11:28 |
Sorry, Unable to find bootloader for this RAP ID ! | Jilani001 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-23-2010 06:16 |
Sorry, Unable to find bootloader for this RAP ID ! | Deepakranasaria | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 01-09-2010 12:07 |
1100 RH-99 Flashing Failed - Unable to find flashloader for this FlashID ! | shafeeq | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 10-20-2009 13:39 |
